Smoker's Custom Motard - Page 143 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 07-01-2019, 10:43 AM   #1421
Smoker
BLACK BELT
Local Time: 03:06 PM
Flip Offs: 33
Flipped Off 12 Times in 11 Posts
Default Re: Smoker's Custom Motard
Originally Posted by Mongoose View Post
do the tubes just snap together? kinda reminds me of those coolant tubes. i'd assume there's a teflon liner inside..
The links slide over a teflon tube and fit together.
I'm using an uncoated, polished, stainless inner cable, since I need to solder on the cable end fittings.
Smoker is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-03-2019, 06:35 AM   #1422
Smoker
BLACK BELT
Flip Offs: 33
Getting close to wiring up the bike.
Unfortunately, I know very little about wiring. Will definitely need some help.
I bought this used stator. Hope it wasn't a mistake. The blue wire that goes to the neutral light switch is messed up.
Looks like the blue wire is burned where it goes through that notch in the trans cover. About 1/4" of the wire housing is gone, and the copper wire is broken there (under the blue tape). All of the blue wire in the photo is hardened. Feels like it will snap if I try to bend it.
Plan is to replace the entire blue wire. First problem is, I have no idea what size the wire is. Guessing 22 gauge. Better get some kind of chart or sizing tool.
The grommet that holds the wire in the notch is NLA (p/n 90480-01148-00). Will have to figure out another way.
Old Streetfighter Motorcycle Forum Post 07-03-2019, 08:40 AM   #1423
mcantar
Fuck it, let's do it live
Local Time: 04:06 PM
Flip Offs: 44
Electronics are easy. You comfortable with a soldering iron?
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
This user High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 07-03-2019, 09:48 AM   #1424
Smoker
BLACK BELT
Flip Offs: 33
I wouldn't say comfortable, but I've soldered a few (literally) wires before.
Also need to buy a soldering pot or crucible for soldering the fittings onto my custom cables. Never used one before. Still looking at soldering techniques for the cables.
Old Streetfighter Motorcycle Forum Post 07-03-2019, 09:55 AM   #1425
Mattson
Stressed Member
Local Time: 01:06 AM
Flip Offs: 24
Flipped Off 33 Times in 21 Posts
Mattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on here
Eh? I'm an El-Tech by training and never even heard of a benchtop version! Thought they only did that in big factories.
Benelli Tornado TRE Novecento 2006
EX: Triumph Daytona 955i DSSA 2002 Fighter
My homebrew blog thread thingy: Oddball Brewery
Old Streetfighter Motorcycle Forum Post 07-03-2019, 11:27 AM   #1426
SEBSPEED
V4's FTW
Local Time: 06:06 PM
Flip Offs: 53
Flipped Off 56 Times in 46 Posts
I've done cable ends with a regular pencil iron. I made a brass fitting from a wood screw, drilled the cable hole, countersunk on one side. Pull the cable through, snip it a tad long, birdcage it, solder the big end. Think of making a rope ladder, but more precise.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
SEBSPEED is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-04-2019, 08:34 AM   #1427
Smoker
BLACK BELT
Flip Offs: 33
Got the cable adjusters from Germany. Only place I could find the right size adjusters in stainless. I previously made some titanium adjusters (for the carb cables), but trying not to make one-off parts, if I don't have to. These stainless adjusters are so drilled out, they're very light. And stainless can go into the nitriding oven.
Mocked up the YPVS cable housings. Looks good and custom. Will throw on some blue anodized nuts for a good match.
Old Streetfighter Motorcycle Forum Post 07-04-2019, 08:48 AM   #1428
Smoker
BLACK BELT
Flip Offs: 33
Found this chart, and will take a look at the blue wire construction, and see how it works.
Old Streetfighter Motorcycle Forum Post 07-04-2019, 09:42 AM   #1429
tldave
Flip Offs: 5
soldering is kinda like welding, you are heating up the pieces of metal you are soldering so the solder melts and adheres to them. melting them solder onto them just results in some bullshit. just watch a YouTube video and you'll get it. the key is to buy a half decent pen with the proper tips for your application, and get shit JUST got enough to solder. the better the soldering iron/pen, the faster you can heat the metal up, the less induction you get traveling up the metal, and fucking up your Christmas.
Old Streetfighter Motorcycle Forum Post 07-04-2019, 09:45 AM   #1430
tldave
Flip Offs: 5
also, clean the tip when it's hot. I use sand paper. clean tips mean fast heating. put tip in and spin fast, then wipe off with a rag. that's my style. probably better ways.
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
