Is Smoking Permitted? - Page 247 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 12-02-2018, 01:29 PM   #2461
Smoker
BLACK BELT
Local Time: 09:07 PM
Flip Offs: 34
Default Re: Is Smoking Permitted?
Got more info on the upsized reedcage mod.
There are 4 different VForce3 reedcages for the CR125. The one used for the upsized RZ/Banshee mod is the V301A.
V301A no longer sold by Moto Tassinari, superseded by V301B.
V301A was listed for '87 - '00 CR125. V301B was listed for '01 CR125. Not sure of the difference.
The VForce4 reedcage for the Banshee/RZ is V4144. Says on the MT website that metal needs to be removed from the cylinder walls, in order for the reedcage to fit.
There is only one VForce4 reedcage for the CR125, the V4R01D. Listed for '87 - '00 & '02. Notice they skip '01. (So, I have doubts about the V301B fitting the RZ/Banshee.)
I ordered a G401 gasket set for the V4R01D reedcage, so I can compare the size to the G4144 gaskets I have for the V4144 reedcage.
Can still find V301A reedcages around, but I read an independent test showing VF4s are better than VF3s.
VFuck!
Old Streetfighter Motorcycle Forum Post 12-02-2018, 02:53 PM   #2462
RS_Raz
Dickhead
Senior Fighterer
Local Time: 05:07 AM
Flip Offs: 10
I read that VF3s are disappointing compared with VF2s but VF4s are bestest.
Old Streetfighter Motorcycle Forum Post 12-02-2018, 03:39 PM   #2463
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:07 PM
Flipped Off 1 Time in 1 Post
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
Can you use a Boyesen Rad valve?
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-02-2018, 04:32 PM   #2464
Smoker
BLACK BELT
Flip Offs: 34
CR125 Rad Valve?
I guess, so. Probably should fit same as the V4s.
Pretty sure V4s are better/more recent technology.
Old Streetfighter Motorcycle Forum Post 12-02-2018, 04:36 PM   #2465
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
RAD valves are designed to optimise airflow on intakes that are angled to clear the rear shock. Don't think this is an issue on yours?
Also, check out ebay item #202513437489 for your next project.
Old Streetfighter Motorcycle Forum Post 12-02-2018, 07:51 PM   #2466
Smoker
BLACK BELT
Flip Offs: 34
This???
Ha, ha!!
Would probably be dragging the grafted part of the engine on the road. Not to mention the engine/bike would be out of balance.
Could get much more power and performance with 2 big aftermarket cylinders.
They make Rad Valves for the RZ/Banshee engine. To use the larger CR125-sized Rad Valve (reedcages), I would still need RZ/Banshee-style Rad Valve intakes, or other intakes.
Old Streetfighter Motorcycle Forum Post 12-04-2018, 01:57 PM   #2467
Smoker
BLACK BELT
Flip Offs: 34
Well, it would have been a good idea for me to actually look at the engine before spending so much time on this mod.
The CR125 upsized reedcage mod was suggested to me by Ed Erlenbach. He sent me the pic of the V3 reed and the RZ cylinder. The thing is, he's an RD and TZ guy - so maybe this is actually an air-cooled mod. Or, maybe there's something I'm missing. I think the bolt pattern is the same on the V3s and V4s.
Got the CR125 V4 gaskets. Much wider than the Banshee gaskets. With the hose between the cylinders, I don't see any good way to go to larger reedcages.
I could do it by extending the (cut-out, thin-walled) cylinders and welding the new flanges past the hose, or trying to offset the new flanges, but I don't think either answer is good. The extensions would be welded right next to the hose, unless the cylinders are cut down.
Could turn the reedcages sideways, but never heard if that. If I could, they would only be 1mm wider on each side, plus the welding bead.
I think its back to the Banshee V4s.
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 12-04-2018, 02:08 PM   #2468
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Damn that stupid pipe. Try blaster cages then. I think banshee guys upgrade to those which is where I stole the idea from.
Old Streetfighter Motorcycle Forum Post 12-04-2018, 02:31 PM   #2469
Smoker
BLACK BELT
Flip Offs: 34
Unless the bolt pattern is the same, I don't see how they could work.
The coolant hose takes up all the room between the reedcage flanges.
Kind of sucks, but the mod is a lot of work for a few more HP on top. Might even hurt low and mid-range performance.
I wanted it because it's also a cool visual mod.
Old Streetfighter Motorcycle Forum Post 12-04-2018, 02:35 PM   #2470
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
put your efforts into making the intake stand out then. Get that one you posted but Smokerize it.
These people High Fived RS_Raz!
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
