GS500E Fuel Injection - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > GS500E Fuel Injection
Old Streetfighter Motorcycle Forum Post 10-03-2011, 03:48 PM   #31
Flashmn
Fighterer
Flashmn's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:33 AM
Flip Offs: 1
Flipped Off 8 Times in 6 Posts
Flashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of lightFlashmn is a glorious beacon of light
Default Re: GS500E Fuel Injection
Yeah, they're licensed bosch injectors, but most likely made by NipponDenso and have ND connectors. Similar connectors are found in toyotas, which are basically a ND version of bosch injection.
Flashmn is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-03-2011, 09:26 PM   #32
mikey
Redneck Dumbass
mikey's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:33 PM
Flip Offs: 21
Flipped Off 36 Times in 32 Posts
mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!mikey is an amazingly helpful member with a good attitude!
Just bought an EX650 wiring harness on ebay for $28.00 delivered!
Project: Moneypit
Originally Posted by spoonfedd View Post
i would rather have "fear my ass" primer than "fuk my ass" purple
Originally Posted by super View Post
you two fags need to give up the charade and go camping already
Originally Posted by Peter Gaulke
When a shark appears in the area sea lions will leave the water immediately. Luckily there are no tigers on the shore waiting for him, or he wouldn't know what the fuck to do.
mikey is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived mikey!
Old Streetfighter Motorcycle Forum Post 10-04-2011, 08:18 AM   #33
mitch500
Fightering commuter bikes
Fighterer
Local Time: 04:33 PM
Flip Offs: 32
Flipped Off 22 Times in 4 Posts
mitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well likedmitch500 is well liked
Nice.
mitch500 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-07-2011, 01:16 AM   #34
mikey
Redneck Dumbass
Flip Offs: 21
I searched and found an ND source, but the terminology made it hard to find what I was looking for. It was formatted for people who already knew what they wanted. I also don't want a pigtail, I want crimp connectors for the fewest splices possible. I'm going to be using placing this unit inside a sealed box with econoseal (weatherproof) bulkheads so the entire unit has no moisture intrusion. I sent a message requesting info with pics of the injectors, but didn't hear anything as soon as I'd hoped, so I ordered a cheapo wiring harness I can cut up for right now.
Assembled the circuit board today. I took a pic with it next to a AA battery for scale.
The entire unit is only about 2/3 the size of a deck of cards. I have enough injector IC's and darlington transistors to build a second unit as well, so I'll order some SMD resistors and capacitors to reduce the footprint a little. The only zeners I can get with the wattage rating I need are axial lead, but maybe I can get a smaller diameter leads next time so I can mount thru-hole instead of the cobbled mess I have now.
I'll rig up a connection for the TB injectors tomorrow and test with my benchtop 12VDC power supply. If I hooked it up right and don't smoke it, I'll start testing for a closed loop soon. Gen I is only going to be a rudimentary lookup table style system like the current ECU's have in place so I can get some data for closed loop Gen II. I still need a trim pot for idle adjust setpoint, and a circuit to monitor the TPS. The EX650 TB's also have an internal butterfly operated by a stepper, so I'll ahve to figure out what the hell to do with that too somewhere along the line. I have a feeling it's a choke for warming the bike up, but I could also be completely wrong.
I also decided to try and add a serial LCD display with an external speaker I had laying around to it. Not working out quite as well as I'd hoped. I did manage to get it to display random characters and squeal loudly. Not what I was shooting for, but it beats a poke in the eye with a sharp stick.
Project: Moneypit
These people High Fived mikey!
Old Streetfighter Motorcycle Forum Post 10-07-2011, 01:44 AM   #35
VT420
fail-o-matic
VT420's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:33 AM
Flip Offs: 620
Flipped Off 609 Times in 85 Posts
VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!VT420 is an amazingly helpful member with a good attitude!
some of the dual butterfly TBs on FI bikes were an attempt to emulate the behavior of a CV carb, or at least to prevent bog from sudden vacuum loss on sudden throttle openings...
on one hand it still seems like you're trying to reinvent the wheel with some of the hardware that's already out there, but on the other hand, i'm sure your learning a SHIT-TON about FI and engine management, so that makes it all worth while...
interested to see the final product, and possibly scematics and code, if you aren't trying to be supersecretsquirrel, lol
: putting the fight in fighter since always....
Originally Posted by Friedrich Nietzsche
Let man fear woman when she hateth; for man in his innermost soul is merely evil; woman, however, is mean
Originally Posted by Robert Heinlein
I am free because I know that I alone am morally responsible for everything I do. I am free, no matter what rules surround me. If I find them tolerable, I tolerate them; if I find them too obnoxious, I break them. I am free because I know that I alone am morally responsible for everything I do.
VT420 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived VT420!
Old Streetfighter Motorcycle Forum Post 10-07-2011, 12:36 PM   #36
mikey
Redneck Dumbass
Flip Offs: 21
Interesting. I'll have to look into the stepper and see what I can do with that. I'll probably have to recycle code from the stepper drivers on my 3D printer project, which has stalled due to not being home lately.
Maybe, maybe not. More like improving on a version already in place. The Microsquirt is out, but I've read a LOT of the forums on thier site and people talk about it like it's the same thing as the 3D printer DIY: A series of questionable parts with no discernable roadmap for successfully integrating it into a running system without a LOT of heartache. Worst of all, the schematics are completely uninformative. You need to know what color wire goes where, not what the wire does. It's like EFI for dummies, only they don't get you out of the dummy stage. You use THIER parts, THIER schematics, THEIR boards, and then scour the forums for answers until you play EFI legos and hope for the best. The worst part is that it's mostly car-specific, so you get answers related to a specific brand of car or a specific engine type, not something more broad-based.
