Dimestak - 1988 xlh883 Sportster - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2018 Winter Buildoff > Bike Build Threads
CustomFighters.com Streetfighter Motorcycle Forum > Dimestak - 1988 xlh883 Sportster
Old Streetfighter Motorcycle Forum Post 11-07-2017, 09:35 PM   #1
DimestaK
DimestaK's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:00 AM
Flip Offs: 2
DimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud ofDimestaK has much to be proud of
Default Dimestak - 1988 xlh883 Sportster
Figure I'll join in with this years buildoff instead of just watching. See where this goes, have some fun, and maybe finish.
Here is the progress up to current date and time
And the good ole date pic as she sits
[IMG][/IMG]
DimestaK is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-08-2017, 12:12 PM   #2
DimestaK
Flip Offs: 2
Default Re: Dimestak - 1988 xlh883 Sportster
Paid $1500 for the bike originally. So far to date I've only spent $31 out of my pocket other than the initial price. Sold the stock sporty take off parts to get me to this point. Most the other bits were just sitting around the shop collecting dust
Cost list as of today
Bike $1500
Front motor mounts $28
1.250 tube caps $10
04 gsxr1000 rear caliper $28
04 gsx750f rear rim $50
gsxf cush drive $15
TL1000s top triple $20
Fox MTB shock $80
Old Streetfighter Motorcycle Forum Post 11-10-2017, 02:14 PM   #3
DimestaK
Flip Offs: 2
Tires came in yesterday. Need to mount them still. Wound up going with the Battlax. Never ran em so we'll see how they go
And started on making the handle bar. Piece of 1" tube I threw some knurl on real quick. Need to throw some bends in it and then step it down still
These people High Fived DimestaK!
Old Streetfighter Motorcycle Forum Post 11-11-2017, 02:25 PM   #4
DimestaK
Flip Offs: 2
Tires mounted and under the bike now. Tossed the tank on just for a visual
Old Streetfighter Motorcycle Forum Post 11-14-2017, 10:24 PM   #5
DimestaK
Flip Offs: 2
Been working on the handlebar this week, bit by bit. Threw a couple degrees bend in each side
Then started working on the ends. Needed to step down from the 1" to .875". Turned a piece up tube down to fit the main bar and cut plugs for the ends
Plugs welded in and cleaned up, drilled for bar end mirrors ( need to tap ) and switch housing location holes drilled
Old Streetfighter Motorcycle Forum Post 11-15-2017, 09:17 PM   #6
DimestaK
Flip Offs: 2
Fitted the bar ends with some switches, Busa masters and CRG levers
And threw them in the main bar on the bike
Gotta sort some angles so I can final weld the bars into 1 unit. Wires will be run thru the bar eventually and down thru the stem for a mostly hidden look. At least that's the plan at the moment.
Set of TL calipers up front also. Going to need to order some brake lines
Old Streetfighter Motorcycle Forum Post 11-18-2017, 10:09 PM   #7
DimestaK
Flip Offs: 2
Been needing to sort the rear axle adjustment out. Lots of things needing to be done out back but cant because this bits not done. Racked my brain for a nifty idea and scoured the net for pics. In the end I decided to go simple and just use a bolt with a threaded bung I'll weld to the side of the axle plate. Did spring a few coins though and got these instead of a plain bolt
One thing that I was dead set on for this bike was the ability to carry a passenger. Means I needed a fender of some sort so I ordered that while I was spending. Came from the same place and got me free shipping so why not. No where close to ready for it yet, but threw it up for ideas. I highly doubt I'll use the entire length of it as its a bit much. May chop some up and make a front fender also.
The curve of the fender is about spot on with this tire. I was really worried about that and measured a ton, but knew it would be closer than any attempt I would be able to make
Old Streetfighter Motorcycle Forum Post 11-20-2017, 08:08 PM   #8
DimestaK
Flip Offs: 2
Threaded bungs done for the adjusters. I'll try and get them glued on this weekend if I have time
Old Streetfighter Motorcycle Forum Post 11-26-2017, 11:31 AM   #9
DimestaK
Flip Offs: 2
Needed to open the axle slots from .750 to 20mm. Simple job with a carbide burr. Also got the adjuster bungs tacked on. I'll fully weld them later on when the frame gets dissasembled
Old Streetfighter Motorcycle Forum Post 11-27-2017, 09:07 PM   #10
DimestaK
Flip Offs: 2
Originally I hoped on running the rear caliper somewhere like so with a couple solid mounts right off the tubes
The sportster rotor was quite large ( 11.5" diameter ) and it might have worked. But this rotor isn't and so its going to hang under something like so. Without the fancy yellow tape of course
Thank you for viewing Dimestak - 1988 xlh883 Sportster in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - Dimestak - 1988 xlh883 Sportster on Custom Fighters Streetfighter Motorcycle Forum
