A boring job - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > A boring job
Old Streetfighter Motorcycle Forum Post 05-03-2019, 12:24 AM   #1
Local Time: 07:47 PM
Flipped Off 57 Times in 47 Posts
Default A boring job
Literally. I got to use my boring head today & thought I'd share. Apparently certain years of FZ09 and R1 have the same offset and spacing, but the FZ forks are 50/52 vs 50/54 on the R1. The stems don't swap nicely, and if you rework the stem to fit the R1 lower you have to weld it up, turn it down, then mod the stops and refinish the clamp with paint or powder. Plus you end up wasting a stem (R1) and lower (FZ).
Much easier/better to bore out the FZ lower clamp from 52 to 54mm. It's only 1mm off the wall thickness, plenty meat still there and plenty strong.
First had to set up the FZ lower, leaving a gap underneath to allow the tool a full pass.
Then measure the gap in the clamp, insert appropriate spacer, tighten bolts to eliminate play & vibration, use edge finder to locate center
Through the magic of math, vee blocks, and a height gauge I set the boring head and tool to the right size and let'er rip
Worked out well.
R1 bottom triple:
New FZ holes:
SEBSPEED is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived SEBSPEED!
Old Streetfighter Motorcycle Forum Post 05-03-2019, 12:49 AM   #2
Local Time: 04:47 PM
Default Re: A boring job
damn thats daring to set up the head like that.. i'd have never even though about that.. let alone taking one cut.
Mongoose is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-03-2019, 08:31 AM   #3
How do you mean?
Old Streetfighter Motorcycle Forum Post 05-03-2019, 09:57 AM   #4
Local Time: 03:47 PM
nice work
is fork length reasonably close? how about spacing?
Old Streetfighter Motorcycle Forum Post 05-03-2019, 10:38 AM   #5
Originally Posted by Junkie View Post
nice work
Thanks.
I did this job for a local-ish person, not sure on the FZ fork length as I haven't seen the bike in person. He was planning to use the stock top with the R1 lower, said the spacing and offset were the same. I have a set of 05 R1 forks here if you need a measure on those?
Old Streetfighter Motorcycle Forum Post 05-03-2019, 11:46 AM   #6
not important, just curious. thought I'd read somewhere that the FZ09 forks were pretty damn long making swaps challenging.
Old Streetfighter Motorcycle Forum Post 05-03-2019, 03:23 PM   #7
Originally Posted by SEBSPEED View Post
How do you mean?
I dont got the balls to measure off the machine on blocks and stick it in and cut it lol...
I always sratch cut, measure.. Then adjust it on the machine... Like a pleb
These people High Fived Mongoose!
Old Streetfighter Motorcycle Forum Post 05-03-2019, 07:31 PM   #8
Ah, ok gotcha. I think if I didn't have the tools I have right now, it would be a different story.
Old Streetfighter Motorcycle Forum Post 05-03-2019, 10:29 PM   #9
keef
Local Time: 09:47 AM
keef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to beholdkeef is a splendid one to behold
I had an 09 for about 4 years and 80,000ks. I had heard long forks, but never measured them.
But, my front end was -10mm, and the rear shock was +8mm, so it can handle a geometry change.
Nice work seb.
keef is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived keef!
Thank you for viewing A boring job in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - A boring job on Custom Fighters Streetfighter Motorcycle Forum
