#11 | |
HAS AIDS
Local Time: 07:03 PM
CF Cash: 58,115
![]() i has a: 2005 zx10r, 1999 r1 fighterer, 1990 cr500 project, 1995 mcgrath replica cr250 project, 1984 cr250 frame off resto project, 197? gt750 cafe project, 1986 atc200x, 2002 raptor 660r (bought it for girlfriend,) 2002 zuma, old ugly ass honda rebel. official member of the "i want to tap dat (denvers mom edition)" group |
| Advertisement | |
These advertisements only appear for guests, register now for free to remove these ads! |
#12 |
CF Cash: 124,243
Only thing you can do with a bad tank slapper is try to give it more gas and hold on... Most of the time, the bike will stabilize itself. The problem is most guys panic and wreck before the bike has a chance to correct itself. On that particular bike, you definately should invest in a damper if your into high speed stuff. Scotts top mount rotary damper works best IMO. Sometimes it's better to be lucky than good, glad you made it back in one piece.
"Puff puff, give. Puff puff, give. You fuckin' up the rotation." |
#13 |
Fast ZX-12R
I had a 79 XS1100 Special Yamaha that would get head shake. It was kinda strange, it would start at about 116 mph and the faster you went the more it would shake. But it wasn't a violent shake it was a real slow wobble. I couldn't figure out why it was doing it. that was back when my balls were larger than my brain. theres no way I would ride something like that today.
| These people High Fived shotgun! |
#14 |
Sofa king we tall did
Fighterer
Local Time: 08:03 PM
CF Cash: 26,908
Glad your ok man! Sounds like its time to replace the pressure bearing in the triple.
| This user High Fived evil mechanic! |
#15 |
Senior Member
Senior Fighterer
Local Time: 05:03 PM
CF Cash: 13,706
Glad you are OK, but I completely disagree with what you did. There is no reason to have a stabilizer for high speed stuff unless you are on the track. No reason to endanger yourself and others on the road by pulling stupid shit like that on the road. When you are riding on the surface streets and highways, keep your head out of your ass and take it a little easier on the throttle.
| This user High Fived kjhilsinger! |
#16 |
CF Cash: 14,761
Tankslappers happen for a few reasons. Most of the time the rider is gripping the bars too tight. For instance when you get on the gas hard the front end gets light reducing available traction. While on the gas hard you are probably holding on tighter than normal and probably pulling back on the throttle side a bit. Once the front ends traction gets too low your extra force on the bar is great than the friction between the tire/road and the force of the rotating tire keeping it straight. If you have ever wheelied at high speed and turned your bars you will know that the force from a spinning wheel has a huge effect on the bike. usually when the wheel gets a little sideways the contact patch is off center with the rear wheel(how rake/trail affect the contact patch path). so when you shift or reach the point where the wheel starts to weight it goes to right itself(think about casters on a shopping cart). this pitches the bike to one side, the front overshoots and does the same thing over and over again until it can right itself or pitch you.
This seems to happen at high speeds because of aerodynamic lift and lightening of the front end. 165mph is no laughing matter. Without fairings your body produces a good bit of lift even if you are tucked in and holding on. THE LAST THING YOU WANT TO DO is brake. loose grip, neutral throttle and let the bike settle. The bike wants to go straight. Taking your feet off the bike is a bad idea. It changes the CG a good bit and can make things worse. Keep your weight on the seat/pegs. Some people say fight it, gas it and so on. Its up to you and usually the split second it happens, its all reaction so unless it happens often, its going to be luck until it isnt im sure weve all seen this(first part is just a commercial) matt 83gpz750 turbo http://www.customfighters.com/forums...ead.php?t=4541 Parts build-off headlight http://www.customfighters.com/forums...ad.php?t=28354 Discussion http://www.customfighters.com/forums...499#post493499 Parts build-off gauge http://www.customfighters.com/forums...ad.php?t=29821 Discussion http://www.customfighters.com/forums...413#post532413 |
| These people High Fived shift1313! |
#17 | |
MAJOR CATASTROPHE
#18 | |
HAS AIDS
CF Cash: 58,115
#19 |
HAS AIDS
CF Cash: 58,115
imagine this guy would have got his feet down and saved it, thats pretty much how mine played out.
#20 |
CF Cash: 37,249
Putting your feet down will only unsettle the bike more and make thing worse.
| Bookmarks |
| Thread Tools | |
