starter solenoid swap - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Electrical and Lights
Electrical and Lights Anything related to the fabrication of lights and other electrical components goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > starter solenoid swap
Old Streetfighter Motorcycle Forum Post 08-29-2011, 01:04 AM   #1
lynchingacers
V-4 for 4 life
lynchingacers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:37 PM
Flip Offs: 9
Flipped Off 12 Times in 6 Posts
lynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of lightlynchingacers is a glorious beacon of light
Default starter solenoid swap
finally got fed up with using a screwdriver everyday
if this is in the wrong area please move to the right place
me and a friend fixed my stupid starter solenoid and replaced it with something that should never really wear out.. my friend helped alot and i am now sharing this with you.
do this only if you hate 50 dollar solonoids have a diagram and at least have knowledge of BASIC DC electrics
PARTS LIST
1-Solenoid: 85 bronco stater solenoid ( 13.95$ at orileys auto) Master pro PN#2SS4
2-bought a 20ft roll of 14Gauge RED primary wire from orchard 5$
3- A FEW FEET OF OTHER COLORS my bike uses green or green+stripe for all grounds and about a 2 foot of yellow
3- assorted crimp fittings ( ring spade in a couple sizes)
4- 30Amp Fuse holder ( yes you need one unless you want crispy wiring) i used these theyre really nice
you will also need heat shrink tube and at least a lighter!!!
Tools
wire clippers
Wire Crimpers/ strippers
screwdrivers
small sockets or tiny crescent wrench
i cant stress this oene enough a Wiring schematifc for youre bike!!!!!!
a couple wrenches i needed 10mm and 12mm for gas tank, battery posts and such i did a bit unrelated wiring while in there
i ended up replacing the battery leads one to the motor for ground and the positive lead to the solenoid with Welding Cable 4 gauge
if you don't have the cable length for relocating it you need to make new cables my friend makes them out of welding cable which is fucking BOMB battery cables as its so flexible!!! also oil, grease and gas resistant i am not going in depth on this part big copper cable Crimp fittings and a cable anvil looking thing i don't know its name... he makes kits and shit mostly for jeeps but will make whatever you need if you got a length spec. and know the ends needed
he used this type of cable
http://order.waytekwire.com/productd...ED%20100%20FT/
85 Sabre ( 4 wire solonoid connector)
we ended up taking
threes 3 power wires that merge for gauges and are always hot leads ( 2 REd/White leads) 1 solid Red lead
take these splice together ( always hot leads )
then wire a fuse holder ( i used Delphi weather proof holders)
to the battery + terminal on the solenoid with a 5/16-3/8 ring terminal the other end goes and is spliced into the hot leads.
next prep your starter power cable( i used my stock one but i had to cut off the end and replace it with a 5/16 ring terminal (6 Gauge) i left the stock cable because without removing the starter and doing an oil change in the process i cannot remove the other end of the cable
next part take you're Wring diagram for your solenoid note which terminals for what function ( there's four on the solenoid i used and a diagram in the box with it ) one for Battery +, one for starter a coil hot lead(unused here) and a trigger lead ( to activate the starter)
now my bike has 2 other wires left we haven't got to yet A solenoid ground ( clutch side stand switch ect.)( green red stripe) now you don't have to absolutely use it but i have to as with the case grounding to frame the gear position sender stopped working and displays neutral all the time on my bike you might not have this problem depending on how factory wired it ( the ford solonoid uses case grounding so beware!!!!!)
i used solid green for this as i do not have striped wire around.
the other wire is the solenoid trigger lead mines yellow red stripe stock but as i cant find red/yellow stripped wire i used yellow for it you extend this and hook it up to your trigger terminal on the solenoid
now all that's left is o hook up to you're battery cable from the positive post to the solenoid input lead and test it out
now i had to move mine about 8 inches from the stock location as its just too damn big to fit there so all wires were extended except the
starter lead i removed my bikes stock toolbox and coolant tank to free the space btw
BIG Red lead is from Battery +
Small Red leads go to the always hot leads for ignition and stuff like that
Green Lead Starter solenoid Ground( goes through gear position and clutch switch on mine) Remember to isolate the mounting tabs and casing if its wired similar to mine
Yellow is the Starter Trigger lead extended from the main wiring harness
the Big Black wire is to the Starter its the original Oem Cable with a new end fitting crimped on
and before i get a bunch of shit iam going to work on tidying this up ovet the next week !!!
lynchingacers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived lynchingacers!
