shafty Virago 750 - i guess nobody have done it before :) - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2013 Streetfighter Buildoff > 2013 Buildoff Entry Threads
2013 Buildoff Entry Threads All 2013 Buildoff Entry Threads Must Be Posted In Here
CustomFighters.com Streetfighter Motorcycle Forum > shafty Virago 750 - i guess nobody have done it before :)
Old Streetfighter Motorcycle Forum Post 11-01-2012, 07:12 PM   #1
spyra78
Active Member
Fighter
spyra78's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:20 PM
spyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud ofspyra78 has much to be proud of
Default spyra78 - single swinger shafty Virago 750 - build
hello there!
pretty new here and looking for inspirations... Just started my own Virago 750 82 project couple of weeks ago...
I hope i can still get into the 2013 build off ). Can i?
discussion thread
Here is where i got till now:
all started as a nearly stock one:
had those two to choose from:
then:
had to work on a head tube a bit to fit the gixxer front:
the triple clamps were all different bikes so had to be machined slightly too to fit on the forks..
managed to put it all together without bigger problems and i luv the look of it
while tidying up my garage i found a nice old seat:
cleaned it an planning to put some nice brown leather on it:
then i started on the engine- want it done mirror like:
this is only beginning:
as u can c i got rid of the edge of the casing. want to make it as smooth as possible...
it all will take some time but ill try to get it done asap...
what do you guys think?
All sugestions welcome!
Last edited by spyra78; 11-02-2012 at 05:43 AM. Reason: easier to find one both threads have got the same title.
spyra78 is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived spyra78!
Old Streetfighter Motorcycle Forum Post 11-01-2012, 07:21 PM   #2
spyra78
Active Member
Fighter
Default Re: shafty Virago 750 - i guess nobody have done it before :)
I had it all written down as i was working on the bike so i just paste it here
I thought its good time to show few pics of it as i seriously started to believe that buld will go well
saturday:
not much was going on so here are few pics:
just thought what to do with the tank... racing green, black, black cherry..
and maybe some stripes
then cleaned the tank
before
and after:
sanding, sand blastin, grinding and polishing day... i can feel no arm.. went numb ;]
now i realised why hand made stuff is often very expensive.. will never say that something hand made is too expensive,,
...so i decided to use a single side swing arm... polished one will have to end up on the shelve till the next project
the ''new'' wheel is getting better...
then cleaned the calipers...
and the chopped the frame needed for the new swinger ... i was scared for a moment once i have done it....
then i put few things together and the idea of the bike apeared...
my humble opinion.. not at all bad )
yessss
havent decided on the type of the seat yet...
i am pretty sure there will b single sided plate holder...
but we will c...
to be continued...
Old Streetfighter Motorcycle Forum Post 11-01-2012, 07:23 PM   #3
spyra78
Active Member
Fighter
and here is the most recent update:
on whats done today:
made a proper stiff table(about 10cm to tall so gonna have to chop them legs) to bolt the bike to it for th build time...
already bolted the front of the bike to it and going to mount the frame and the swinger to it tomorrow...
Old Streetfighter Motorcycle Forum Post 11-03-2012, 05:18 AM   #4
spyra78
Active Member
Fighter
just a little update:
decided to change the jig to make it easier to put in a straight line, level and plumb.
Bought two nice thick pipes and .. well u can c it on the pics.
Also hang the bike so its much easier to move around..
so far i spent around 1500 USD
will make a whole list at the end of the build. planning to close it in 2500. We will c..;]
tbc...
Old Streetfighter Motorcycle Forum Post 11-07-2012, 06:39 AM   #5
spyra78
Active Member
Fighter
Hi!
firstly: i was asked to upload some pic with the newspaper with date so here's a couple:
and now what i have done so far:
once i had it all bolted to the jig in a straight line, level and plumb, i started on beefing up the swing arm mount:
made it all fit nicely, mocked it up:
then made few welds here and there to keep it together on its place:
once placed few strong welds on i could unmount the rear wheel off of the jig and take the whole swinger out along with the mount ( gonna keep it bolted to the swing arm for final welding:
and here is the closer look:
i quite like the way it looks. Pretty massive. But im sure there will be few changes and xtrapieces welded in to make it stiffer.
off to the garage now
tbc...
Old Streetfighter Motorcycle Forum Post 11-13-2012, 06:07 AM   #6
spyra78
Active Member
Fighter
Originally Posted by fennimore40229 View Post
where did you find a single sided swing arm?
NTV swinger from ebay...
and here is a small photo update:
Old Streetfighter Motorcycle Forum Post 11-15-2012, 08:44 AM   #7
spyra78
Active Member
Fighter
while working on the wheels i just mocked it up with tyres and i quite like it
Old Streetfighter Motorcycle Forum Post 11-19-2012, 05:08 AM   #8
spyra78
Active Member
Fighter
Originally Posted by nmangano2412 View Post
WoW, im shocked!!!! This is absolutely amazing!!!! sub'd
cheers bud!
didnt have much time to work on it lately so just a small job done:
polished some stuff. Unfortunatelly the alloy on the swinger is different and doesnt want to get shiny...:/.
Will have to work on it a bit longer i guess. Not sure if it will work though.
Any suggestions on what polishing stuff to use?
Old Streetfighter Motorcycle Forum Post 12-12-2012, 07:14 PM   #9
spyra78
Active Member
Fighter
hello!
finally got some time to work on it and:
fresh rubber:
and this is the plan for all the cables:
will c how it goes.
bracket for the rear r6 shock:
i wish i had a better welder. Tig one day i hope...
but its all cleaned up and mounted
tbc...
Old Streetfighter Motorcycle Forum Post 12-16-2012, 04:56 PM   #10
spyra78
Active Member
Fighter
darn cold got me so nothing was going on in the garage...
here is the rough ide what i want it to look like.
what do you think?
Thank you for viewing shafty Virago 750 - i guess nobody have done it before :) in the 2013 Buildoff Entry Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2013 Buildoff Entry Threads - shafty Virago 750 - i guess nobody have done it before :) on Custom Fighters Streetfighter Motorcycle Forum
