titans project "skip build" chat - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2020 Winter Build-off > 2020 Winter Build-off Discussion Threads
CustomFighters.com Streetfighter Motorcycle Forum > titans project "skip build" chat
Old Streetfighter Motorcycle Forum Post 11-01-2019, 07:46 AM   #1
Local Time: 08:20 PM
Default titans project "skip build" chat
happy to chat about, take advice, slag me off. what ever
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 11-02-2019, 04:57 AM   #2
Local Time: 04:20 AM
Flipped Off 40 Times in 39 Posts
Default Re: titans project "skip build" chat
fixed those crooked bends yet?
Old Streetfighter Motorcycle Forum Post 11-02-2019, 05:00 AM   #3
yes mate, it wasnt so bad once i cut them to length, and a bit of heat etc seems fine now. or at least not as noticable on the bike.
Old Streetfighter Motorcycle Forum Post 11-02-2019, 05:44 AM   #4
looked bad in one of pics you posted in thread, but that might be camera angle. was shitty on facebook tho
Old Streetfighter Motorcycle Forum Post 11-02-2019, 06:08 AM   #5
Think it was camera angle, may have been some movement from heat while welding that may have helped
Sent from my SM-G973F using Tapatalk
Old Streetfighter Motorcycle Forum Post 11-05-2019, 03:09 PM   #6
Local Time: 05:20 PM
regarding your welds, some (hopefully) constructive criticism: I suspect you aren't getting things as clean as they need to be for TIG to work well. I also suspect you're using a fairly long arc length.
IMO, for someone working on learning TIG, if you aren't dipping your electrode reasonably often your arc length is most likely too long.
These people High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 11-05-2019, 03:39 PM   #7
i have spent a lot of time grinding tunston i was definently not as close on the Gusset welds as i could have been but mainly down to position. i do plan on redressing them welds later. i think i was between 1-2mm of the surface but will try and get a bit closer.
i terms of cleaning up the metal, that has been my main focus here, every thing is getting, de greases, sanded - orbital in most cases but where needed the old flapper to to remove grim. its hardest on the old frame sections. lastly its getting wiped off with acetone and finally a clean SS wire brush just before welding..
very much still a work in progress on the tig front but appreciate the observations
Old Streetfighter Motorcycle Forum Post 11-05-2019, 03:46 PM   #8
In that case I'm surprised at all the oxidation on your welds. Are you running a gas lens? What size cup, what argon flow rate? Are you wiping your filler rod off too?
Old Streetfighter Motorcycle Forum Post 11-06-2019, 02:54 AM   #9
Standard set up so no gas lense. Using a size 7 cup, around 10-12ft/h ( this is probably the problem area as I need a better regulator) filler rods are all cleaned off before use, rubbed down with scotch bright.
Old Streetfighter Motorcycle Forum Post 11-06-2019, 07:43 AM   #10
makenzie71
Local Time: 07:20 PM
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Where are you guys getting these custom drop triples from? Is that cheaper than extending the forks?
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing titans project "skip build" chat in the 2020 Winter Build-off Discussion Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Discussion Threads - titans project "skip build" chat on Custom Fighters Streetfighter Motorcycle Forum
