So here is a up to today wrap up from the thread in the "dirty tard" sub-forum I started.
Started off with two Dr650's and stripped them both down to bare frame and assembled one out of the good parts from both.
Got the two bikes built into one stock example of a Dr650.
Started chopping up a 2013-2014 CRF450 dual exhaust and combining them with a 06-09 CRF250 mid pipe.
Welded the 450 mufflers to the 250 mid pipe. I did this because I didn't want to use the round mufflers off the 250, I wanted to keep the squareish 450 mufflers. The 250 mid pipe is nice because the inlet diameter matched the dr650 pipe unlike the 450 inlet and would be easier to work with. Also gave me more room by the airbox and shock.
Cut some off of the uglier Dr650 head pipe to give me room to run the exhaust.
Zip tied on mock up pic.
Then I got super lucky and scored a warp-9 supermoto wheel set on ebay at a reasonable price. Came with 17" wheels, pilot tires with ~1000 miles on them, corrected speedo drive, warp 9 320 floating rotor and caliper bracket and a shorty side stand. Which as turns out stand is WAY too short, don't know what they were thinking there lol I'll redo that one.
After I put the wheels on and grabbed those pics I went back at the exhaust. It was still incomplete and zip tied on in those pics.
First de-tab the subframe. Things like old exhaust mounts, and grab handle mounts got cut off.
Removed this mount.
Burned in a new one.
So, that leads us up to where I am at today as far as work on the bike.
Here are the proof of date pics to make it all legal.
Spoiler alert: Video at the end of the post. Probably have to click the photo bucket link as I can't ever get embedding right on here lol...
Right so the exhaust situation. Need to bridge this gap.
I cut the inlet end off the muffler and that piece is the perfect diameter to slip into the new inlet end on the CRF250 mid pipe.
With that part cut short I was left with that above gap to bridge between the head pipe and the mid. So I started cutting out the new piece to weld in.
Eventually got the piece down to a good weldable size and had at it burning it in. Not easy on the eyes, but I never claimed to be a good welder lol. Although I have come a LONG ways ...
Once the mid and the head pipe were joined I went about the muffler brackets. I cut the rubber mounts off the old muffler to help dampen the vibes at the mounts.
Out of pure luck they ended up being the perfect fit for the muffler mounts!
Then I went about goobering those in place.
With both sides goobered on both edges this is how they are looking all mounted up!
If you were wondering, here is pics of clearance between airbox, frame, and shock with the new exhaust.
Only less than ideal part is the clamp on the mid, I got it at the only spot that is accessible with any tool and I can just get a ratchet wrench on there to tighten it up. Should've thought that one out a little better, but I can get it tight so oh well.
So enough pics and talking lets hear how it sounds! Personally I love it, not stupid loud not lame quiet...
Trimmed the inner fender to get that back in and past the new exhaust.
And she is in.
With that sorted I threw it loosely back together to get some pics. Loosing those grab handles and back blinkers cleaned up the ass end pretty good.
Biggest issue (stupid large tail light and plate holder aside) is the number plates. Left is flat up against the exhaust and right is out way too much for the size of the new muffler. That will be addressed further down the road.
Picked up a black UFO supermoto fender, cause the stocker is a bit huge. I'm sure y'all know how to mark and drill four holes in plastic so lets just stick to the "after" pics.
Picked up a KTM 625smc headlight. I like these because you still get an H4 bulb, so it puts out good light, but it's a smaller package than the stocker.
Stoopid easy to mount. Take off the rubber fork straps and then use those holes to bolt it onto the stock DR650 headlight mount :nuts: Got real luck here.
All I needed to do was add a couple of spacers behind to two bolts.
Pics with it on.
That's about it. Need to move speedo and dash around to clean things up a little more upfront but I'll tackle that later.
Thanks for looking and sorry about all the pics
Parts:
S/m fender $26.95
KTM light $30.00
Spacers and hardware "Free from the parts horde."
Some of what needs to go on. RM250 rear fender, unsure of year I've had it in the horde since the days of my 400.
Chop chop.
Add a little RM to the mix.
Roll her outside for some mock up shots since it's not a snow covered ice berg in CT....Yet...
A before shot for comparison.
Thanks for looking guys. And thanks for the high fives too! Got to get back out and try and figure out just how I'm going to make that new fender happen...
Dash apart with a ruff plan on aluminum... You know, cause ever ounce counts...:fu:
Holyos... And more filing than I would like to discuss...
It fits!
It fits... Again..
Out the way. Speedo next.
Just whipping up a drop bracket, and if you don't have a drill press I would %100 recommend the harbor freight one that I got. So much better than a hand drill.
