Wiring Aftermarket Headlights - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Electrical and Lights
Electrical and Lights Anything related to the fabrication of lights and other electrical components goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Wiring Aftermarket Headlights
Old Streetfighter Motorcycle Forum Post 07-12-2011, 07:21 AM   #1
Kaos
SHOWUSYATITS
Kaos's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:13 PM
Flip Offs: 71
Flipped Off 59 Times in 47 Posts
Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!
Default Wiring Aftermarket Headlights
This is another question I see quite a lot so I figured why not start a thread for it. It’d be great if this could be stickied.
These are by no means the only way to do it but they are a good start.
There are a few factors involved in wiring up a new headlight. Same bulb configuration? Same wattage/draw?
More often than not your new headlight will have more wires or a different configuration than your stock setup. Chances are, you are going to need to use a relay.
Relays are great for powering headlight circuits, infact many automotive electricians suggest powering your stock headlights thru an aftermarket relay setup. Using a relay gets rid of any voltage drops the stock setup may have and gives full power directly to the bulb.
There are a couple of considerations when wiring up your new relay and these are 1)Wire size and 2)Fuse size.
Your wire rating needs to be greater than the maximum amperage draw of your new setup. Your fuse should also be greater than your maximum amperage draw, but lower than your wire size.
Now some people will say that it is perfectly fine to have the fuse size equal to capability of the wire. I fully disagree with this notion. If the fuse size is equal to or greater than the handling capability of the wire, then there is a chance the wiring could be damaged in the event of a short...it could even cause a fire. Better to have the fuse pop and no damage to the wiring....
Before we can even think about wiring in our new headlights, we need to find out what wattage/amperage our new headlights operate at. Finding out this will help us choose our wire size and in turn our fuse size.
So, who here remembers Ohms Law from school? Remember when we all said to the teachers "We'll NEVER use that!"? Well, you're about to use it!
I = W/V
I = Current (in amps)
W = Power (in watts)
V = Voltage (err, in volts)
For example, we know our Voltage is 12V. Now say our new headlight has a 55w globe, so Power is 55w. So now we take 55 and divide it by 12> 55 / 12 = 4.58
So now we know our globe will draw 4.58amps.
And for those of you that don’t remember Ohms Law or how to use it, here’s a simple calculator to find the amperage:
http://www.raylucke.com/20010926/tools/amps.phtml
So now that we know our operating current, we can choose our wire/fuse size.
Looking on below chart we can see that 18AWG has a max current rating of 4.6V. This will not suffice however, seeing as you will need to use a min 5amp fuse. So looking to the table again we see that 17AWG has a max load of 5.8amps. This coupled with a 5amp fuse would be acceptable. I however would personally consider using 15AWG with a 7,5amp fuse....or even better, use 14AWG. Reason? 14AWG has a rating of 11.8amps. If I wish at a later stage to upgrade the bulb from a 55w to a 100w, I will not have to change the wiring, instead I’ll only have to change the fuse to a 10amp.
The only other thing to consider in wiring choice, is voltage drop. However it is my experience that in the very short distances of motorcycle wiring, voltage drop is not really an issue.....
Anyway, enough of this geek shit, let’s get onto the diagrams shall we?
This first diagram is pretty simple. Using a basic SPST NO relay (Single Pole Single Throw Normally Open) we can power a single filament globe. Ideal for where you may want to add an extra light. Potentially you could run two from this setup, but I would avoid this.
The next diagram would be for running 2 globes, eg a pair of driving lights both ON all the time. It uses a single DPST NO relay (Double Pole Single Throw Normally Open).
Alternatively you could use use two SPST relays to do the same job as such:
The next diagram uses a spst and a spdt to power a new light using a H4 or other twin filament bulb. The disadvantage of this setup is if the spst relay fails, the headlight will be inoperable...
The next uses two spst relays to power a new light using a H4 or other twin filament bulb. The advantage of this setup over the one above is that if one relay fails, you will always have the other putting out light...
The last diagram uses 2 SPST relays (Single Pole Single Throw) to run 2 single filament bulbs where stock utilised a single twin filament (H4) globe. Wiring your new lights directly to the old wiring would result in one light being shut off when High is selected. This wiring diagram allows one light on Low and both on High.
And that is all I can muster for this dreary day fellas/fellalitas.... I shall add more as I think of them, but really I think that about covers all combinations you could need or want.
Originally Posted by jaybuilt
...i have siad it before do what you realy want and do it today above all have your share of fun causc you will damn shure have your share of the other.
