Matty`s sunk cost fallacy (Bashan street quad) - Page 6 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Matty`s sunk cost fallacy (Bashan street quad)
View Poll Results: Which road to take?
Fix`n flip 2 28.57%
Full custom rebuild 2 28.57%
No fucks hoontrike 3 42.86%
Voters: 7. You may not vote on this poll
Old Streetfighter Motorcycle Forum Post 02-11-2020, 11:26 AM   #51
Mattson
Stressed Member
Local Time: 09:54 PM
Flip Offs: 25
Default Re: Matty`s China Street Quad
Haven`t posted much although been in the shed almost every night, mainly trying not to re-enact the famous garage fight scene from the movie House of flying spanners... Here`s where I`m at right now:
-There`s no wiring diagram available anywhere for these things (at least one I`ve managed to find)
-Not that it would have helped me much as the wire colors of the new wiring harness do not match the ones on the quad.
-The new wiring harness has been wired... to clumsily translate a Finnish saying, "towards ass". I literally had to explode the remains of the old harness to find out which wire is supposed to go where.
-The engine kill wire was hooked up as the positive for the horn
-There`s one wire that has switched power but is not used so I`m guessing that`s what`s supposed to power the horn.
-The horn negative is wired straight into ground so if I wire it like that it`ll scream bloody murder whenever the power is switched on, still haven`t gotten to figuring out where the horn wire DOES go and rather not push the button to find out
-The engine start circuit was wired so that if I pressed the start button without the brake pulled the lights would go out, and the brake pulled in the brake light would light up, but only if the start button is pressed.
-There`s still one wire that`s coming from the gear sensor and has switched power UNLESS the reverse gear is selected. At first I thought this was supposed to power the start relay but it only has 10v and too little amps to trip the relay so still got no idea what, if anything, that is for.
As can be seen from the pic I wired the switch gear through superseal connectors but at that point got my head mixed up badly enough that I wired the connectors wrong so gonna have to re-re-re-re-redo those one more time...
So yea it`s been a fun week but now the start button does indeed trip the start relay, and only does it when the brakes are applied as it should be.
Still waiting on my rear brakes though, going on six weeks now... The DPD parcel tracker does show the package has left Meppel NL 31.1. but for some reason shows up in Oirschot NL two days later which is on the opposite side of the country and nowhere near Eindhoven where the airport is. Just sent an email to ALG-Moto if they`d kindly ask DPD where the hell is my package and why is it still not here. Slowly starting to run out of humor with that one...
Ex: Benelli Tornado 900 '06
Ex:Triumph Daytona 955i DSSA '02
Ex:Honda CBR 600 F2 '91
This user High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 02-11-2020, 06:06 PM   #52
Mattson
Stressed Member
Flip Offs: 25
Turns out I got a ton of superseal pins and sockets but happen to be fresh out of the connector bodies so solder and glue-socket it is, the switchgear can easily be removed along with the harness if the need should ever arise. Also turns out there`s no point in searching for the horn wire as the new harness doesn`t HAVE one! The center pin in the 9-way connector to the left switchgear was empty! That was quickly remedied by a bypass and now I have a horn as well.
Done with electrickery for a while I decided to fit a new hose between the brake master and the reservoir as well as refit the said reservoir. Also fitted the chain although after thoroughly soaking it in 80w90 oil and letting it sit, it has sagged enough that I probly have to remove one more link, no biggie as it probly takes me more time to dig out the tool box again than to do the deed as this is a spring clip master chain. (I`ll tell you being used to 530xw chains this thing is worryingly flimsy but I guess it`ll be enough for the output this thing has...)
Old Streetfighter Motorcycle Forum Post 02-15-2020, 03:44 PM   #53
Mattson
Stressed Member
Flip Offs: 25
She runs (man it always feels the best to write that ) BUT the battle is far from over quite yet...
https://youtu.be/qVKXq-xbtuE
Dismiss the horrible clatter I got spooked about that too but turns out it`s just loose things rattling around at the back (basically just threw this together after a very long day in the garage to try if it starts at all) Now I know how to do a lot of things, carb tuning is not one of them so if someonoe can identify from the sound or how it behaves (bogging/fluctuating revs at WOT) if it`s going lean or rich I`d much appreciate it. It does idle like a champ and revs up to about half throttle but when I open it up it goes hell no so I`m guessing main jet/needle position?
These people High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 02-16-2020, 09:16 AM   #54
shinyribs
Local Time: 02:54 PM
Flip Offs: 58
Couldn't tell much from the video on the carb question. If the exhaust was pumping like a chimney when you rev it I'd say it could be rich and flooding, but it doesn't really sound that way. Recovers too cleanly.
Apologize for a question I should have the answer to, but is the stock airbox in place? You know my internet situation It returns to idle without lingering, so you can rule out vacuum leaks.