Bolted up to original mount on triple and some new hardware and spacers on the bottom holes.
Some people build with a plan, some people like me, don't...I tend to just mess around with stuff and when something seems to click I move forward. So today I started messing with the rear fender.
Got some supplies, 2 packs of modeling clay (the stuff that doesn't harden), a clay shaping tool set, aluminum tape, packing tape, great stuff and some glue.
Cut off this cross bar. That was behind the remaining stock fender.
Slid the piece of the new RM fender underneath and glued them at the top where they made contact. Sliding underneath allowed me to shorten the length about 1" from the mock up pics.
Packing taped off the area underneath going from frame rail to frame rail then sprayed the great stuff in. This was done to give the fender some support.
So the "plan" I got is to trim away the foam and then I'll use the clay to reshape the RM fender to tie it all into the stocker. I may have to wait a day or two for the spray foam to harden.
So next post the clay work will begin. Thanks for looking y'all :rock:
Arts and crafts store and Home depot supplies: ~$50
Start working the rainbow technicolor dream fender.
Tools I've been using.
So far I am surprised at how easy this is going. I actually said to myself, "Holy shit, this may just work." It's really slow going, but do-able. As you can see I have a lot of shaping left to do but I will chip away at it. Could only get a little time in today as I had to work yesterday, and I'm fighting mono symptoms... Fucking skanks....
Best part of the clay is the material you scrape off just gets balled up and you can reuse it to fill in low spots and rework.
Thanks for looking and for the high fives and comments! Still don't have a "plan" for the fender but I'm happy with how the clay is working so I feel good moving forward!
Fender progress. It's slow going, but working with clay is proving to be surprisingly easy!
Had to cut the last bit of down slope out of the remaining stock fender to give me a straight line.
Started removing clay. Used that line as my bottom reference.
Started shaping the fender out.
Got the left side to a good point then started messing with the right side. Still work to be done on both sides, but I'm happy with the progress at this point.
And possible the best part of the weekend. Hooked up a florescent light above the bike, and I picked up a sweet ass table lift for $300 off a buddy of mine! No more working in the dark and no more sore back for me!
So remember when I said I didn't have a plan? Well that was really dumb....
I was trying to get things symmetrical on both sides of the fender and trying to work out the bottom edge and it wasn't going good...
Then this happens.
I flipped the fuck out and tore off the clay and ripped that hateful bull shit off the bike.
I reached a low point and considered just buying the $165 dollar pre-made straight fender.
Then after I cooled down I said, "This is customfighters for fuck sake that's not how we do it here!"
So a plan was hatched. Yes now I have a plan...
Center line and outside edges of fender mark out on a Ikea furniture laminated board type of thing and fender piece aluminum taped down.
Marked my fender tip spot using the rest of the stock fender tip.
Use a square and mark reference lines across the board.
Trim the tip piece down a little and slide it under the back half piece. Then aluminum tape it down.
Shit ton of card board and aluminum tape to cover the hole and build the fender tip piece up some.
Start throwing on the clay.
So good news now I have reference lines to see where to stop the different areas of clay work. And I also have a good flange around the edge for my mold, which is a huge improvement over doing it on the bike.
I'll be back at shaping the clay soon and obviously post pics as I progress.
Another weekend... Of play doh... Starting to get sick of it, but I can see the light at the end of the 'ol tunnel at this point. I will see this through, it may turn out to be crap... But I will see it through.
Then add a fuck shit stack of aluminum tape with packing tape over that layer.
Got to make the mold now. Hoping to do it after work that way I can leave it in the shop to cure where it's warm. My home "shop" will be too cold.
Then... Well it will be sanding the mold. That is going to take a freaking while, I can see that already...
Just need to get this fender done, I want to do other things but I can't let this die because I moved on to other parts...
Mold primed, black painted (helps to see air bubbles when laying glass), clear coated.
Coated with a light coat of vasoline to help with release.
First layer of fiber glass is the woven cloth, then added three or so layers of loose strand mat.
Pop the fender out of the mold. Killed the mold in the process though. I'll talk about that in discussion thread.
Drill a hole for back mount and counter sink.
Front mounts drilled and nut...thingys<?> mounted on.
Cut off grab handle mounts. Didn't want them on the bike or the holes on the side of the fender.
Will clean up the rest when I prep frame for powder coat.
Mounted.
AAAAAAAAAAnd money shots. arty-smiley:
Tossed on the cut down side panel just to see how that is looking. Kind of like the cut down look with the straight fender. May have to work with that idea a little more.
Thanks for looking and the high fives! Feels good to have that on the bike, I'm really happy how it's looking...
