#61 | |
Now Sabreless
Local Time: 04:21 PM
Flip Offs: 240
Flipped Off 84 Times in 31 Posts
I laid down another layer of fiberglass on the headlight and sanded it down again. Then I threw a coat of cheap primer on it to see the pinholes and unlevel surfaces. It looks pretty good, going to need to do a skim coat of filler and knock that down and it should be good.
![]() ![]() Also got my bar end mirror in the mail. I'm just using one of the Third Eye bike mirrors. ![]() ![]() ![]() ![]() Quote:
Sabre Build - Continued by RatFighter "Bastard Child Hybrid" Build - XS / FZR |
| Advertisement | |
These advertisements only appear for guests, register now for free to remove these ads! |
| Sponsored Links | |||
Advertisement | |||
#62 | |
Now Sabreless
Flip Offs: 240
I was test fitting all the coolant pipes onto the engine and noticed a problem. With the coolant pipes on, the T for the oil mod lines is in a place so that the connector for the front heads oil mod line is blocked by the coolant pipe.
![]() So, I cut another piece of hose and made a new line for the rear head that was 1.5" longer, so it moved the T further towards the side of the engine, giving me room to run the line under the coolant pipe. The braided line is rubbing on the coolant pipe a little bit, so before I assemble it for the final time I'm going to put some heatshrink on the braided line where the pipe is so it won't rub. ![]() ![]() Since I put that extra 1.5" in the line, it gave me more slack on the main line from the oil gallery so I can get it around the front motor mount easier, without so much rubbing. ![]() I also cleaned up the clutch side cover a bit. The paint was dull and just didn't look good, and the bare aluminum parts were oxidized. So, I took some sandpaper and S100 to it and now it looks just like new. Before: ![]() After: ![]() I started cleaning up the rest of the gasket surfaces on the engine so I can get this thing reassembled soon. I also have been replacing all the seals that I can and cleaning it up along the way. ![]() ![]() ![]() ![]() Quote:
| These people High Fived SabreV45! |
#63 | |
Now Sabreless
Flip Offs: 240
Got a little bit done this morning. I got my gear indicator housing loaded up with the leds and mounted it onto the tach.
![]() I also got the frame and swingarm completely stripped down so that I can get it all painted up tomorrow.
| This user High Fived SabreV45! |
#64 | |
Now Sabreless
Flip Offs: 240
Got some more parts painted. I got the frame, subframe / main coolant pipe and swingarm painted. I did them all with a satin black paint. It is less glossy in person, more of a satin than gloss.
#65 |
V4's FTW
Local Time: 05:21 PM
Flip Offs: 37
Flipped Off 46 Times in 36 Posts
I like satin black.
That oil mod looks familiar too!
2011 Buildoff bike continued: http://www.customfighters.com/forums...ad.php?t=47081 05 VFR800 - daily driver 81 CB900F Supersport - http://www.customfighters.com/forums...ad.php?t=47081 96 VFR750 86 VFR700 - http://www.customfighters.com/forums...ad.php?t=15971 83 VF750F - http://www.customfighters.com/forums...ad.php?t=18850 95 XR250R 96 XR400R 00 XR70R Float like a Goldwing, sting like a gixxer ![]() |
| This user High Fived SEBSPEED! |
#66 | |
Now Sabreless
Flip Offs: 240
+1 on satin black, I love that color.
You should definitely recognize the oil mod, pretty much the same engine as yours, got the parts from the same store, and hell, I even used your thread as a guide when making mine.![]() ![]() ![]() ![]() Quote:
#67 | |
Now Sabreless
Flip Offs: 240
I managed to get the swingarm and rear suspension bolted up and torqued down. I cleaned everything up before I bolted it down, so the back end is ready to go. I mounted the rear wheels so I could bounce the rear and make sure everything was working, which it is.
![]() After I had that all mounted, I decided to mock up the triples, forks, front wheel, headlight bucket, clipons, gas tank and one caliper just to get a good idea of how everything is going to look together. I'm really liking it. ![]() ![]() ![]() I haven't gotten a ton done this week because of my other project that I just started. I started to do a quad-HID projector retrofit for my 00 Eclipse. I bought all of the parts with a little extra money I had from selling the overpriced cold air intake that came on my car and buying a short ram intake for a lot less. I couldn't stand having all the parts lying around so I started the retrofit. I'm using a pair of clear lense aftermarket projectors which I'm modifying the cutoff shields and color modding them which will be a low-beam / fog light and a pair of Infinity G35 bixenon projectors with a pair of replica FX clear lenses and being color modded. They're going to be mounted in a pair of aftermarket headlight housings which already have a shroud with two circular cutouts which I mounted the projectors to aim through. Here's a couple of pictures just because.![]()
#68 |
I love lamps
![]() CF Pimp |
I just started reading up on HID planet. I'm glad to see that you did a 7" round with a bi-xenon projector.
Can you get pictures of the light pattern in the bike housing? looking hella awesome pun not intended "A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects." #1 + #2 88 FZR400 ~ link Tall Bike ~ Build
#69 | |
Candy Paint Whore
CF Lover
Local Time: 03:21 PM
Flipped Off 10 Times in 8 Posts
I thought this level of humour could only be found by browsing 6dollarshirts.com Quote:
#70 | |
I love lamps
![]() CF Pimp |
| Bookmarks |
| Thread Tools | |
