SV1000Reptilia - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SV1000Reptilia
Old Streetfighter Motorcycle Forum Post 10-07-2019, 03:39 PM   #31
Local Time: 04:37 PM
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
Default Re: SV1000Reptilia
Yes, but no, but yes.
Alum strength, regardless of alloy, is highly dependent on it's heat-treat level. This is the -T(n) in the alloy number, i.e. 6061-T6.
Welding alum will introduces a high heat cycle that will reduce temper to T0 at least in the heat-affected-zone or in the entire part depending on how hot the whole thing gets. So, there goes all your strength... until you re-temper it. Sending the part off for heat-treat after welding will return it to the desired T level.
right, it can be re heat treated, but that isn't something most welders will be equipped to do and it's going to be awfully expensive for a part that size.
Old Streetfighter Motorcycle Forum Post 10-11-2019, 06:09 PM   #32
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:37 AM
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Month
Ok here we go again with a subframe from 899 this time. The reason I've choose to buy this and not build one, is that I'm not sure If I can make it lighter from the OEM. It's a litle complex. Doable to build but complex enough, to give all the efort and money and stay with a heavier subframe at the end.
So 899 subframe it is and the 1199 one is on ebay for selling. I should have it next week.
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 10-11-2019, 11:15 PM   #33
Auser6guy
Local Time: 06:37 PM
Auser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of light
That seems much easier to work with. If that’s steel I reckon even I could knock something up 😂
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 10-12-2019, 05:00 AM   #34
Leroy
It's piece of cake to make it work. Yes it's made of steel
This user High Fived Leroy!
Thank you for viewing SV1000Reptilia in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SV1000Reptilia on Custom Fighters Streetfighter Motorcycle Forum
