Question about makeing a fiberglass fender - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Paint and Bodywork
Paint and Bodywork Anything to do with fabricating bodywork, composites, prep and paint work goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Question about makeing a fiberglass fender
Old Streetfighter Motorcycle Forum Post 03-09-2012, 04:49 AM   #1
Racing Geek
lb/hp is what it's about!
Racing Geek's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:20 PM
Flip Offs: 164
Flipped Off 74 Times in 65 Posts
Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!Racing Geek is an amazingly helpful member with a good attitude!
Scavenger Hunt
Default Question about makeing a fiberglass fender
I was thinking a fender like in the photo below would look good on my build but I'm having trouble thinking of how to mount it since I want it to maintain a set distance from the tire at all times. This would mean making it adjustable so the gap doesn't change when the chain tension is adjusted. I would rather not run struts all the way back to the axle for aesthetic reasons. Any ideas?
2017 Build-off project: CT125 -- Ugly Duckling (don't post in this one)
2017 Build-off discussion: CT125 -- Ugly Duckling
Racing Geek is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-09-2012, 12:14 PM   #2
Fight Everything
Rollin hard in Wiscompton
Fight Everything's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 53
Flipped Off 40 Times in 30 Posts
Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!Fight Everything is an amazingly helpful member with a good attitude!
Default Re: Question about makeing a fiberglass fender
Quickest thing I can think of is to shape a couple pieces of rebar or similar. Weld tabs to mount them to the swingarm up front, shape them to run along the sides of the tire and kick up a little at the back (give a little more clearance at the edge of the fender)
Fight Everything is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-09-2012, 12:43 PM   #3
thaOrleanyte
Jarhead Supreme
thaOrleanyte's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 699
Flipped Off 454 Times in 180 Posts
thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!thaOrleanyte is an amazingly helpful member with a good attitude!
What about a loop with small diameter metal bar. Maybe even glass the bar in.
thaOrleanyte is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived thaOrleanyte!
Old Streetfighter Motorcycle Forum Post 03-09-2012, 11:55 PM   #4
Racing Geek
Flip Offs: 164
Scavenger Hunt
I've sketched up a modified version of those two. It may be easier to make the first one from steel and other ones from fiberglass.
How big of a gap do you think there should be between the fender and tire? 1/2" seem right?
EDIT:
Another idea I just had is to use a stainless steel mesh as a core. When making the fender use a couple layers of fiberglass, then place the mesh, and then then a couple more layers of fiberglass. I wonder how that would hold up to the vibrations and bumps.
Old Streetfighter Motorcycle Forum Post 03-10-2012, 12:29 AM   #5
thaOrleanyte
Jarhead Supreme
Flip Offs: 699
carbon fiber? I dont know much that would take (or cost), but it may not be a budget buster if you're efficient.
Thank you for viewing Question about makeing a fiberglass fender in the Paint and Bodywork section of our streetfighter motorcycle forum. I hope you found it useful!
Paint and Bodywork - Question about makeing a fiberglass fender on Custom Fighters Streetfighter Motorcycle Forum
