Go Back   Custom Fighters Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Member Project Bikes
Register FAQ iTrader Donate Mark Forums Read
CustomFighters.com Streetfighter Motorcycle Forum > 83 GPz750
Old Streetfighter Motorcycle Forum Post 12-21-2008, 12:56 AM   #71
shift1313
shift1313's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:46 AM
CF Cash: 8,830
shift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud ofshift1313 has much to be proud of
Default Re: 83 GPz750
two more things, the turbo im using is larger than the factory turbo kaw used, doesnt help. and that aluminum mid fairing on the stock 750 turbos, is actually structural and cast aluminum. im not sure if they modded the lower frame where the turbo is but they felt they needed that so im guessing the moved something around down there
shift1313 is offline   Reply With Quote on our streetfighter motorcycle forum
Why not sign up and join the CF family? Register now for free!
Old Streetfighter Motorcycle Forum Post 12-21-2008, 12:57 AM   #72
babyfighter
Fully Qualified Asshole
babyfighter's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:46 PM
CF Cash: 62,254
babyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of lightbabyfighter is a glorious beacon of light
ok then, ill go back to saying nothing and stalking the thread
'89 CBR600 Build.... will stop cutting stuff off one day.....
'90 GSX600F ride.... looks boring.... will do for now....
'80ish KL250 dirty project........ CG powered.....
R.I.P. Gavin 'greencheezeeta' Butts
babyfighter is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-21-2008, 10:13 AM   #73
shift1313
CF Cash: 8,830
comments/questions are always welcome. More often than not i overlook something important:-D.
If you are interested about turbocharging anything there is a great book called Maximum Boost by Corky Bell. Tons of great info in there about everything.
Old Streetfighter Motorcycle Forum Post 12-21-2008, 12:03 PM   #74
spyder
Buy all my shit!
spyder's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
CF Cash: 260,785
spyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to allspyder is a name known to all
I think the first picture you posted showing your header being made (think it was page 6) was a great start. ----V
But as soon as you cut back too far and wraped that plate around it, I think you just killed your header pipe.
I think you should have atleast got some pipe that was pre-bend and took your time with a collector to the turbo. What you got now doesnt look so good man.
You have a great idea and concept, but that header looks like crap man. You can do better then that
<img src=http://www.customfighters.com/forums/image.php?type=sigpic&userid=234&dateline=1249600452 border=0 alt= />
The "For Sale" list people, check it out
The FZR Fighter---> http://www.customfighters.com/forums...ad.php?t=24258
03-05 R6 or R6S Vortex rear sprocket http://www.customfighters.com/forums...ad.php?t=30202
speakers and amps for sale http://www.customfighters.com/forums...ad.php?t=30239
Gas tank camera mount http://www.customfighters.com/forums...ad.php?t=30255
spyder is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-21-2008, 04:54 PM   #75
shift1313
CF Cash: 8,830
there just isnt enough room spyder, believe me this isnt how i wanted to do it at all(and it may change several times). I even played around with taking the tubes away from the motor out to the sides and i just couldnt get it back to the turbo. I actually bought some prebent tubing for this with that in mind but i just didnt/dont have the room . If the turbo was mounted the other way(intake on the left) how i started would have worked just fine, but what you dont see is the exit from all the tubes actually needs to go back towards the motor.(like the paintbrush pic i attached). After xmas im going to take a good look at a factory 750turbo and take pics/measurements of where they put their turbo and how deep the sub oilpan actually is. Im thinking the frame on the front is actually different but i wont know until i go take a look at one.
I think shortly im going to buy a roll bender and i will be able to make some tight radius bends that i just may be able work with. My other option is using heavy sch40 weld-els. I dont want to but they have some really tight bends so i may have to.
thanks for the comments, they are appreciated.
Name:	Collector (4)edit.jpg
Old Streetfighter Motorcycle Forum Post 12-21-2008, 08:28 PM   #76
spyder
Buy all my shit!
CF Cash: 260,785
Im glad you didnt take that the wrong way.. lol Im 110% for what your doin man, just tryin to figure out how you can get this thing to work without makin it look like a hack job.
Did you try and look for a turbo'd header for that bike at all?
Old Streetfighter Motorcycle Forum Post 12-22-2008, 12:48 AM   #77
Bad Kaw
Flying Squirrel
Senior Fighterer
Bad Kaw's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:46 AM
CF Cash: 3,361
Bad Kaw is a good noobieBad Kaw is a good noobieBad Kaw is a good noobie
Great build! 10 outta 10 in my book.
-KR
BTW: I've got a line that I'm working on to get a (totally roached-out) 750 Turbo from a friend...it's my kind of bike b/c it's soooo freakin' rough that 'fightering it will be considered a 'save' and not 'sacrelege' by the purists. If I get it I'll have to drop you pics, you won't believe the physical condition...it's gross!
’82 KZ 1000 J: Mods
’82 KZ 1000 J: ELR Clone
’82 KZ 750 R1 (GPz): ELR cloned
’78 KZ 1000 D: Bone stock…for now…
’78 GS 1000 E: roller/project/junk
’84 GS 1150 ES: minor mods…almost done
’83 XJ 900 R: roller/project/junk
’89 NT 650 Hawk: bone stock (hers)
’82 CB 900 F: 9/11 project (1100F motor, etc…)
Bad Kaw is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-22-2008, 08:53 AM   #78
shift1313
CF Cash: 8,830
not at all man. i appreciate all comments. When i get the chance im going to turn the turbo around. it will make routing the intake a serious pain because it will have to tuck between the header and the engine but it will make the exhaust line a little easier because it will be more of a straight shot. who knows. i still may end up with a factory header and sub oil pan, but thats the easier way out
Old Streetfighter Motorcycle Forum Post 12-22-2008, 08:54 AM   #79
shift1313
CF Cash: 8,830
-KR
Thanks Kaw! I have seen some rough(fire damage) bikes. hopefully you can bring that turbo back to life. I know parts arent the easiest to find
good luck with it.
Old Streetfighter Motorcycle Forum Post 12-22-2008, 02:44 PM   #80
Bad Kaw
Flying Squirrel
Senior Fighterer
CF Cash: 3,361
good luck with it.
Yeah, actually 'parts scarcity' is why it belongs in my garage; new model sport bikes exist to provide proper suspension for 70s-80s superbikes. The bike actually belonged to me for a few months, but then I sold it; had no idea that I would miss that pig, but I do. I had fantasized about yanking the front fairing off and going 'fighter, but had my reservations...now seeing your spectacular results I MUST get it back. When my purist buddies hack on me for not just re-painting it to make it "correct", I'll come whining to this forum for some propper complements.
-KR
BTW: your seat looks comfy, but a bit 'tall' in the saddle. Is it, or is that just a perception on my part?
’82 KZ 1000 J: Mods
  Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Member Project Bikes
Tags
shift1313 is the hulk
Thank you for viewing 83 GPz750 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - 83 GPz750 on Custom Fighters Streetfighter Motorcycle Forum
Streetfighter Forum | Northeast Streetfighters | Dish Network Deals
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vBCredits v1.4 Copyright ©2007 - 2008, PixelFX Studios
