FZ1 Engine Swap Ideas - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Engine Swaps
Engine Swaps Engine Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > FZ1 Engine Swap Ideas
Old Streetfighter Motorcycle Forum Post 06-18-2013, 11:49 AM   #1
Wonko
Mono-thingy-guy
Noobie
Local Time: 03:44 AM
Wonko is a NOOB
Default FZ1 Engine Swap Ideas
Long time lurker - great site here! I've got a 2003 FZ1 that I'd like to do something a little different to. My first plan was to swap a gen 2 fuel injected engine into it in place of the carbureted one. Now, I have come across a 2007 Aprilia Tuono that was lightly wrecked (front wheel bent and tail cracked) and I've kicked around putting that engine in the FZ1 and turn it into kind of a cafe racer type. Any thoughts or input on which option might be more fun? Obviously frame modification will be required with both choices which is no big deal. The gen 2 FZ1 engine will be way faster, but the Tuono engine will be a bit badasser! What would others prefer to ride?
Wonko is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-18-2013, 12:06 PM   #2
DecepticonDon
Elbow Grease is Cheap
DecepticonDon's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:44 AM
Flip Offs: 301
Flipped Off 143 Times in 38 Posts
DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!DecepticonDon is an amazingly helpful member with a good attitude!
Default Re: FZ1 Engine Swap Ideas
that would be a pretty big undertaking.
check out this thread. It's a VTR1000 engine in a Bandit frame. very similar in both regards to a Tuono engine in your FZ1 frame.
http://www.customfighters.com/forums...ad.php?t=53866
FZ1 engine is wider, so fitting the Tuono engine would require some extensive frame modifications.
Also the Tuono engine is a stressed member, whereas the FZ1 engine sits in a cradle frame. You will have to strengthen the frame to overcome this. "stressed member" means the engine/mounting points acts as part of the frame. More detail on the subject can be had with an internet search.
Being a V-twin, the Tuono engine is longer front to back. you'd probably have to mod the frame and possibly the tank to fit.
Originally Posted by robsroadeater View Post
dont want no skanky slagbag hangin offa yer short arm mate
Project: Daytona 675
Operation: Kwak Attack
1991 Tidecraft B.O.A.T. build
DecepticonDon is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-18-2013, 12:17 PM   #3
Wonko
Mono-thingy-guy
Noobie
Wonko is a NOOB
I've thought about the stressed member situation a bit. The gen 2 FZ1 engine is also a stressed member. I've considered turning the top portion of the frame into a trellis type, and cutting off the down tubes that cradle the gen 1 engine. This would also be done for the Tuono engine, and the needed strengthening pieces would be added accordingly. I'm also concerned about the narrow v-twin engine looking retarded in the wider frame. I wonder if it might be better to look at a narrow frame for that engine, something like a CB750 frame or similar. Also, thanks for the link! I've looked at that thread a number of times and am quite inspired by it.
This user High Fived Wonko!
Old Streetfighter Motorcycle Forum Post 06-18-2013, 06:42 PM   #4
blensen
blensen's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:44 AM
Flip Offs: 12
Flipped Off 4 Times in 4 Posts
blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!
Fundamental misunderstanding of what a stressed member engine means. Stressed member means that the part is fundamental to the strength and rigidity of the frame. Look at the new Panigale for an extreme example.
The engine is not a stressed member in the first-gen FZ1, meaning it isn't a major factor in the strength of the frame, which is typical for cradle-frame bikes.
The FZ1's frame would almost certainly need to be modified to adequately support the Tuono engine, but the Tuono engine will not be a stressed member with this swap unless there is a fundamental redesign of the frame.
Originally Posted by ultimate fighter
my throttle response was as fast as an old man with parkinsons trying to put his keys in the door
blensen is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-18-2013, 06:48 PM   #5
Wonko
Mono-thingy-guy
Noobie
Wonko is a NOOB
No redesigning of the frame will take place, just adding to it for rigidity. I imagine it will be a lot like the Necromorph. Thanks for the replies.
Old Streetfighter Motorcycle Forum Post 06-18-2013, 07:41 PM   #6
DecepticonDon
Flip Offs: 301
Originally Posted by blensen View Post
Fundamental misunderstanding of what a stressed member engine means. Stressed member means that the part is fundamental to the strength and rigidity of the frame. .
I don't have a fundamental misunderstanding, but might just not know how to express is concisely. But it does kind of act like part of the frame. I think you're splitting hairs.
Old Streetfighter Motorcycle Forum Post 06-18-2013, 07:54 PM   #7
blensen
Flip Offs: 12
Ok then instead of being wrong you were unintentionally misleading. Either way, there's a big difference between the engine sitting in the frame, and the engine BEING the frame. Hardly splitting hairs.
Old Streetfighter Motorcycle Forum Post 06-18-2013, 09:28 PM   #8
Notyetafighter
Senior Member
Fighterer
Local Time: 09:14 PM
Flip Offs: 3
Notyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to allNotyetafighter is a name known to all
Cross plane R1 motor. Should be pretty simple to swap I'm guessing.
Notyetafighter is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-19-2013, 06:57 AM   #9
GreY2231
GreY2231's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:44 PM
Flip Offs: 2
GreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to beholdGreY2231 is a splendid one to behold
Nope. That engine wont even fit in the new FZ1. shoot the r1 engine that is the same as the fz1 won't even fit. I work at a yamaha dealer. And have done lots if measuring fir just this. It would still need some fabricated brackets. The engine in the FZS1000 (the bike in discussion) comes from the yzf-1000r thunder ace I would check out swapping parts from it like cams and carbs or FCR's fir more umph. The EFI is a lot less user friendly to add anything you need some kind of tuning box (power commander) where as xarbs you just need a jet kit. Plus fcr's or mikuni's TM/HSR series are badass. Just my $.02
GreY2231 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-19-2013, 08:52 AM   #10
Wonko
Mono-thingy-guy
Noobie
Wonko is a NOOB
Thanks for the replies, guys. With any of the above mentioned swaps, there would certainly have to be frame modifications. If swapping in the gen 2 FZ1 engine, it would be a lot less hassle (in the scheme of things) since then engines are almost the same. I realize they aren't really the same, though. My buddy had an '01 FZ1 and had continuous problems with his carbs. This is one reason why, for me, fuel injection is the way to go. I know that not all carb'd FZ1's have problems, but it's unfortunate that my first exposure to this bike was that situation. I'm completely fine setting up the fuel injection and tuning things with the gen 2 engine. On a side note, I picked up the '07 Tuono last night and will be doing a bunch of measuring to see what can be done. After that, it looks like I'll have an '07 Tuono to part out.
Thank you for viewing FZ1 Engine Swap Ideas in the Engine Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Engine Swaps - FZ1 Engine Swap Ideas on Custom Fighters Streetfighter Motorcycle Forum
