DIY - Stubby your Exhaust. Not 56K Friendly. - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > DIY - Stubby your Exhaust. Not 56K Friendly.
Old Streetfighter Motorcycle Forum Post 03-15-2009, 03:00 PM   #1
Punkbrad
good with tools
Punkbrad's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:26 PM
Punkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of lightPunkbrad is a glorious beacon of light
Default DIY - Stubby your Exhaust. Not 56K Friendly.
My SV650's Leo Vinci Aluminum slip on looks like shite from the sea-air and its a little corroded and crusty looking. I decided to strip it down and paint it black, but then I figured I might as well chop it a bit too.
Heres my DIY - I will finish the sanding and paint and post it here later today.
All work was done on my patio with a dremmel and a cordless drill - not to tuff at all.... I dont have the luxury of a garage and the shop is closed today.. fuck it, I'll figure this out!
Find the length you want the pipe, and mark it - i used a fine point sharpie.
My pipe I wanted to be 10" so thats where I marked it.
Carefully go around the can marking at the proper length, when done, use tape to circle the can at your marks, this will help guide the cut.
Next I drilled out the rivets to get the endcap and slipon cap off.
Rivets removed, band removed.
There is a silicone bead around the can, so I cut away as much as possible.
Take a punch or small screwdriver and punch the rivets into the can.
Time to make the cut - go slow and be careful. use eye protection.
Cut is complete thru the aluminum.
Use a razer blade to cut the packing away and get it free from the baffle.
Once you are thru the packing, remove the end cap.
Take the pipe end cap off, this is the piece I am tossing,
unless one of you here want a 6" can..?
I pulled the slipon cap out and the baffle is welded to this so becareful not to bend or dislodge it from the slipon cap.
Next is to remove the packign from the part I want to keep.
I pushed my hand between the can and the wrap and it popped right out.
Next I cut the steel-wool wrapping around the baffle core to length.
Mark the baffle core to cut to length. be careful, measure twice, cut once.
I used a fiber-reinforced cutting wheel for my dremmel tool,
it cut the can and the baffle core using only 3 discs.
Baffle core is cut to length.
A quick test fit of the caps & baffle core and can to see if it all fits up right.
Looks pretty fuckin good to me mate!
Next is marking the can for the rivet holes on the cut side.
I put the endcap in and made a line as to center,
then i put the band on and made the cross lines to show center point of the hole.
NEXT UP:
DRILL ENDCAP HOLES
SAND IT
PAINT IT
PACK IT
RIVET IT BACK TO LIFT
VIOLA!~
I'm not anti-social, society is anti-me.
90 347 1216: http://www.customfighters.com/forums...ad.php?t=18866
Punkbrad is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-15-2009, 05:39 PM   #2
Punkbrad
good with tools
Default Re: DIY - Stubby your Exhaust. Not 56K Friendly.
Drill the holes for the rivets to hold on the end-caps
Chamfer and file all the burrs from the holes, and also the cut end of the can.
Test fit to make sure the rivets are the right size.
Test fit to make sure that ALL the rivets will go in snugly.
When I bought the pipe it came with a rivet-on badge, so why not put it on too?
Im using VHT Very High Temperature header coating in Satin Black.
After sanding (which I didnt take pix of cuz i was covered in aluminum dust...
Apply even coats of paint and wait between coats for each coat to dry - do not rush this part.
People always tend to rush the painting and it will come out like shite 99% of the time if so.
Between coats make a sandwich.
IMPORTANT- if makign a sandwich have salt and vinegar chips and a Dr. Pepper.
While eating sandwich watch South Park or read the new issue of Streetfighter Mag.
Apply more coats, waiting patiently between coats.
Last Coat - all done and baked.
Note - You cant just bake this in the over in the house. It will stink the house up and your wife will yell.
I took a large toaster oven outside and baked there per the directions on the back of the spray can.
Put the baffle steel wool back on.
NOTE - you can do this a few different ways. I found it easier to put the steel wool on,
then wrap the steel wool with the packing. trying to stuff the baffle thru the packing in the can
may prove to be very difficult as it mashes the packing up on the inside of the can.
First try, put the packing in first, then do it differently.
There are no other pics of the packing process as my hands were very greasy and dirty..
I've never worked with Rivets before. Its not hard. However I could not find stainless steel rivets
anywhere today. i conceded to buying aluminum and they seem to hold fine.
