But seriously, if you take that thing to anything close to the engine's limits, you have more guts than I do. Said the guy planing to take a home built front end on the highway as a daily ride.
The clutch is the hoop under the steering wheel? Do you not like the clutch where it is? I thought most people tyr to get the pull as light as they can and mount a regular mc lever on the shifter.
The clutch lever turns with the steering wheel and to turn lock to lock you only move the wheel about 30* to the left or right of center. Since you barely have to turn the wheel you never have to reposition your hands on it and that's why the clutch lever can stay in that same spot in relation to the wheel. I'm fine with where it is located because I have long arms and need to put my hands at 2 and 11 for it to be comfortable.
I do plan to make it easier to pull. The stock clutch lever has a 4:1 leverage ratio and this shifter kart lever I bought has a 3:1 ratio so it is harder to pull.
I didn't want to put the clutch lever on the shifter because I was thinking you'd have more control over it if it was on something solid like the wheel. Figured if it was on the shift lever and you are trying to feather the clutch so you dont lock up the back wheels on a downshift and then hit a bump there is a chance you might end up shifting it too.
im a lil late on this but cant wait to see this thing done maybe ill get around to doing mine then we can race. I got two shifter frames that I bought a while back ago just for something like this I just need a powerplant for it. I olmost wanted to dump the f2 motor into it but decided to do a fighter. so get r done so we can see some donuts
At Road America they have open track days for the Motorplex track which is only for supermotos and gokarts. I've only ever been there late in the year with supermotos and there wasn't even a tech inspection. I would imagine during the racing season it will be busier and there will be a tech inspection. I really hope they don't hold me to the "you must have a fire suit" rule and make me safety wire everything. If they do I don't think I'm even going to take it there. There are a few kart tracks within a hour drive time but I think two of the three are dirt tracks and I have no idea if they would let something like this run if it would even make it through their tech inspection. With that said I'm making this plenty safe to keep me content but racing organizations can go overboard at times tryinf to protect people from themselves.
Also, the Motorplex doesn't start open track days until June or July so I can't get any on track photos with this befeor the end of the buildoff.
At idle it doesn't but when it gets revved up it sort of does. Then again maybe it was just like that because it's inside the little shed. Either way it sounds better than I was hoping for but I did find a few small pin hole leaks I need to fix.
Yeah it's great at warming up my ankles if I'm standing right in front of it. I have been wanting to get one of those 100k+ btu torpedo heaters for out there but they take up so much floor space. Then again with one of those it would probably only take a few minutes to get it back up to 50+ degrees.
I thought about doing that as a fail safe on the top of the engine for anyone to slap it in case of emergency but never got around to it. There's just a switch on the dash now.
This will probably be for sale next Spring/Summer.
