SV1000Reptilia - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SV1000Reptilia
Old Streetfighter Motorcycle Forum Post 10-02-2019, 07:34 PM   #21
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:53 AM
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Month
Default Re: SV1000Reptilia
I've seen those subframes before I've order mine
I thoght it was like the others for race use
So that's an other one option to consider. Thank you hrdy
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 10-04-2019, 03:27 AM   #22
Local Time: 03:53 PM
Flip Offs: 189
Subscribed. Looking forward to more updates.
This user High Fived Casper!
Old Streetfighter Motorcycle Forum Post 10-04-2019, 05:28 PM   #23
Local Time: 06:53 PM
Originally Posted by Leroy View Post
In my early plans, a fuel tank in the suframe and a fiberglass tank cover at the original place was included.
I want to shave some weight but, that subframe change a litle bit my plans.
I'm working on it and I'm going to fit that fooking panigale tail
690/701 fuel cell is the subframe, not a bad price if you could find one would make an intresting addition but not sure how you would work the tail unit over it
https://www.ebay.co.uk/itm/KTM-690-S...gAAOSwTm1dlgQH
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 10-04-2019, 07:29 PM   #24
Leroy
I have already decided to built a subframe from scratch. The plan is to build the fuell tank in it.
Of course that depending fron the volume of the tank, that it could fit in there.
I'm aiming for a tank with 10+ liters. Anything else with a smaler volume it won't work for me.
Of course every idea is welcome cause it will help me a lot. Thank you titan
Old Streetfighter Motorcycle Forum Post 10-05-2019, 03:26 PM   #25
Local Time: 04:53 PM
Flip Offs: 45
Fighter of the Year Fighter of the Month
Originally Posted by Junkie View Post
second, even done perfectly the welding weakens aluminum quite a bit.
Yes, but no, but yes.
Alum strength, regardless of alloy, is highly dependent on it's heat-treat level. This is the -T(n) in the alloy number, i.e. 6061-T6.
Welding alum will introduces a high heat cycle that will reduce temper to T0 at least in the heat-affected-zone or in the entire part depending on how hot the whole thing gets. So, there goes all your strength... until you re-temper it. Sending the part off for heat-treat after welding will return it to the desired T level.
These people High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 10-05-2019, 03:29 PM   #26
Flip Offs: 45
The rear seat tray will go to the bin cause I already have it.
Have you binned this bit yet? I'll buy it off ya if not.
Old Streetfighter Motorcycle Forum Post 10-05-2019, 03:35 PM   #27
Flip Offs: 45
Also on the subject of Pani subframes.
The 1199/1299 subby is cast alum, while the 899/959 versions are tubular steel at the cost of a few lbs.
There are also tubular alum as well as carbon versions available aftermarket.
In your application they're all interchangeable... if you for some reason end up using a Pani tank, you'll need the appropriate tank mount bracket to match the version the subframe is from. The baby Pani tanks are steel instead of alum and 1/3 or less the cost. 899/959 specific stuff is always going to be cheaper than 1199/1299 parts, bear this in mind when parts shopping.
This user High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 10-05-2019, 08:42 PM   #28
Leroy
Your right about it. I've found informations about heat treat at google but no one that could do it here in Greece.
Trying to find out the weight of the 899/959 subframe. It must be somewere in google.
PM me your address. I will send it to you. It wiil cost you the shipping fee.
Old Streetfighter Motorcycle Forum Post 10-05-2019, 11:24 PM   #29
Flip Offs: 45
Thanks man! Broke one of the fairing mounting tabs on mine in that crash a couple weeks ago.
Been a while since I looked but IIRC steel subframe is 7.75lbs, cast alum is a little over 4.
Old Streetfighter Motorcycle Forum Post 10-06-2019, 07:26 AM   #30
Leroy
7.75 libs isn't that heavy, compared to the SV subframe. I should check that out too.
Thank you for viewing SV1000Reptilia in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SV1000Reptilia on Custom Fighters Streetfighter Motorcycle Forum
