DIY: Fiberglass front fender - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Paint and Bodywork
Paint and Bodywork Anything to do with fabricating bodywork, composites, prep and paint work goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > DIY: Fiberglass front fender
Old Streetfighter Motorcycle Forum Post 05-05-2010, 10:50 PM   #1
Fathead_03
Flashburnt
Fathead_03's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:16 AM
Flip Offs: 145
Flipped Off 35 Times in 30 Posts
Fathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud of
Default DIY: Fiberglass front fender
So I received my 600rr fender, and I hated the look. So I decided to build a front fender. This is how it goes. (BTW - this is the first time I've ever built a fender. Just kinda winging it, but following good rules, so I figured it would help).
Some of the tools(paint brush, roller, glass, resin, scissors, etc.
Start off by cleaning the tire off, so the tape will adhere.
Then tape off more than enough area to lay down the fiberglass. Try your best to make sure things lay flat. The end product will thank you.
(Here I used a piece of rubber hose, to give it a ridge down the middle, like the rest of my bike has)
Then cover everything up so you don't get excess glass, resin, etc on it. Don't cut corners here. This stuff is nasty to get off, especially if you don't notice until its hard.
Then cover the taped area, with a mold release of sorts. I used this PVA mold release. You can spray it on, or brush it on. Only use one layer, and anymore will dissolve the first layer. Then let that dry for 15-30 mins. You can use car wax if you are in a pinch though.
While it was drying, I pre-cut my fiberglass. I actually used 4 layers. A piece of advice. Put some spaced out cuts from side to side, so the fiberglass will conform to the curve of the tire, without bunching up.
(sorry not alot of pics, this gets really messy)Mix your resin, and lay down a layer on the tire. Then lay a layer of fiberglass. Then brush on some more resin. I then rolled the 'glass to make sure all the air bubbles were out and it was laying flat. Then another layer of glass, resin, roll, glass resin roll, glass resin roll. After the final layer, I made sure to roll it very well, to make sure it was laying quite flat. Then let the resin dry and cure. Go have some beers.
Once its cured, you can pull off all the stuff you protected the bike with. Then try to wiggle underneath the fiberglass, on top of the tape. Then slowly pry it up with your hands, and you will see it start to release. High pressured air works too. With little effort, it'll pop right off.
I quickly trimmed the excess off the ends, to get perspective on it. This is what I have.
It fits super close to the tire, conforms perfectly, and will turn out pretty nice. I'll be cutting a bit off each end. and making it super flat, but this is the first step. I plan on attaching it to the sides of the original fender, modified quite a bit though. That will be the next step.
Build Threads
2009 Winter Buildoff CBR Build Thread
After-Buildoff CBR Build Thread
CB750 Hardtail Bobber Build "Old's Cool"
Originally Posted by Denvgasm View Post
someone died ban everything
Originally Posted by vbwstripes View Post
I like carbon peaking through the paint. It's like side boob.
Last edited by Fathead_03; 05-07-2010 at 04:49 AM. Reason: was my first time... hahahahah
Fathead_03 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-05-2010, 10:51 PM   #2
Fathead_03
Flashburnt
Flip Offs: 145
Default Re: DIY: Fiberglass front fender
So this is what the fender looked like after it was all cured. I then mapped out where I wanted to cut.
Start cutting. This is what you have. (I used a cutoff wheel. Worked well, wear a mask)
Then I took a DA with some 40grit to flatten it out, and as I did that, I noticed it was alot flatter than I had thought it would be. No need for filler. Barely a need for icing.
So after going over it all with the DA, I spread some icing on it(Thinner than body filler. Used mostly for filling imperfections, not as much building or shaping). Then I hit it real fast after it dried with the DA again.
So here it is very roughly sanded, just sitting on the tire. Next step is to make a mount for it.
Build Threads
These people High Fived Fathead_03!
Old Streetfighter Motorcycle Forum Post 05-05-2010, 10:51 PM   #3
Fathead_03
Flashburnt
Flip Offs: 145
So here we go on the 3rd installment. Deciding on a way to mount the fender, and actually please to the eye. That took me a long ass time. I am not showing the first design, as it was close, but I modified it to this. So here we go.