My tack on it is a clean-slate redo from the ground up. Since I'm a controls and automation engineer for a living, and spent part of 2 years designing and building combustion and ignition systems for industrial ovens, I bring a lot of real-world experience into A/F ratios and fire control feedback. Honeywell makes a fire control feedback system using A/F and temperature as the variables that I've worked with that works like a dream, but it's a huge set of modules and there is no way in hell it's going to fit on a bike. It would be workable in a car, but never on a bike. I'm modelling my system on that, with a full ignition sequence, warm up phase, everything in the final version.
The best part is you can use open-source parts available through Newark, and I have a total of about $75 in the entire electronics kit. $30 for the processor, $5 for the shield, $20 in electronics parts, some time, assorted wire and shrink tube, and the software programming environment is free. The Megasquirt kits cost about $600, bare bones. You still need to buy throttle bodies, sensors, gauges, and in the end, it's still geared towards cars, so the footprint is huge and not very limited-space freindly.
The TB's would have to be sourced bike to bike anyway, unless someone came up with a generic TB system with attachment flanges. I can't find anything "generic" anywhere, and I did a lot of looking. Sudco was my last hope. The sensors for closed loop (which only the PC-V uses correctly, and for that you need to have a specific OEM EFI bike, and STILL have tuned) must be sourced, and the megasquirt only uses it as feedback for the tuner, not for the control system. If I get this working correctly, the feedback will tune the controller on the fly to maintain the correct design A/F with a trim adjust based on criteria I haven't completely defined as of yet. I need to see how it works first, but my off the cuff take is that I need to maintain about a 14.7:1 ratio with a temporary richening/leaning trim based on a high rate of change of the throttle. Go WOT and it pumps a little more, snap it shut, it leans a bit so you don't flood it. It's your basic cascaded PID loop control, with the A/F as the main feedback point and the throttle ROC as the cascade level 1.
I've been reading The Motorcycle Fuel Injection Handbook while I do this to gain more insight into what I'm doing too, so even if I DO reinvent the wheel, I'll have a much deeper understanding of the system as a whole, and I'm not out a bankful of money, so it all works out.
All the base schematics are already available on the LM1949N data sheet. That's the IC injector controller I chose to use. The controller code will be up when I get the Gen I version running, along with a full B.O.M. for everything I used.
Project: Moneypit
Old Streetfighter Motorcycle Forum Post 10-07-2011, 03:35 PM   #37
Monkey Wrench Cycles
that one legged bastard
Fighterer
Monkey Wrench Cycles's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:33 AM
Flip Offs: 2
Monkey Wrench Cycles is well likedMonkey Wrench Cycles is well likedMonkey Wrench Cycles is well likedMonkey Wrench Cycles is well likedMonkey Wrench Cycles is well likedMonkey Wrench Cycles is well liked
I thought it would be good reading to get the book mentioned but almost had a heart attack when i saw the price. $112!!!
I saw google ebook for $10, guess ill buy that...
"You can't know where your going until you know where you've been"
Http://www.monkeywrenchmotorcycles.com
Monkey Wrench Cycles is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-07-2011, 04:23 PM   #38
Freestyle72
Fighterer
Flip Offs: 9
Flipped Off 7 Times in 6 Posts
Freestyle72 is making some friendsFreestyle72 is making some friendsFreestyle72 is making some friends
My local chapters has it for $34 hard copy...
But like you I found the e-book for $10 a better deal.
Freestyle72 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-07-2011, 04:33 PM   #39
Freestyle72
Fighterer
Flip Offs: 9
Oh and as far as Microsquirt costing $600... no it cost me $420 shipped.
And it's actually pretty versatile. I am impressed that you can do what you can with electronics but for me I would not have a chance in hell of putting all those components together in my own ECU.
I got my FZR683 to idle on the microsquirt pretty easily. Now that I have proven that it will run as a concept with fuel only control. Now I am going to go full sequential and control the timing as well.
Microsquirt may be the lego of ECUs as you put it but it can handle the parameters of a motorcycle engine quite easily and has excellent software available for it to program fuel and ignition maps.
For me learning how to create these maps and various things is a challenge enough without actually having to learn all the electronic componentry and engineering that goes into that.
There is no argueing that your method is a hell of a lot less expensive though.
I have about $800 into my efi set up with all parts including a new gas tank with high pressure fuel pump, the ecu, TBs, etc etc.
This user High Fived Freestyle72!
Old Streetfighter Motorcycle Forum Post 10-07-2011, 05:49 PM   #40
mikey
Redneck Dumbass
Flip Offs: 21
Congrats on getting it to idle! Where did you get the TB from? Mine is an EX650, but that was only because it was what the original guy I found in Europe was using. Supposed to be a pretty easy fitup.
For pricing, I got the $595 right off the website from DIYautotune on the PNP system. I agree, if you're not at least moderately familiar with electronics and microcontroller programming, this would be just about impossible without having a pre-built system to start with. If I get mine doing what I intend it to do, no need for fuel maps, but that's going to be a few iterations on down the road. I'm still trying to get the stupid base circuit to fire correctly. They don't exactly explain a lot in the data sheet, and it leaves a lot open to trail and error.
BTW, I got the book for $25 at Barnes and Noble or Borders or something. Don;t recall, but the price tag is still on it.
Project: Moneypit
Thank you for viewing GS500E Fuel Injection in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - GS500E Fuel Injection on Custom Fighters Streetfighter Motorcycle Forum
