Awesomeness. I can't decide whether my tank for my supermoto build is gonna be carbon fiber or aluminum yet.... Might depend on how much my tig welding improves haha. Looking forward to see how this comes out.
Hi, maybe I'm being a bit thick here but I just read loads about this tank & am struggling to see what you are trying to achieve is it just a re-shape of the old tank that you are going to use as is but smoothed out & overlaid with carbon or are you making a plug to take a mold for a carbon cover off
One problem you may face when taking the mold off it is that the heat from the curing process can react with the filler making it shrink or crack deforming area's of your mold, ordinary filler is a big no no in the trade for this reason, any paint can also bubble & crack marking the mold as well .........
One way to minimise the above problem is to cover the finished plug with smooth sheet wax another that can help is a decent coat of 2 pack paint polished smooth & well waxed, either way double gell the plug & let it go off properly before laying the mold up, this will give you plenty of thickness to rub down the inside of your mold & remove imperfections before making the tank out of it, 1200 grade wet or dry & plenty of water & loss of finger prints will be the order of the day for a smooth mold here
Look carefully at the resin you use & speak to the maker if you need to as not all resin is fuel or ethanol proof.
No worries fella you asked people to tell you how to do it better so I did arty-smiley: just trying to pass on a little knowledge gained from a few years in the trade
I'll be honest I cant see the point in treating the tank after making it as that's something that can & does fail (from experience) using purpose made resin to build the tank in the first place is a better option IMO but its yours so do what you think is best
Related Threads
1.6M posts
40.4K members
Since 2006
