| DIY A how to section for the members, by the members! |
Thread Tools |
#21 |
42
Senior Fighterer
Local Time: 04:48 AM
Flip Offs: 1
You inspired me to make some glass stuff, A tail for my blade. I did it foam-core style just wrapping over a foam piece that then gets stuck inside. I didn't have any of the foam we make downhill boards out of so i used some random shit and the poly resin is eating it. I hope it doesnt turn out like shit.
Adventurer by trade, Pikey by circumstance. |
| Advertisement | |
These advertisements only appear for guests, register now for free to remove these ads! |
| Sponsored Links | |||
Advertisement | |||
#22 |
Function IS Form
Gotta put some shit inbetween the glass and the foam to keep it from getting eaten!
"Hey! Don't you bad mouth this country. Compared to the rest of the third world, we're doing great." -Moe Syzlak |
#23 |
is not your fucking bro
Local Time: 07:48 AM
Flip Offs: 75
Flipped Off 53 Times in 24 Posts
do your foam then cover the foam in bondo. firberglass doesnt eat bondo.
#24 |
Function IS Form
Or tinfoil
#25 |
Flip Offs: 75
very true. but with bondo you can sand it smooth and get a smooth surface. i guess you can with tinfoil if you smash it enough. nemman used that metal duct tape.
"Instead of using plastic I covered everything with painters tape then I covered that with metal duct tape, any hardware store will have those. Then I waxed the metal tape so the fiberglass resin wouldn't stick. I actually used EZPOXY because you can work with it longer before it sets up. The metal tape is easy to form and holds it's shape so you can push it into tight corners and it will stay there. The blue painters tape does a good job of protecting the part. You could take a shape off a painted part and not damage it doing it this way. The downside is if you want to use the tape side you won't have a smooth finish. Using resin to repair bare areas is a great idea. It would also fill any pinholes that bondo wouldn't get into. I usually buy all my cloth and resin from Wicks Aircraft www.wicksaircraft.com"
#26 | |
Perpetual Project
When I used a foam mould I wrapped it in saran wrap before laying down the resin. Honestly that method sucked. But it was a first attempt so I'm sure if I put more thought into it I could pull it off better now. Tin foil might be a better option depending on the shape of the mould. It would work well for getting a "rough shape" plug made if nothing else, then you could add to it to get your finished piece. Like some of my original posts said, theres lots of ways to do fiberglass work, this is just one variation. Built Not Bought![]() The project never ends... ![]() My B12 Build: http://www.customfighters.com/forums...=Candymans+B12 R6 Build: http://www.customfighters.com/forums...ad.php?t=51178 My Fighters: 98 Bandit 1200 - 05 ZZR 600 - 89 Ninja 250 - 84 GS750E |
#27 |
Function IS Form
Yeah I use that metallic duct tape when I'm making race fairings fit better, works like a charm
#28 | |
Naked from the waste down
Are you going to eventually make your own body work for your fighter? Mr. April 07 - FOTM Champion. |
#29 | |
Function IS Form
Yeah, I'm gonna make a tail and I'm going to (heavily) modify a stock fiberglass upper, and I'm going to make a race bellypan. "Hey! Don't you bad mouth this country. Compared to the rest of the third world, we're doing great." -Moe Syzlak |
#30 | ||
fighter transplant in NC
hey candyman, I'd be interested in buying a solo seat cowl from yah. my little bro has his 250 and I think he would love one. any idea on how much they will cost?
| Bookmarks |
| Thread Tools | |
