Smoker's Custom Motard - Page 144 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Smoker's Custom Motard
Old Streetfighter Motorcycle Forum Post 07-04-2019, 10:50 AM   #1431
Mattson
Stressed Member
Local Time: 06:44 AM
Flip Offs: 24
Flipped Off 33 Times in 21 Posts
Mattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on hereMattson spends too much time on here
Default Re: Smoker's Custom Motard
Do not use sandpaper, if you rub through the coating of the tip down to the copper core the tip is ruined, all you need is a piece of natural sponge, do not use plastic foam sponge obviously cause it will melt. Wet the sponge and just wipe the hot tip onto it, the surplus solder and slag will come off cleanly without damaging the tip. If you're not planning to use the iron on anything else than just to solder up a few wires get a cheap flat tipped one, shouldn't cost more than a tenner or so, 45w will suffice in a windless environment. An adjustable soldering station is always better but for just wires a bit overkill. I've found my go-to soldering iron to be the dremel gas torch
Mattson is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 07-04-2019, 02:25 PM   #1432
tldave
Local Time: 11:44 PM
Flip Offs: 5
you can't stop me bro
Old Streetfighter Motorcycle Forum Post 07-06-2019, 03:05 PM   #1433
Smoker
BLACK BELT
Local Time: 08:44 PM
Flip Offs: 34
Trying to do the float bowl mod.
Couldn't find the Keihin bowls online. Found a new set on Ebay.
https://www.ebay.com/itm/NEW-Float-B...cb2c%7Ciid%3A1
Got some bogus shit.
The ad photo shows actual Keihin bowls. Ad says made by Keihin bowls.
Keihin (PWK) bowls have "PWK" cast on the inside of the bowls. Not on the bowls I received. Bogus bowls next to my genuine PWK bowls.
One bowl is damaged/defective. Note the position of the overflow tube. This bowl also had machine work done. Probably caused the bent tube.
The bowls I received aren't even the same version as the ad photo. Overflow outlets are also different.
Check the quality compared to genuine Keihin:
More wasted time. Will contact Sudco about getting genuine bowls.
Old Streetfighter Motorcycle Forum Post 07-06-2019, 04:21 PM   #1434
Mattson
Stressed Member
Flip Offs: 24
man that`s bullshit... and at the same time the main reason why I only order via ebay stuff I don`t have to return in case of a dud (cause the shipping costs from here can be 10x the value of the product)
Old Streetfighter Motorcycle Forum Post 07-06-2019, 05:42 PM   #1435
Auser6guy
Fighter In Training
Auser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of lightAuser6guy is a glorious beacon of light
Default
Sucks man ! File a dispute, PayPal will refund your money in full including postage within 24 hrs and the shipper pays return postage. Most of the time they don’t even ask for the stuff back.
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 07-10-2019, 04:58 AM   #1436
Smoker
BLACK BELT
Flip Offs: 34
Wasn't feeling this kill switch, so it's gone.
Got a billet aluminum kill switch. Just need matching hardware.
Old Streetfighter Motorcycle Forum Post 07-10-2019, 06:11 AM   #1437
Auser6guy
Fighter In Training
I take it that’s a push and latch type switch? Looks good. What throttle housing is that ?
Old Streetfighter Motorcycle Forum Post 07-10-2019, 10:09 AM   #1438
Smoker
BLACK BELT
Flip Offs: 34
It's a momentary switch.
Joker Machine billet throttle. Not made by Joker any more.
Old Streetfighter Motorcycle Forum Post 07-11-2019, 12:11 AM   #1439
Smoker
BLACK BELT
Flip Offs: 34
Started looking at the electricals.
Already have a question.
Does the frame need to be grounded?
Was thinking the frame is only grounded so that ground wires could be attached to the frame, instead of running all wires back to the battery negative.
Maybe there's another reason - like, it's better to ground devices closer to where they're located - or some other shit I don't know. Probably don't want to ground to aluminum, right?
Old Streetfighter Motorcycle Forum Post 07-11-2019, 12:46 AM   #1440
Junkie
re-tarded
Flip Offs: 3
I think most aluminum frame bikes ground through the frame
Thank you for viewing Smoker's Custom Motard in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Smoker's Custom Motard on Custom Fighters Streetfighter Motorcycle Forum