Old Streetfighter Motorcycle Forum Post 08-29-2011, 01:29 AM   #2
lynchingacers
V-4 for 4 life
Flip Offs: 9
Default Re: my bike finally starts itself...
damm i might need to rename this
This user High Fived lynchingacers!
Old Streetfighter Motorcycle Forum Post 09-05-2011, 10:35 PM   #3
lynchingacers
V-4 for 4 life
Flip Offs: 9
Can a mod move this to The electrical Fabrication section might be better there!!
Old Streetfighter Motorcycle Forum Post 09-05-2011, 11:21 PM   #4
Poopie
GOOROO of da POO POO
Poopie's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:37 PM
Flip Offs: 132
Flipped Off 91 Times in 61 Posts
Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!Poopie is an amazingly helpful member with a good attitude!
I'm reading, but not fully understanding what the hell is going on here....?
Is it like a clap-on starter???
“When the game is over, the king and the pawn go into the same box”
EL RoY Build
EL RoY Discussion
Chickamauga Warhorse Build
Chickamauga Warhorse (discussion)
Originally Posted by GDogg007
If I fuck this up bear with me. I am on some serious pain meds for kidney stones and flying like a mofo here.
Poopie is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-06-2011, 05:28 PM   #5
Tbird232ci
Fighterer
Tbird232ci's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:37 PM
Flip Offs: 42
Tbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to beholdTbird232ci is a splendid one to behold
It using a readily available Ford solenoid, and replacing the expensive, factory solenoid.
1983 KZ550 LTD
Nothing is true. Everything is permitted.
Tbird232ci is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Tbird232ci!
Old Streetfighter Motorcycle Forum Post 09-07-2011, 03:48 AM   #6
lynchingacers
V-4 for 4 life
Flip Offs: 9
basically what he said^^
is there any way i can make it a bit easier to understand?
i tried to write it as detailed as i could and tried to make it understandable
Old Streetfighter Motorcycle Forum Post 09-07-2011, 08:22 AM   #7
Kaos
SHOWUSYATITS
Kaos's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:07 AM
Flip Offs: 71
Flipped Off 59 Times in 47 Posts
Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!Kaos is an amazingly helpful member with a good attitude!
Excellent write up mate! You just fightered your starter circuit! Lol, that's great for older bikes that may not have starter solenoids available new....
I think the confusing thing was the title lol, I half expected to read a remote start or rfid thread...
Originally Posted by jaybuilt
...i have siad it before do what you realy want and do it today above all have your share of fun causc you will damn shure have your share of the other.
CUSTOM FIGHTERS FOR LIFE!
Kaos is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Kaos!
Old Streetfighter Motorcycle Forum Post 09-07-2011, 08:33 AM   #8
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 596
Flipped Off 1,311 Times in 703 Posts
ROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robboROBBO must be robbo
Fighter of the Month Fighter of the Month Supporter of the Streetfighter Build for Charity
Good work mate ,good lint ta WAYTEK as well .
Reppadoodledoo fer you !
ROBBO' 2009
This user High Fived ROBBO!
Old Streetfighter Motorcycle Forum Post 09-07-2011, 11:47 AM   #9
lynchingacers
V-4 for 4 life
Flip Offs: 9
wrote it kinda late and dod good on it just didint think out the title very well
Old Streetfighter Motorcycle Forum Post 09-07-2011, 10:56 PM   #10
929_adam
5 years in BOP 4 class D
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 497
Flipped Off 165 Times in 131 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
bump for mving purposes
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
customfighters.com streetfighter forum
FOH CYCLE FAB
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived 929_adam!
Thank you for viewing starter solenoid swap in the Electrical and Lights section of our streetfighter motorcycle forum. I hope you found it useful!
Electrical and Lights - starter solenoid swap on Custom Fighters Streetfighter Motorcycle Forum