I took some steel spacers(from your local Ace Hardware) and used those for the allen bolts to go through, into the stock tabs. Once those were in, I sat on my stool looking at it, trying to decide on a bracket that would look decent. I managed to look up at my headlight bracket, and figured I'd go the same route. I went and got some 5/16" steel bar, and went to town. No fancy tools. A hammer, a cut off wheel, a bench mounted vice, and a welder. Here is what it looked like tacked.
Once I decided I liked it, I ground the fender a little more, to match the profile of the brackets. I then welded up the brackets.
I couldn't find a decent way of mounting them, so I devised this plan. It works for now. I put tabs under the fiberglass, then drilled a hole through, and threw a rivet it in. It doesn't look bad at all, and sure is sturdy. Also, it sits rather close to the tire, which is what I was looking for.
I then did my bedliner theme that follows the rest of the bike, followed by priming and painting the fender.
After it was dry, I assembled it, and riveted it together.
Then installed it on the bike.
Overall, I'm happy with it. I'm going to use this bigass head of mine to maybe think of a different way of mounting it. Until then, this works well. Hope this encourages you to give it a shot yourself.
Build Threads
Old Streetfighter Motorcycle Forum Post 05-05-2010, 11:14 PM   #4
gsf1200R
ShamanFighter
gsf1200R's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:16 AM
Flip Offs: 484
Flipped Off 802 Times in 365 Posts
gsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympusgsf1200R sits atop olympus
im hella jealous...im a klutz and i would like take the extra steps to tape every thing and it would still fuck up some how...im gonna subscribe to this one tho for future reference maybe ill practice with paper mache
Goal: Promote streetfighters to the custom motorcycle scene in America.
Plan: Spread the word to motorcycle enthusiasts through our forum & blog.
gsf1200R is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-06-2010, 12:15 AM   #5
Stephen_ver4.0
Skunk Fighter
Stephen_ver4.0's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 55
Flipped Off 29 Times in 18 Posts
Stephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to allStephen_ver4.0 is a name known to all
fuck yeah! thanks!
Stephen
Stephen_ver4.0 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-06-2010, 12:24 AM   #6
Stephen_ver4.0
Skunk Fighter
Flip Offs: 55
I forgot to mention fathead you can get a yard of cloth for $5 bucks. I had more than enough for my belly pan.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220598563243
It's not as expensive as carbon fiber. I got it in 4 days after I paid.
Stephen
Old Streetfighter Motorcycle Forum Post 05-06-2010, 10:33 AM   #7
Phoebe
Swamp Witch
Phoebe's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 86
Flipped Off 17 Times in 15 Posts
Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!Phoebe is an amazingly helpful member with a good attitude!
That's fantastic, Fathead! Very nice job
Phoebe is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-06-2010, 11:39 AM   #8
Candyman
Perpetual Project
Candyman's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1
Candyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to allCandyman is a name known to all
Fighter of the Month Supporter of the Streetfighter Build for Charity
Great thread. I'm looking forward to seeing how you mount it, thats the only thing that has stopped me from tackling a fender.
Built Not Bought
Let these hands sit not idle.
<SOLD<SOLD
Candyman is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-06-2010, 12:12 PM   #9
SEBSPEED
V4's FTW
Flip Offs: 50
Flipped Off 51 Times in 41 Posts
SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!SEBSPEED is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Year Fighter of the Month Fighter of the Month
I think a good tip for anyone attempting this, would be to start with a new tire to ensure clearance every time you mount a new one(profile will be taller).
Get er done!
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 threads
VFR800 Build
VFR800 Talk
Old Streetfighter Motorcycle Forum Post 05-06-2010, 12:56 PM   #10
chg380
Gear Head
chg380's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 254
Flipped Off 105 Times in 39 Posts
chg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympuschg380 sits atop olympus
Great Job.
Keep the fight alive, Free AFF
chg380 is offline   Reply With Quote on our streetfighter motorcycle forum
Tags
fatheads fender company
Thank you for viewing DIY: Fiberglass front fender in the Paint and Bodywork section of our streetfighter motorcycle forum. I hope you found it useful!
Paint and Bodywork - DIY: Fiberglass front fender on Custom Fighters Streetfighter Motorcycle Forum
