Repairing Radiator Mount Bracket - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Repairing Radiator Mount Bracket
Old Streetfighter Motorcycle Forum Post 01-24-2019, 04:26 PM   #1
jfizzle232
Local Time: 02:55 AM
jfizzle232 is a NOOB
Default Repairing Radiator Mount Bracket
The radiator mounting bracket on my 2005 ZX10r radiator has broken off. Picture below shows the damage. The other side is fine which is great. I don't really have any welding stuff so I was thinking about using some JB weld to put it back together. The radiator is held on by this bolt and another weight-bearing 'nub' on the other side, as well as a stay on the bottom.
Thoughts? Would JB weld hold good enough or is it absolutely necessary that I find someone to weld it on?
jfizzle232 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-25-2019, 12:21 AM   #2
Local Time: 03:55 AM
Flipped Off 56 Times in 46 Posts
Default Re: Repairing Radiator Mount Bracket
It really should be welded.
If the piece it attaches to doesn't flow coolant, you can add a couple pop rivets as a second choice. They won't last as long as weld though.
SEBSPEED is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived SEBSPEED!
Old Streetfighter Motorcycle Forum Post 04-03-2019, 06:01 PM   #3
dude, just make a tab that goes from the frame the the fan bolt hole, and bolt it all together.
These people High Fived tldave!
Old Streetfighter Motorcycle Forum Post 04-03-2019, 08:40 PM   #4
beezwiz
beezwiz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 14 Times in 8 Posts
beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!
J
Don't know where you're located... but if riding season is already upon you. I would take Dave's advice... if ya have a several more weeks like we do in Chicago... dis-assemble and have it welded.
Peace of mind is a good thing while riding.
Beez.
Don't be the chaser, be the one who is chased. You are the Tequila... not the lime.
beezwiz is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-03-2019, 10:00 PM   #5
crazyjon's
crazyjon's's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:55 AM
Flip Offs: 17
Flipped Off 5 Times in 4 Posts
crazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant futurecrazyjon's has a brilliant future
This^^^
Jb weld will work....till you hit a bump!
Or get it welded, should be about 40$.
Jon
"Practice till the hot brass burns the cheeks of your ass" F. Bob Chow
crazyjon's is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing Repairing Radiator Mount Bracket in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Repairing Radiator Mount Bracket on Custom Fighters Streetfighter Motorcycle Forum