Wanted to do something that didn't involve the rear of the bike for a quick break.
Needed to get rid of the stock pumpkin blinkers.
So I picked up some universal flush mount blinkers. Then mounted them on the stock hand guards. I know, I did that on the R6 build so yeah not that creative. Use your imagination on the white guards, come finishing time they will be black. That will help the blinkers blend in better.
Light up for reference.
How they mount up. Drill the hole in the guard then threaded post with wires goes through and the large plastic nut goes on. Wires run to front harness out of a smaller hole drilled in the guard. Simple stuff....
Made some head way on this todaay, but have the day off tomorrow so I'll finish then. So next update I'll be dealing the last part of the droopy rear fender. The saggy butt subframe section. :CK187:
Clean all the metal, use 3/4" tube for inserts at the new seams. Cutting the tube let me slide it into the joints.
Burn it in and clean up my "welds"
This was the first time I welded round tube. It was a little tricky for me. Some welds looked really good some not so much. But it's burned in and solid and everything cleaned up ok.
Had hoped to get more done this weekend, but you know how that goes.
I did how ever manage to get my china special integrated tail light and plate holder mounted.
Cut these tabs off.
As luck would have it they're the same thread pitch as the bolt on the light. So move them into position and weld in.
Bolt up the light like so.
Here's a tip for welding. Some of you may find it handy. My ground clamp isn't big enough to go around the tube diameter of the frame. So I use a hose clamp around the frame and clamp onto that for the ground. Works really well.
Here is a pic from the ebay ad if you want to know what it looks like light up.
Tail light: $12.99 (I hope it works for a while, lol)
Was talking about it in the party and bullshit thread, so I'll give you a recap in case you didn't see. The brake part of the brake light is beyond horrible it's scary. I'd say skip this light if you are looking for a integrated tail light for your bike. Unless you like fucking with shit to make it work, in which I do so here is what I got.
Wired in a brake light flasher. This will pulse the brake light for me with one of ten patterns you select.
To select the patterns wire the green (or just touch to ground) to a momentary switch. While holding the lever down push the switch (or touch wire to ground) to go through the patterns.
Now, this did help. But it didn't really solve the real problem of the intensity of the led not increasing much on the change from running to brake.
So a new plan was hatched. (1/16" aluminum, because you know..race bike.)
Cut it out pop a bend on the bottom.
Drill some holes and put on a red 6 led strip I've had in the parts hoard for years.
Wire it up to the brake light. it's a 3 wire bar, so the two + leads were joined together for full bright.
Much more comfortable with that, it is super noticeable with the flash patterns. Infact you hardly notice the tail light change now.
So in the end the light is ok at best, the running light and the blinkers are actually good. And the brake light can be made better, but I'd still avoid it like the plague.
Thanks for looking everyone. I tried to upload a video of the flasher but it's failing,, but there are a bunch out there on youtube. I personally think they're worth ever penny.
I think a lot of people run into this problem but I don't see too much talk about it here.
So you throw on your new LED blinkers and integrated tail and all of a sudden all the blinkers light up at the same time when you try left or right. The problem comes from voltage going from one side to the other through the indicator bulb in the dash.
The fix is cheap and easy. Go over to Radio Shack and get two 1n4001 diodes.
Around $1.50 for both...
Pull your dash and cut the two wires for your blinker indicator.
The two diodes go on the two wire from the harness. Grey stripe on diode goes with the flow of current. So think of the grey stripe as the out.
Connect those together and attach to one of the two wires on your indicator bulb.
Next step I got lucky and had an unused connector from the factory I could steal the ground off of. So take the remaining wire from the dash and put that to ground.
And that's it... Your blinkers should now blink separate again. It will not solve the rate at which they blink, that you will need a led specific blinker relay, but it will solve the other problem.
Hope this helps someone out eventually. I know a lot of you are like, "Yeah no shit, everyone knows that."
Most of what you need. Skateboard wheels, threaded rod....nuts,,,
Rear broken down left to right. Nylon lock nut, flat washer, skateboard wheel, flat washer, hex nut on threaded rod. Same on opposite side, 3/8" hardware and rod. Vinyl hose over rod is 1/2" od and that takes up the gap inside the axle. Nut side of axle has 3/8" hole but the other is 1/2".
On.
Front's setup.
Only able to use 1/4" on front due to hole in axle. Hoses go together and in the right side hole in axle. Reduces that to the 1/4" needed.
Washers fit in wheels.
Goes on the same as rear with the hex nut and lock nut on both sides, but had to add nylon spacers to get them away from the forks.
