Need someone with a lathe and some basic skills.... - Custom Fighters - Custom Streetfighter Motorcycle Forum
Register iTrader FAQDonate Image Host All New Posts New Streetfighter Posts Insurance
CustomFighters.com Streetfighter Motorcycle Forum > Need someone with a lathe and some basic skills....
Old Streetfighter Motorcycle Forum Post 03-08-2012, 07:05 PM   #1
mpls|cafe|racer
HipsterKillerGarage
mpls|cafe|racer's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:56 AM
Flipped Off 125 Times in 97 Posts
mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!mpls|cafe|racer is an amazingly helpful member with a good attitude!
Default Need someone with a lathe and some basic skills....
No lathe right now.
I need some bungs made.
I have a tap, and can get a tap drill for you to use. Can send them out as long as I can get them back.
I need 10 bungs, 3/4" BSP mild steel.
Major diameter is 1.041" on the threads....
Need the bungs made out of some 1.25" material, bored and threaded, then turned down on the outside to 1.140" and cut off at a length of 3/4" per bung.
I can send you solid barstock to use and all that.
I kinda need these pretty soon, so if this is something you can do, please contact me.
WAY DOWN HERE ON LEVEL 7, HIDING FROM THE RADIATION.
mpls|cafe|racer is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-08-2012, 07:46 PM   #2
Wes4386
Wes4386's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 75 Times in 41 Posts
Wes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to allWes4386 is a name known to all
Default Re: Need someone with a lathe and some basic skills....
I can do it if no one closer to you comes through.
Wes4386 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-08-2012, 08:11 PM   #3
mpls|cafe|racer
HipsterKillerGarage
That would rule if you could actually.
I can send the material and tooling needed.
If you can get a quote together for me that'd be great.
Thanks.
Old Streetfighter Motorcycle Forum Post 03-08-2012, 09:27 PM   #4
sonic reducer
Local Time: 04:56 AM
sonic reducer is a good noobiesonic reducer is a good noobie
do you not have a lathe at work?
sonic reducer is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-08-2012, 09:58 PM   #5
endo
The Soft Serve Enigma
endo's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 73
Flipped Off 96 Times in 82 Posts
endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!endo is an amazingly helpful member with a good attitude!
Supporter of the Streetfighter Build for Charity 2007 Streetfighter Buildoff - Most Complete Theme
If he had access to it do you think he'd be asking?
Project Redefyned 7/11
If I have to explain, you won't understand.
RIP Michele "MadMadame" Monroe, 30Apr80-24Mar12
RIP Gavin "Greencheezeeta" Butts, 5Oct83-8Sep09
endo is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived endo!
Old Streetfighter Motorcycle Forum Post 03-08-2012, 10:02 PM   #6
mpls|cafe|racer
HipsterKillerGarage
See line 1.
Our lathe at work is a CNC setup, and now that we're doing almost all of our parts in house instead of using a vendor, it's tied up.
No more gov work on the lathe now.
So nope, I do not have a lathe to use at work. Like endo said, if I did, I'd be using it. lol
Old Streetfighter Motorcycle Forum Post 03-09-2012, 03:08 AM   #7
Titanium
Titanium's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:56 PM
Titanium is making some friendsTitanium is making some friendsTitanium is making some friends
would like to help but i think the postage would be a bit high
My T59 project http://www.customfighters.com/forums...ad.php?t=50593
Go Big, Go Loud, Go Proud or Go Home
Better to just look an idiot than open your mouth and confirm it
If you never try, you'll never fail and then you'll never learn
Titanium is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-09-2012, 03:46 AM   #8
mpls|cafe|racer
HipsterKillerGarage
Can't you buy bsp paralell couplings/threaded sockets over on that side of the big dip?
Old Streetfighter Motorcycle Forum Post 03-09-2012, 07:09 AM   #9
Wes4386
If +/-.005 and a machined finish works I'll do them. 50 bucks would work for me.
Old Streetfighter Motorcycle Forum Post 03-14-2012, 06:50 PM   #10
EBCB
EBCB is making some friendsEBCB is making some friendsEBCB is making some friends
PM sent
EBCB is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing Need someone with a lathe and some basic skills.... in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Need someone with a lathe and some basic skills.... on Custom Fighters Streetfighter Motorcycle Forum
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Top USA Streetfighter Motorcycle Websites
