Yantosh's CB1300rr - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2017 Winter Buildoff > Bike Build Threads
Bike Build Threads Post yer bike threads in here.
CustomFighters.com Streetfighter Motorcycle Forum > Yantosh's CB1300rr
Old Streetfighter Motorcycle Forum Post 11-01-2016, 03:36 PM   #1
yantosh
Local Time: 06:42 PM
Flip Offs: 13
yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!yantosh is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month Fighter of the Month Fighter of the Year Fighter of the Month Fighter of the Month Fighter of the Month
Default Yantosh's CB1300rr
Pre build off stuff is in here
http://www.customfighters.com/forums...=118113&page=6
proof of status pics
the plan
take a big fat CB1300, slot in a usd front end, one off swingarm, monoshock, clip ons, race seat, numberboard, no lights ,
lets get to it gents
Old Streetfighter Motorcycle Forum Post 11-01-2016, 05:36 PM   #2
yantosh
Flip Offs: 13
Default Re: Yantosh's CB1300rr
standard clocks ... what's insideum? can I use'um?
the back of them got somewhat fucked in the bikes argument with roadside furniture
what the fuck... it's all PCB stuff...
the back is quite flat once all the bust shit is gone ...... new carbon back plate???
I dunno if it needs to use the standard clocks what with fuel injection and the other clever stuff...
Old Streetfighter Motorcycle Forum Post 11-01-2016, 05:56 PM   #3
yantosh
Flip Offs: 13
hacksawed another 3 bits of tube for the arm
then put a blade arm in the jig, I'll use the suspension set up from this arm so need to make fittings for the jig to hold the ends at the right width and hold the linkage mount in the right place
Old Streetfighter Motorcycle Forum Post 11-02-2016, 01:37 PM   #4
yantosh
Flip Offs: 13
start made to the ends for the arm,
I forsee a lack of lunch breaks for the next few months
Old Streetfighter Motorcycle Forum Post 11-02-2016, 05:00 PM   #5
yantosh
Flip Offs: 13
when I was assembling the swingarm jig I drilled and tapped the holes on top of the uprights ....
this bundle of stuff is the reason why
the bigger bits of angle get drilled and bolted on, the threaded bar goes through the arm and the little angle joins it together
then a little crappy welding later it's the linkage mount position is jigged
4 little tubes turned up to hold the arm ends in the correct position
a blade arm being narrower than a CB13
Plan for tomorrow - try any get the ends, if not finished, ready for the jig
Old Streetfighter Motorcycle Forum Post 11-03-2016, 06:02 PM   #6
yantosh
Flip Offs: 13
cracked on with the arm ends
still need a fair bit of cleaning up, machining in a hurry isn't the best for the finish
Old Streetfighter Motorcycle Forum Post 11-03-2016, 06:09 PM   #7
yantosh
Flip Offs: 13
which fit in the jig like so
then I grab the two bits ob bent tube
and the cross tube
all the tubes still need cut to fit each other
pivot tube tomorrow
Old Streetfighter Motorcycle Forum Post 11-05-2016, 03:02 PM   #8
yantosh
Flip Offs: 13
another couple of days of machining
that's the linkage bearing got a place to reside, lets mill pockets to match the clips ons...... devils in the detail
fits a treat on the cross tube
it'll all tie together kinda like this
Old Streetfighter Motorcycle Forum Post 11-05-2016, 03:22 PM   #9
yantosh
Flip Offs: 13
i'm planning a fair bit of polishing on this bike..... fuckin hate polishing..... guess I better start rubbing the machining marks off stuff
I have access to a large polishing machine, it's not really set up for aloominum , but it'll do
Old Streetfighter Motorcycle Forum Post 11-05-2016, 04:31 PM   #10
yantosh
Flip Offs: 13
fuckinell this frame is heavy , I know... lets chop more of it off
this bit weighs about a ton
which leaves us with this
reckon that's about much steel as I'm going to remove , the subframe will be replaced with an aloominum job after the arms done. I've left the foot control mounting points but i won't be using the standard stuff
Thank you for viewing Yantosh's CB1300rr in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - Yantosh's CB1300rr on Custom Fighters Streetfighter Motorcycle Forum
