GOLDEN TRASH 78 KZ650 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > GOLDEN TRASH 78 KZ650
Old Streetfighter Motorcycle Forum Post 04-24-2019, 09:08 AM   #1
rabies
time is running out......
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:30 AM
Flip Offs: 1,383
Flipped Off 37 Times in 33 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
Default GOLDEN TRASH 78 KZ650
I luv me a kz. got it cheapish. he said it ran but wouldn't.
its clapped out bad. but I don't need much of the bikes stuff.
ders gold in der trash son
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived rabies!
Old Streetfighter Motorcycle Forum Post 04-24-2019, 09:13 AM   #2
rabies
Flip Offs: 1,383
Default Re: GOLDEN TRASH 78 KZ650
I got it home and did a complete-ish tear down
chop chop chop
kik only
Old Streetfighter Motorcycle Forum Post 04-24-2019, 09:21 AM   #3
rabies
Flip Offs: 1,383
took these off right away.
tried to get motor started. it has compression. but no kick over.
plugs were black but usable.
1 plug wire was busted off.
2 vacuum plugs were off the carbs.
1 throttle push cable was off and throttle didn't return.
wiring is rigged to hookup a power wire and kik over(no key)
carb boots were cracked at the manifold.
carbs opened and closed fine though. very dirty.
new battery was in it.
starter makes funny noise. was given another starter. not the same :/
coil is cracked.
rear tire is completely worn out as if burnout was its ending
rectifier was fried.
should have pressure washed before bringing it home
as she sits
ordering stem bearings and ninja stem as kz stem is also 9".
NEW plugs, coils, rectifier, taillight, tire etc.
These people High Fived rabies!
Old Streetfighter Motorcycle Forum Post 04-24-2019, 10:57 AM   #4
MDM
Procrastinator
MDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant futureMDM has a brilliant future
Are you going to keep the standard Z styling? ANd just uprate the rolling gear?
MDM is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-24-2019, 12:58 PM   #5
rabies
Flip Offs: 1,383
only Z part will be motor and frame piece that surrounds motor(cradle)
I like the wire wheel plus it will mismatch front wheel(I like that)
but its drum brake.
most likely swapping out swingarm for wider tire, mono shock mount and disc brake.
I was thinking of doing a double center shock. so use 2 softer shocks if used together on lightened up bike?
il post an idea. but pinterest doesn't work on my work computer.
painting forks and frame. might do frame over the winter. powder coat a flat bronze color.
would like to introduce some wood to the bike somewhere
Old Streetfighter Motorcycle Forum Post 04-24-2019, 01:07 PM   #6
Local Time: 02:30 AM
Flipped Off 116 Times in 103 Posts
Put the V4 engine in the Kwak frame, realize that drum brakes are fine when properly set up, build a flat tracker/ brat type seat thing and ride the fuck out of this one.
shinyribs is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-24-2019, 02:51 PM   #7
Local Time: 09:30 AM
Flipped Off 39 Times in 38 Posts
Someone mentioned v4?
This user High Fived rex_saugerty!
Old Streetfighter Motorcycle Forum Post 04-24-2019, 03:09 PM   #8
rabies
Flip Offs: 1,383
Yaw Saw. 83 magna. v45
also have a thread on it
Old Streetfighter Motorcycle Forum Post 04-25-2019, 03:03 PM   #9
XxGRYMMxX
Breaking shit...
XxGRYMMxX's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 8
Flipped Off 13 Times in 10 Posts
XxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on here
cool little bike. watching to see whats up.
They can ban, outlaw, and restrict whatever they please. I'll keep doing whatever the fuck I'm doing, because I don't really give a shit. The only thing that will change is that I'll be breaking their made up bullshit rules while doing it, and I'm comfortable with that.
My Build http://www.customfighters.com/forums...d.php?t=118649
XxGRYMMxX is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-25-2019, 07:39 PM   #10
My dad has a ‘78 650 C model. Has about 11k miles and is pretty unmolested. I love the tails on those....it’s a shame you hacked it off but I know that it’ll be for a good reason.
‘74 Kawasaki H1-500
‘76 Kawasaki Kz900 Stripfighter
‘78 Kawasaki Kz1000
‘83 Kawasaki Gpz750 (Turbo Converted)
Streetfighterkz is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing GOLDEN TRASH 78 KZ650 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - GOLDEN TRASH 78 KZ650 on Custom Fighters Streetfighter Motorcycle Forum