Both on.
Skateboard wheels: $7.00
Misc. home depot hardware: $10
(to be fair it could be cheaper but I buy more than what I need just to have it around)
I wanted an adjustable brake lever. But I didn't want to spend the $40 per lever that warp-9, the only company that makes adjustable levers for DR650, wants to charge.
So I went on ebay looking for similar levers in the suzuki lineup. Found the bandit 400, sv650, gsxr lever around the 2001 vintage was similar in the pivot to where it make contact on the master plunger.
Lever was purchased and a plan was hatched. Stock Dr on left bandit 4 on the right.
Biggest difference is the bandit is twice as thick were it goes into the master cylinder.
So I grabbed the grinder and file and had at it.
Had to work the lower part of the master pivot area to clear the hump in the lever where the adjuster spring is.
Then I drilled and tapped a hole for a screw to hit my brake light switch.
Cut it down to 3 finger width and then popped it in the drill press and drilled four accent hole thingy's in it.
Same treatment for the clutch side.
Down side, sort of. I had to loose the stock hand guards. The brake lever no matter how much I cut out of the guard was still being interfered with. So I'll have to buy a different set of blinkers and mount them some where.
To be honest I wasn't %100 on those guards and blinkers any way. I do think it cleans up the front with out them.
Also started the ground work for the new side panels. Lots left to do on those, but I now have some templates to mess around with.
Thanks for the high 5's everyone. Looks like we will have some reasonable temperatures pretty soon here, so motivation is coming back!
This was the card board template from the last post, it was traced from the cut down plastic panel I had a bunch of posts ago.
I trimmed those down to match what I had in my head for the new shape of the panels.
Bought some 16 gauge steel and cut them out, then popped a couple of bends in.
Bend is a little different on the right side in order to clear the starter relay.
And bam.
I'm really happy how they turned out! I also realized a sheet metal brake would be a fantastic addition to the garage Bends turned out good for being done in a vise by hand. Need to buy a belt for my belt sander so I can finish them up, but because I didn't write it down I forgot it on my two trips to lowes today <sigh> every time lol...
Ended up making a quick change to the right side panel. One of the bends was going the wrong way and didn't match the other angles on the panel. I figured I'd post this up to illustrate a point. If you make side panels or things like body work for your bike, I've found that matching body lines and angles into the new piece will make everything flow better in the end.
I highlighted the bends with some red lines in paint to show you what I mean. Here is the first from yesterday, it's bend was rushed and went in the opposite direction of the other angles making it stand out.
Here is the adjusted. I followed the same angle as the front of the panel, which follows the angle of the seat on the tank. Not a drastic change but it flows with everything much better now. I couldn't leave it, would have bugged the hell out of me
Take the spare clutch and stator covers and cover them in aluminum, or, all you min ehh umm tape.
Wet out four layers of carbon fiber. 2x2 twill, in case you care.
So if you haven't figured it out, I'm making some carbon fiber case guards. Hoping tomorrow they will be cured enough to pop off of the covers and trim up. Then I have hours of wet sanding and finishing work to do. They'll be RTV'd onto the covers in the end, but that won't happen until the motor is painted and back in the bike. And that won't happen until next month.
When they are finished up I'll post up a pic of them "on" the motor for y'all to see.
Cloth and resin left over in horde from projects in the past.
Really appreciate all the high fives!
Cut the little tabs off, flip it to move the offset in and invert it. Then mount the new blinkers. Which imo look better than the hand guard setup.
Want to be able to ride 2 up, so I need to keep the passenger peg mounts. But I don't want to have the pegs on all the time. I also don't want to keep the mounts exposed like this.
Cardboard plan laid out on the scrap titanium from the muffler I cut down on the R6 build.
Cut out before heat treatment with the propane torch.
After some heat.
Then bolt them on.
Then after a lot of wet sanding and a buff here are what the covers look like on. Main objective is to keep the brake and shifter lever from smashing a hole in the actual engine covers in the event of an off.
I freaking hated the square stock mirrors. (These pics show the blinkers better than the last post too.)
SOoo I bought some round mirrors thinking they'd be a straight swap on and look hawt deal.
I had to take my aggression out on these damn things.
Happy with how this weld turned out too p.s.
There... That's better.
Got one more trick up my sleeve for tomorrow's post. Had to buy supplies for that this afternoon. Then I'll be breaking it down and doing the finishing work to it.
Right now I feel comfortable with the pace and being able to finish, but I'll probably need every bit of these last two months.
Thanks for hanging with me on this one y'all!
New mirrors: $26.50
Related Threads
1.6M posts
40.4K members
Since 2006
