| 2010 Buildoff Entry Threads All 2010 buildoff entry build threads must be posted in here! |
Thread Tools |
#1 |
I been fightin' gravity
Thats right, you might not think its a streetfighter, but it is.
I'm making it more aggressive, lighter, faster, handle better, and stop better. Plans. Adapt a Honda 900rr front end. Respring rear shock softer. Cut Neck and De rake frontend. Re Do leather seat. Clean up - paint - PC engine parts. Paint frame. Pull dents from tank. Build gauge cluster. Modify swingarm, space out belt drive, for fatter rear tire. Oil cooler. Few other trick secret bits. Pics to come as soon as I get some help. Already done. Monoshocked, Highly modified swingarm and frame. Bobbed. clubman bars. Dropped fuel tank 1.5 inches. Front dropped 4 inches, rear raised 4 inches. Mikuni 40mm flatslide pumper carb. Ported head. Full stainless exhaust and aluminum muffler. Handmade. oh ya will be pushin pounds. I miss you Chris, You're my Hero. RIP 2010 Build Thread Discussion http://www.customfighters.com/forums...ad.php?t=26317 09 Buildoff winner build http://www.customfighters.com/forums...ad.php?t=15986 |
| This user High Fived Truckinduc! |
| Advertisement | |
These advertisements only appear for guests, register now for free to remove these ads! |
| Sponsored Links | |||
Advertisement | |||
#2 |
#3 |
| These people High Fived Truckinduc! |
#4 |
older pics
#5 |
U571 or whatever the hell his name is came over and rode the bike for the last time. Then he helped me pull the front end.
![]() ![]() ![]() ![]() Gonna swap stems soon.
#6 |
top triple I highly modified for front mount risers
#7 |
pressing out stems and swapping them tomorrow. turn a spacer for the upper triple and the front end is on. then turn two more spacers and the front wheel is on.
I have to find or make a spring compressor to swap springs out back. I miss you Chris, You're my Hero. RIP 2010 Build Thread Discussion http://www.customfighters.com/forums...ad.php?t=26317 09 Buildoff winner build http://www.customfighters.com/forums...ad.php?t=15986 |
#8 |
Shitty pics but the rear wheel ill be using, with a matching gsxr wheel up front.
![]() ![]() ![]() and yes I need the wide rear tire for a reason I miss you Chris, You're my Hero. RIP 2010 Build Thread Discussion http://www.customfighters.com/forums...ad.php?t=26317 09 Buildoff winner build http://www.customfighters.com/forums...ad.php?t=15986 |
#9 |
![]() ![]() ![]() ![]() OPINIONS? I miss you Chris, You're my Hero. RIP 2010 Build Thread Discussion http://www.customfighters.com/forums...ad.php?t=26317 09 Buildoff winner build http://www.customfighters.com/forums...ad.php?t=15986 |
#10 |
made front wheel spacers today. Also found out front rim has a small bend near the bead. not too bad though.
Tomorrow, rotor adapter and possibly caliper mount. Stem work and possibly handle bars. I miss you Chris, You're my Hero. RIP 2010 Build Thread Discussion http://www.customfighters.com/forums...ad.php?t=26317 09 Buildoff winner build http://www.customfighters.com/forums...ad.php?t=15986 |
| Bookmarks |
| Thread Tools | |
