My Big Build - Page 8 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > My Big Build
Old Streetfighter Motorcycle Forum Post 02-23-2017, 07:19 AM   #71
yantosh
Local Time: 05:23 PM
Flip Offs: 14
Default Re: My Big Build
Originally Posted by Gripen View Post
Question about the swingarm mount. Why build it this way? Why not just opening in the plate?
the inserts for the swingarm mounts can be removed and replaced raising or lowering the pivot point by 5mm either way, when combined with adjustable top shock mount, the adjustable dogbones and the adjustable offset yokes they will hopefully let me sort any handling issues
that's the plan anyway
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 02-23-2017, 07:28 AM   #72
yantosh
Flip Offs: 14
Originally Posted by Gazmo65 View Post
The notch to get to the engine mount and where the frame tube sits looks a little weak , would it not have been better to make it larger then notch the frame tube slide it over and weld around it , so as the plate sits in the the frame tube? This is not a criticism as there is no way I have the skills you have but just an observation, loving the build and keep the pictures coming.
those aren't the actual frame tubes, the frame tubes will be shaped to fit around the top of the side plate, the part of the side plate that has the notch in it is as much a guide for the rails as anything else, it wasn't initially in the design, I'm pretty confident that welding right round the lower tube to the side plate, then right round the top rail to the side plate then joining the 2 rails will be fine.
never fear tho, if I get that far and I'm not confident in it i'll re do it
Old Streetfighter Motorcycle Forum Post 02-23-2017, 01:52 PM   #73
Gazmo65
Fighter In Training
Gazmo65's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:23 PM
Gazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to allGazmo65 is a name known to all
Gazmo65 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-23-2017, 02:23 PM   #74
Gripen
Noobie
Gripen's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Gripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of lightGripen is a glorious beacon of light
Smart. Looking forward to see the adjustable shock mount.
Gripen is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-01-2017, 12:33 PM   #75
yantosh
Flip Offs: 14
redrew the mount, reckon it's nearer the mark, once both side plates are on i'll cut a trial template
friend turned a 24mm thread for me letting me start
got the first two flats cut at lunchtime today, then was able to pop it in the spark and cut the internal hex
the disc on the thread will end up as a trick locking nut
Old Streetfighter Motorcycle Forum Post 03-01-2017, 12:46 PM   #76
Smoker
BLACK BELT
Local Time: 09:23 AM
Flip Offs: 36
Nice work!
How did you cut the internal hex?
I've wanted to do that before, but the machine shop I use doesn't do "broaching".
Smoker is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-01-2017, 03:21 PM   #77
yantosh
Flip Offs: 14
spark erosion , by far the easiest way
Old Streetfighter Motorcycle Forum Post 03-02-2017, 03:46 AM   #78
Gripen
Noobie
Looks brilliant!Getting ideas for my mount.
This user High Fived Gripen!
Old Streetfighter Motorcycle Forum Post 03-03-2017, 03:54 PM   #79
yantosh
Flip Offs: 14
more pretty things
Old Streetfighter Motorcycle Forum Post 03-14-2017, 04:16 PM   #80
schlafen
Active Member
Fighter
schlafen's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
schlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of lightschlafen is a glorious beacon of light
What grade and thickness alloy tube are you using for the frame? I assume the lighter and stronger the better?!
Are you considering the final size of the frame as well ? Flexi pipe looks quite beefy.
Sent from my SM-G935F using Tapatalk
schlafen is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing My Big Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - My Big Build on Custom Fighters Streetfighter Motorcycle Forum
