I need a longer 28mm axle! - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > I need a longer 28mm axle!
Old Streetfighter Motorcycle Forum Post 11-06-2019, 04:27 PM   #1
makenzie71
Fighterer
Local Time: 12:07 AM
Flipped Off 1 Time in 1 Post
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default I need a longer 28mm axle!
Swapping an R6 wheel into my ZX6R swingarm, but the R6’s 28mm axle is about an inch short (ZX6R uses a 25mm axle). I’ve got a couple different R6 axles and GSXR600 axles and they’re all the same length (about 12”). I need a 28mm axle thats closer to 13”/325mm. Any ideas?
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 11-06-2019, 05:52 PM   #2
370steve
old fart
Local Time: 06:07 AM
Flip Offs: 29
Flipped Off 34 Times in 7 Posts
Default Re: I need a longer 28mm axle!
GSX1400?
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 11-06-2019, 05:58 PM   #3
makenzie71
Fighterer
We didn't get that one in the states
This user High Fived makenzie71!
Old Streetfighter Motorcycle Forum Post 11-06-2019, 06:05 PM   #4
370steve
old fart
Flip Offs: 29
TL1000R?
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 11-06-2019, 06:10 PM   #5
makenzie71
Fighterer
I'm seeing if I can find out the TLS/R lengths now.
Old Streetfighter Motorcycle Forum Post 11-06-2019, 08:04 PM   #6
makenzie71
Fighterer
Thought to myself "mak TL's use to be your thing you have two 20 gallon totes full of TL parts surely there's an axle in there"...
...and there was...
...and it's the right length
These people High Fived makenzie71!
Old Streetfighter Motorcycle Forum Post 11-06-2019, 08:05 PM   #7
makenzie71
Fighterer
there were actually four of them in there. I only had 4 TL's and only took the swingarm off one of them the fuck do I have four axles for?
Old Streetfighter Motorcycle Forum Post 11-06-2019, 08:54 PM   #8
a_morti
Local Time: 07:07 AM
Flip Offs: 24
Why not use the 25mm spindle and shim the wheel to meet it? You can make captive spacers for this.
If you use a 28mm spindle, you're going to need a 28mm drill bit and/or grinder plus a really fkn steady hand to make it go in the swing arm straight.
Old Streetfighter Motorcycle Forum Post 11-06-2019, 09:17 PM   #9
makenzie71
Fighterer
The 28mm adjusters fit the swingarm just fine, I'll just have to ream out the swingarm axle slots a bit. Alignment there isn't really an issue...the slots are already 26mm for a 25mm axle. The adjusters actually set the alignment.
Old Streetfighter Motorcycle Forum Post 11-07-2019, 07:59 AM   #10
a_morti
Flip Offs: 24
If it were me I'd still feel better doing captive spacers.
Unless you've fluked out and the Yamaha OEM spacers aligned everything to your hyosung with a Kawasaki arm and a Suzuki spindle, you're going to have to make spacers anyway.
Using the bigger spindle will mean drilling out the caliper carrier so you still need a 28mm drill. Is there enough meat on it?
Thank you for viewing I need a longer 28mm axle! in the Streetfighter Help Needed! section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter Help Needed! - I need a longer 28mm axle! on Custom Fighters Streetfighter Motorcycle Forum
