My Big Build - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > My Big Build
Old Streetfighter Motorcycle Forum Post 12-23-2016, 06:46 PM   #31
yantosh
Local Time: 06:32 PM
Flip Offs: 14
Default Re: My Big Build
I am leaning towards leaving the bearing pockets in the neck undersize, then final boring them once the frame is 100% welded, that way I can be certain the steering stem and swingarm pivot are bob on
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 12-24-2016, 01:45 AM   #32
mcantar
Fuck it, let's do it live
Local Time: 11:32 AM
Flip Offs: 45
Thatsa good idea Yan.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 12-30-2016, 05:28 PM   #33
yantosh
Flip Offs: 14
I wasn't happy that the cross piece of the jig was spot on, so I loosened everything off and took the swingarm pivot pin back out. While I was putting it all back together I remembered I had a steel tube with inserts in the ends with 20mm holes, used it while putting new pivot points in the Z650 frame, so that's in the frame now ready for attaching to the jig
It has a mashup of spacers along with it, but I'll make proper ones
the lower insert was trimmed to length
and the front mounting plates started
If all goes to plan the old frame will be off tomorrow
Old Streetfighter Motorcycle Forum Post 12-30-2016, 11:23 PM   #34
akjell
Senior Member
Fighterer
Local Time: 10:32 AM
akjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of lightakjell is a glorious beacon of light
Not sure what I like better here -- the bike or that build jig. Awesome work!!!
________________________________________
Check out my first 900rr SSSA Build at: http://www.customfighters.com/forums...ad.php?t=88889
akjell is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived akjell!
Old Streetfighter Motorcycle Forum Post 12-31-2016, 11:02 AM   #35
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:32 PM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Default
Originally Posted by ROBBO View Post
That's were i go wrong ,all I use is wood fer this stuff
I've used wood jigs for all my stuff too. It can be fine in terms of accuracy, but it's only really suited for single use jigs where you don't need access to all sides of a joint. Would get knocked around to much in the process of building a whole frame, and get in the way of welding. And that's ignoring the damage it would take from fire....
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-31-2016, 12:33 PM   #36
yantosh
Flip Offs: 14
the old frame is off the jig, today has been a battle between me trying to get things done and my inner chimp wanting to smash the whole fuckin place ...... I fed him beer and hoped for the best .
I've been checking the specs of the new GSR compared to the GSXR, the GSXR has a rake angle of 23.5' where as the high barred GSR is 25' , the last thing I want is to go to all this grief and end up with a bike that's super twitchy and tries to launch me into the scenery at every opportunity (i'm old enough to realise I'm no super hero)....
soo I'll change the neck angle a bit , make adjustable offset yokes (letting me set the trail ) , an adjustable swingarm pivot and ride height adjuster for the shock... hopefully that'll be enough to set it up
I'm having a cup of tea..... pics soon
Old Streetfighter Motorcycle Forum Post 12-31-2016, 01:58 PM   #37
yantosh
Flip Offs: 14
looks like I'm done welding for the next week or so
but I was able to get to this point
I'll need to collect the throttle bodies and airbox, should have done that yesterday when I was at the shop
but since I'd got this far I had a mess about with flexi pipe
Old Streetfighter Motorcycle Forum Post 12-31-2016, 07:46 PM   #38
yantosh
Flip Offs: 14
31st Dec.. 23:00hr...what to do ?
design frame components
that's the inserts for the adjustable swingarm pivot point drawn up , they are of course subject to change, but the basics are there, I can get 5mm up or down with these
Old Streetfighter Motorcycle Forum Post 01-18-2017, 06:52 PM   #39
yantosh
Flip Offs: 14
it would appear I have me a headstock.... all by my own hand too
and so it begins
Old Streetfighter Motorcycle Forum Post 01-18-2017, 06:55 PM   #40
XxGRYMMxX
Breaking shit...
Local Time: 01:32 PM
Flip Offs: 8
fuck yeah.
Thank you for viewing My Big Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - My Big Build on Custom Fighters Streetfighter Motorcycle Forum
