TTR250 to zx9r rhs help - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Electrical and Lights
Electrical and Lights Anything related to the fabrication of lights and other electrical components goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > TTR250 to zx9r rhs help
Old Streetfighter Motorcycle Forum Post 02-12-2020, 01:27 PM   #1
Spyrious
Fighter In Training
Spyrious's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:52 AM
Flip Offs: 5
Flipped Off 1 Time in 1 Post
Spyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of lightSpyrious is a glorious beacon of light
Default TTR250 to zx9r rhs help
Hello.Its not a streetfighter ,but i think many in here have the knowledge to help me out.
I have a 1994 Yamaha TTR250.I'm in the process of upgrading the headlight.I want to be able to switch it on and off.The ttr has no headlight switch,just a hi-lo switch.The stock headlight is 35w.I'm going to use 2 led lights (one Hi,one low beam),10w each.I will make a small harness with a relay to to have them both on when the hi beam is switched on.Now they act like h4,only low beam or only high beam.Now to the question.I bought a right handlebar switch from a zx9r.The switch for the headlights has 3 wires.In the off position all 3 are interconnected,in position (or side lights) lights only 2 and in headlight on none of them are interconnected.I don't know how i can make it work.This is a wiring diagram for a zx6r which is the same
It looks to me like i need to wire it through the hi-lo switch somehow?
Any help appreciated!
Spyrious is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-12-2020, 03:50 PM   #2
XxGRYMMxX
Breaking shit...
Local Time: 05:52 PM
Flip Offs: 8
Default Re: TTR250 to zx9r rhs help
Attach the blue striped (rightmost wire in the schematic at the H/L switch) wire from the switch to your battery (or fuse box where the headlight fuse is).
use 2 relays, one for each light.
attach the black wire (middle one at the switch in the schematic) to the low beam led. attach to low beam relay control, pos side
attach the red/yellow (left most wire in the schematic at the switch) to the high beam led. attach to high beam relay control, pos side
both lights can be grounded at the battery. control side of each relay should be grounded at battery
position 1 will be lights off
pos 2 will be low beams on
pos 3 will be hi and lo on at the same time.
edit: just saw the relay part. correction in green.
a very rough sketch of the circuit
how to wire the relays
Hope this helps at least a little bit.
XxGRYMMxX is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 04:49 PM   #3
Spyrious
Fighter In Training
Flip Offs: 5
Many thanks for the input! I'll take a look at it after work tomorrow! Thanks!
Here is a ttr250 wiring diagram i found
Sent from my HTC One M9 using Tapatalk
This user High Fived Spyrious!
Old Streetfighter Motorcycle Forum Post 02-13-2020, 12:08 PM   #4
Spyrious
Fighter In Training
Flip Offs: 5
One question.Will i be able to use the hi-lo from the left handlebar switch,or does it become obsolete ? Thanks
Old Streetfighter Motorcycle Forum Post 02-13-2020, 12:53 PM   #5
XxGRYMMxX
Breaking shit...
Flip Offs: 8
the diagram I sketched out uses the zx6r switch so the original one wouldnt be used. if you give a few hours til lunch Ill look at the ttr250 diagram ands see if I can make another diagram that uses that one. then you can choose which one you want to use.
EDIT: looks like the ttr250 uses a switch that doesn't support the lights being off. it powers the low and high beams whenever the key is on. If you want to be able to turn the lights completely off then you'll need to use the zx6r switch and eliminate the ttr250 switch
Old Streetfighter Motorcycle Forum Post 02-13-2020, 12:57 PM   #6
Spyrious
Fighter In Training
Flip Offs: 5
Many thanks for your time!!!
Old Streetfighter Motorcycle Forum Post 02-13-2020, 12:58 PM   #7
XxGRYMMxX
Breaking shit...
Flip Offs: 8
all good buddy. good luck!! post some pics if it works out
Thank you for viewing TTR250 to zx9r rhs help in the Electrical and Lights section of our streetfighter motorcycle forum. I hope you found it useful!
Electrical and Lights - TTR250 to zx9r rhs help on Custom Fighters Streetfighter Motorcycle Forum
