December FOTM entry thread - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Fighter Of The Month > 2016 Fighter of the Month
2016 Fighter of the Month 2016 FOTM Entry and Voting Threads
CustomFighters.com Streetfighter Motorcycle Forum > December FOTM entry thread
Old Streetfighter Motorcycle Forum Post 12-01-2016, 11:16 AM   #1
MikeGyver
\_(ツ)_/
MikeGyver's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:40 AM
Flip Offs: 254
Flipped Off 132 Times in 118 Posts
MikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robboMikeGyver must be robbo
Default December FOTM entry thread
Enter here for the December 2016 FOTM. This is your last chance to attempt to get in on FOTY. So get in on the action!
The rulez:
minimum of 50 posts
4-8 good pics of your bike (and tell us which one you want used for judging)
list of modifications and such
must currently own said bike
past entries allowed providing
1. you did not win
OR
2. you've made measurable upgrades since last time
deadline is the 21st before we start voting
Entry posts only. All others will get Hyosung parts from Santa.
Show me whatcha workin' with...
MikeGyver is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived MikeGyver!
Old Streetfighter Motorcycle Forum Post 12-18-2016, 10:21 AM   #2
busa1300
Senior Fighterer
busa1300's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:40 AM
Flip Offs: 1
Flipped Off 5 Times in 3 Posts
busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month
Default Re: December FOTM entry thread
I don't see much movement here yet this month.
It's literally freezing here.... and work in the garage has slowed to almost zero as well.
SO..... I'm throwing one out for you guys to bash on
Instead of enjoying bikes I already have, I built this instead.....
Not a streetfigher in any sense really...
It has a steel tube frame, wire wheels, aircooled engine, RWU forks, and passenger accommodation even.....
But it is a muscle bike, a forefather to the streetfighter in many ways.
And who doesn't like musclebikes.....?
It was pretty weak when I found it, as it had been left for dead out in the AZ sun since 1990.
But I could see some life in there somewhere....
Once I had an idea where I was going with it....It became a nut and bolt reconstruction. (nuts and bolts included)
To finally this...Use this pic to vote
1978 GS1000E
LEFT FOR DEAD…
Things changed or rebuilt
Frame powdercoated
Original rusted tank swapped out with clean original paint tank
Rear tail swapped with matching original color tail
Rotted seat swapped for clean seatbase and recontoured foam, with new cover
New lower rise handlebars
Rebuilt and repainted switch gear
New throttle cables, speedo cable, tach cable
All wiring redone, with a few new ends to replace missing/cut off wiring.
New Dyna coils, wires, plug ends, and full electronic ignition.
Restored gauges
Polished upper and lower triples
New head bearings
Steering damper and welded on frame mount.
Yoshimura oil cooler adapter and 11 row cooler
Daytona steering brace
GS1100E front forks, completely rebuilt with new bushings and seals, cut main spring and 1.5 inch spacer added to rebound spring. 15 weight fork oil
Rebuilt antidive units
600 Katana front calipers, with my own adapters
Custom fit braided brake lines
B-King front radial master cylinder
GS1100E cut down front fender
GT550 front hub, with 2.75x18 Sun aluminum rim, stainless spokes
GS1150E front and rear rotors
ALL bolts replated by me
New wheel bearings
Rebuilt carbs with Dynojet stage 3 kit and K+N filters
All new engine gaskets
Engine completely soda blasted and repainted as original
Bottom of engine sump pulled off and everything cleaned and checked.
Clutch inspected, valves all checked, along with 135-140 compression throughout.
GS1100E aluminum rear swingarm with new bearings
GS1000C rear hub with Sun 3.5X18 rear alumnium rim, stainless spokes
New 530 conversion front ad rear sprockets and chain
150x70 and 110x18 Avon tires, new tubes
Japanese home market KYB piggyback shocks (1994 GSX1100S)
600 bandit rear caliper, with modified mount, and aluminum control bar
HH sintered metalic brake pads front and rear
600 Katana rear master cylinder with custom mount and aluminum actuating rod
Vance and Hines header
Shoria ion battery
Super heavy duty regulator rectifier swap
ALL rebuilt by me…..
Off into the sunset till next spring.....
Happy Holidays...
More history here...
http://oldskoolsuzuki.info/forums/in...eft-for-dead/&
__________MY TWO STROKE ADDICTION_____________
RGV VJ21 L__________________GT 750 J____________
RGV VJ22 FL_________ GT 750 long term cafe project___
RGV VJ22 N ______________RS 250 Cup Bike_________
RGV VJ23 T__________And one for the water...SX-R 800_
RZ 350_______________The cherry popper...KD 80_____
busa1300 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-20-2016, 09:58 PM   #3
F'dup
Hack in a barn
F'dup's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 34
F'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on here
Well... How about a supermoto?
Had resisted because it's well, you know not a "streetfighter"
First pic is how the bike started.
Ktm 625 headlight
Straight rear fender produce from hand made clay mold
Crf450 twin exhausts on Crf250 mid-pipes with a little stock head pipe reworking
sheet metal side panels
little bit of rear frame reworking
finangled sv650 front brake lever
universal sm front fender, "custom" drilled by me
hand made carbon fiber case savers
warp9 wheels, 320 front rotor
race tech rear shock gold vale and shim pack for sm duty
cogent drop in emulators and straight rate front springs
Please use 3rd picture down for voting
2017 build off sv650 build thread <---Click here
2017 build off party, bullshit and general discussion thread <---Click here
DR650 supermoto build <--click
2000 R6 build <--click
A bit of vaseline should lube your bush up real nice though. Just make sure that your shaft is a good fit.
F'dup is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-21-2016, 06:24 AM   #4
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 597
Flipped Off 1,312 Times in 704 Posts
ROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robbo
Fighter of the Month Fighter of the Month Supporter of the Streetfighter Build for Charity
Up against the bad boys here I know but what tha heck its al good fun.
ZX9R Lighty moded.As always a work in progress
Usual risers and durty bars
SS braid brakelines
SS braid clutch cabel
Choped down Yosh' race can and mid pipe
6R headlamp
carbonfibervinyl wraped me flyscreen
1/2 size blinkers
undertail/plate mount mod
Shorty Pazzoes'
K&N air filter
Overflow can mod
Mini skully on frame (cheers punkvernie RIP mate)
Reg skully on fender ! (cheers Mike G )
That's it Good Luck all and a very merry xmas to everone on CF .
ROBBO' 2009
These people High Fived ROBBO!
Thank you for viewing December FOTM entry thread in the 2016 Fighter of the Month section of our streetfighter motorcycle forum. I hope you found it useful!
2016 Fighter of the Month - December FOTM entry thread on Custom Fighters Streetfighter Motorcycle Forum