My worry is over time they can change color from the heat and/or become loose from the vibrations
causing wear on them. Either way, if those things happen its a long way off.
Put the end cap on the can and slide if over the baffle on the inside so its all snug
Rivet the strap back on, being careful to pre-fit the rivets so they all go in and
none of it is cock-eyed.
Put the slip-on cap into place and then strap and rivet just as the end-cap was done.
Rivet on the sweet Leo Vinci badge and I'm all done - fuck yeah!
See the length of the can now, as I wanted it 10" short. I will re-bake the can now that
everything is in place, and it shoulr work just fine.
i scratched the can with a rivet nail so i had to touch that part of the paint up.
once the paint is totally cured, it is a ceramic paint that will be hard as fuck.
It should be pretty resistant to chips and scratches.
Now I have to put my SV's engine back together and get it on the road so i can put the
new stubby slipon to the test.
Hope you liked it - this is rep-whoring... thanks!
~fin~
Old Streetfighter Motorcycle Forum Post 03-15-2009, 06:47 PM   #3
shotgun
Fast ZX-12R
shotgun's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:26 PM
Flip Offs: 132
Flipped Off 121 Times in 103 Posts
shotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on hereshotgun spends too much time on here
Supporter of the Streetfighter Build for Charity Fighter of the Month
You just made me hungry now I have to go make a sandwich.
shotgun is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived shotgun!
Old Streetfighter Motorcycle Forum Post 03-15-2009, 10:41 PM   #4
Fathead_03
Flashburnt
Fathead_03's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 145
Flipped Off 35 Times in 30 Posts
Fathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud ofFathead_03 has much to be proud of
I liked the rivets before you used them, with the spikes out the back!
Build Threads
2009 Winter Buildoff CBR Build Thread
After-Buildoff CBR Build Thread
CB750 Hardtail Bobber Build "Old's Cool"
Originally Posted by Denvgasm View Post
someone died ban everything
Originally Posted by vbwstripes View Post
I like carbon peaking through the paint. It's like side boob.
Fathead_03 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-16-2009, 12:54 AM   #5
Truckinduc
I been fightin' gravity
Truckinduc's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:26 PM
Flip Offs: 6
Flipped Off 21 Times in 18 Posts
Truckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond reputeTruckinduc has a reputation beyond repute
Winter Buildoff Winner Supporter of the Streetfighter Build for Charity
good writeup
Nice looking can now
Truckinduc is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-16-2009, 12:55 AM   #6
929_adam
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 501
Flipped Off 166 Times in 132 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
great work PB!
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
AFF.COM
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-16-2009, 12:55 AM   #7
Punkbrad
good with tools
Originally Posted by Truckinduc View Post
good writeup
he means the exhaust ya...
Originally Posted by 929_adam View Post
great work PB!
thanks man.
honestly, ive never been one to just fuck with something for the sake of fuckign with it, but i thought, fuck it.
the only real pain in the ass was the re-packing. to re-pack it i had to unroll it and re-wrap the steel wool baffle sleeve - it was too fat with all the original material, so i had to remove some packign material to make the wrap a little less thick - i couldnt snap pix cuz i had that itchy resin-coated shit everywhere...
it came out sweet tho- im happy widdit...
Old Streetfighter Motorcycle Forum Post 03-16-2009, 12:58 AM   #8
CK 187
CAPTAIN AWESOMEŽ
CK 187's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 631
Flipped Off 470 Times in 171 Posts
CK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too muchCK 187 plays with their repper too much
Default Medal Supporter of the Streetfighter Build for Charity Supporter of the Streetfighter Build for Charity
Looks good. I like the black on aluminum combo.
CK 187 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-16-2009, 09:42 AM   #9
Punkbrad
good with tools
thanks CK, it wasnt too hard, and i was just messin with it for the sake of messin with somethin - didnt come out too bad -
thanks all for your compliments....
Old Streetfighter Motorcycle Forum Post 03-19-2009, 09:27 AM   #10
Punkbrad
good with tools
Heres a photochop of how it will look with the regular high mount setup.
stay tuned for the 08 GSXR stubby mount look..
Thank you for viewing DIY - Stubby your Exhaust. Not 56K Friendly. in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - DIY - Stubby your Exhaust.  Not 56K Friendly. on Custom Fighters Streetfighter Motorcycle Forum