CUSTOM FIGHTERS FOR LIFE!
Kaos is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-12-2011, 07:23 AM   #2
ultimate fighter
Remi's Dad
ultimate fighter's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:43 PM
Flip Offs: 1,425
Flipped Off 873 Times in 397 Posts
ultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on hereultimate fighter spends too much time on here
Default Re: Wiring Aftermarket Headlights
Repped buddy
Remi Gavin michele RATdad
UF's 2017 build off cb550
UF's 2017 build off discussion
Originally Posted by yantosh View Post
CB is cool as fuck , proper old skool kick your cunt in for looking at it funny
ultimate fighter is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived ultimate fighter!
Old Streetfighter Motorcycle Forum Post 07-12-2011, 07:49 AM   #3
nemo
Do a skid!
nemo's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:43 PM
Flip Offs: 2,794
Flipped Off 435 Times in 208 Posts
nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!nemo is an amazingly helpful member with a good attitude!
Thanks man, this is a big help! Repped fer sure!!
Originally Posted by Motohorho View Post
Looks just like turbo, only smaller ...
nemo is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived nemo!
Old Streetfighter Motorcycle Forum Post 07-12-2011, 09:52 PM   #4
mitch500
Fightering commuter bikes
Fighterer
Local Time: 12:43 PM
Flip Offs: 32
Flipped Off 22 Times in 4 Posts
mitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well liked
Repped. Those will come in handy.
mitch500 is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived mitch500!
Old Streetfighter Motorcycle Forum Post 07-12-2011, 10:01 PM   #5
tlstreak
Senior Fighterer
tlstreak's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:43 PM
Flipped Off 2 Times in 1 Post
tlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to alltlstreak is a name known to all
Im lazy and skimmed, but didnt see something that I have probably messed up and im decent at wiring. What or How do these Euro parking lights work or wire. I hope im explaining that correctly. The little bulb that is always on although my headlight is always on with the bike regardless.
I kinda like having it, but what are the options of running the little bulb. When my headlight burns out it shorts the parking lamp too. not a big issue, but would like to keep it as a back up since Irun a single light.
tlstreak is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-12-2011, 10:11 PM   #6
Kaos
SHOWUSYATITS
Flip Offs: 71
What light are you running mate and how do you have it wired up at the moment? Are you going thru a relay or your stock wiring?
Old Streetfighter Motorcycle Forum Post 07-13-2011, 06:05 PM   #7
tlstreak
Senior Fighterer
umm well modified stock wiring. H4 buld wired seperate. Then a mini parking light is what they are called here. Maybe a running light elsewhere. Not sure of the bulb to tell the truth. Ive simple got it wired hot and grounded into the same ground as the H4. I had 3 seperate bulbs stock. But the lowbeams all run constant with the bike on. I could unplug the little bulb and never notice it being gone.
Old Streetfighter Motorcycle Forum Post 07-16-2011, 10:13 AM   #8
Kaos
SHOWUSYATITS
Flip Offs: 71
Hmm can't really visualise how you've wired it up man. How often is your bulb burning out? The only way I can see it affecting your parker bulb is if you have it wired in series...
When you say you had 3bulbs stock, what were they? Were they all single filament bulbs (H1, H3 etc)?
If possible please do a crude wiring diagram for me bud. Just something showing what wires you are using from the bike going to the bulbs.... then I can draw you up a diagram of how I would wire it....
Old Streetfighter Motorcycle Forum Post 07-16-2011, 12:29 PM   #9
tlstreak
Senior Fighterer
Dont worry about it, ill wire it differently soon enough. To tell the truth I have not had any motivation to touch the bike much at all this year. Ive actually thought about getting rid of it and going with something different and starting over. I still go sit and look at it, but not much else at this point.
Old Streetfighter Motorcycle Forum Post 08-15-2011, 03:39 PM   #10
The Dude Abides
NoObie
Noobie
Local Time: 07:43 PM
The Dude Abides is a good noobieThe Dude Abides is a good noobie
Great post man. This is really helpful. Can you recommend cheap relays for this purpose?
On my 250 ninja I'm going from 1 H4 to a 2 H4. Will whatever the cheapest work so long its like 10 amp or more?
The Dude Abides is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived The Dude Abides!
Thank you for viewing Wiring Aftermarket Headlights in the Electrical and Lights section of our streetfighter motorcycle forum. I hope you found it useful!
Electrical and Lights - Wiring Aftermarket Headlights on Custom Fighters Streetfighter Motorcycle Forum