Wouldn't hurt to double check float level and petcock to ensure plenty of fuel flow. You can lift the needle to fatten things up and see how she responds. If she likes it, but you cant lift the needle high enough, go up a main jet size and reset the needle to stock height to start again.
Also double check all vent hoses off the carb are clear and that the air cut off diaphragm is healthy, if it uses one.
Old Streetfighter Motorcycle Forum Post 02-16-2020, 12:56 PM   #55
Mattson
Stressed Member
Flip Offs: 25
Stock airbox is not in place, it is replaced by an ebay jetcone style power filter. There is no petcock at all so that cannot be the issue. The carb is brand new although not necessarily meant for this particular machine. I'll start with opening up the air screw and see if that does a thing. That however will have to wait as sth in the electrical system has gone awry. The machine worked for a while when I was doing some figure eights at the front yard but for some reason is now dead as a stone. Suspecting the ignition lock as that is a well known failure point with these. One thing is the exhaust might be too restricting as it is longer than original, although not so much that I'd think that to be a likely scenario and one that's easily tested by removing the muffler.
Old Streetfighter Motorcycle Forum Post 05-19-2020, 04:58 PM   #56
Mattson
Stressed Member
Flip Offs: 25
Long time no ocean... Lost all motivation towards this project after getting it outside and finding out it won`t run properly, did other stuff in the garage messing it up real good then didn`t have the resolve to clean up so for the last couple months this thing`s been sittin out in the rain. Finally got a spark to clean up the garage along with a few upgrades so eventually got the quad back on the table as well.
Since I finally had a view to the underside without getting on all fours (ha ha...) I decided the first issue I should tackle is the rattling exhaust...
...sooo one chimney bracket coming up when I get off work tomorrow, can`t use an angle grinder at this hour as that would wake up the kids.
Oh, also found out a couple issues with the not revving thing. First is you don`t need a special screwdriver after all to get to the downwards pointing air screw, you just need to get at it from the right side of the vehicle.
Yea I know... Still need one of them ratchet bit driver wrench thingies but luckily I have one.
The airscrew was open for 2 1/4 turns, it is now opened a full three revolutions, after I get the chimney braced and rid of the resonance rattle gonna wheel it back out and see if that did a thing.
OH! And I STILL have not received the rear brake parts I ordered in January but that`s actually partly my fault now as the package has reached the seller but I told them to hold the re-sending till I figure out what else I still need (about the last place to get them as they`ve stopped making these long ago)
That`s been at least about a month though, should probly send them an email tomorrow...
Old Streetfighter Motorcycle Forum Post 05-21-2020, 08:44 AM   #57
Mattson
Stressed Member
Flip Offs: 25
If any of you guys reading this knows about carb tuning any help would be appreciated.
Current setup:
Keihin PZ30 pumpy carb
Jetcone style free flow air filter
Needle was set on the top slot so needle was all the way in
Main jet has no markings on it so cannot tell but according to the internet it might be a 108
Symptoms: The quad starts fine and idles fine but does not throttle. With the choke halfway engaged I can sort of get it to rev to about half throttle but anything past that it just sputters. I have tried adjusting the air screw from all the way in to dropping from threads, about three turns out seems to be the right place but overall it has oddly little affect no matter what setting it is in.
I have now set the needle all the way up to see if that did a thing, going to reassemble everything and possibly report back in a while. Any ideas welcome.
Old Streetfighter Motorcycle Forum Post 05-24-2020, 05:52 PM   #58
Mattson
Stressed Member
Flip Offs: 25
The carb is kicking my butt enough to lose all motivation again so decided to sod it for a while and concentrate on something else, so bough some stainless angle and flat stock and made these...
...then used those to make these...
...to fit these. Still needs work but can`t use fine tuning equipment like a sledge hammer or an angle grinder at night. Oh and probly would need to wire them in as well, Ive already done the relay and the handlebar switch earlier so making them work shouldn`take too long.
Old Streetfighter Motorcycle Forum Post 05-30-2020, 05:31 AM   #59
Mattson
Stressed Member
Flip Offs: 25
Front suspension orangefication in process. Takes a LOOT more paint than I expected as you shoot most of it past the pipes (and I'm pretty sure the first bottle didn't have a full fill) Need to get more to get the steering knuckle and the hub painted too, luckily those are less visible so don't suppose it matters much if I can't find the exact same shade (NOT driving to the city just to get that exact paint) And of course rinse and repeat on the far side...
Old Streetfighter Motorcycle Forum Post 05-30-2020, 03:56 PM   #60
Mattson
Stressed Member
Flip Offs: 25
Marginally better, just need to get a new rubber around the lower balljoint as it was so crispy it tore away when I peeled off the masking tape.
Now would somebody else please do the other side and the rear hubs, pls?
Thank you for viewing Matty`s sunk cost fallacy (Bashan street quad) in the Other Motorcycle Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Other Motorcycle Discussion - Matty`s sunk cost fallacy (Bashan street quad) on Custom Fighters Streetfighter Motorcycle Forum
