I've always wanted to build a slingshot... now I get to build 2!!
This one is a 1990 750. When I got it, it had already had 07 gixxer front and rear ends grafted on. The front looks legit and the rear is not bad, but incomplete.
Once I get the chain line straight and the rear wheel centered, I'll move on to fitting an R6 tail and an MT03 headlight.
The motor is going to be mostly stock, I'm adding k&n pods and a sidewinder header. Can tbd.
Also adding some modern controls, lots of braided hoses with fancy fittings, Koso speedo, and a paint job.
While I'm taking breaks from all of that, I'll be scrubbing the frame and swingarm with Scotch Brite to give them a nice satin brushed finish.
In order to weld them on, I needed to figure out a way to hold each mount at the same height. I prefer fixturing vs working off dimensions and scribe lines. Fixturing always seems to turn out better.
Easiest thing to go off of was the rear set mount hole... but I didn't want to waste time cutting and drilling a temporary structure... the closest handy item did the trick
All I had to do was cut a taper in a bolt head to center it up, and add a piece of drop to the jaws to set the height.
Those subframe mounts you made look great. Really nice work, man. But are you sure one M6 bolt is enough to do the trick? Looks like you have plenty of meat for two M8's on each upper mount. Just a thought.
awesom stuf as ever,yer ally welding looks real nice fer sure and it don't look like ya need any CNC machinery ATM eh
Related Threads
1.6M posts
40.4K members
Since 2006
