SUKATI....until i get a better name - Page 19 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2017 Winter Buildoff > Bike Build Threads
Bike Build Threads Post yer bike threads in here.
CustomFighters.com Streetfighter Motorcycle Forum > SUKATI....until i get a better name
Old Streetfighter Motorcycle Forum Post 04-18-2020, 05:06 PM   #181
yantosh
Local Time: 03:21 PM
Flip Offs: 14
foot rest plates are locked in place
made a couple of crappy top mounts for the number board, they will be replaced , but once I make the crappy bottom mount it,ll be plenty secure and I can replace them one at a time for nice ones
bottom light is a bit off to one side but it has spacers, so it can be shuffled
body filler ordered from Amazon to finish the front muddie , then I can take a mould from it
Old Streetfighter Motorcycle Forum Post 04-18-2020, 05:49 PM   #182
yantosh
Flip Offs: 14
because I,m a dumbass I somehow got it into my head that SV650 clutch covers were the same as TL..... well actually they feckin ain.t
I,ll finish the SV one and sell it
Old Streetfighter Motorcycle Forum Post 04-19-2020, 04:53 PM   #183
yantosh
Flip Offs: 14
Sundays don,t have a lot of progress in them, they're more of a get it outside for a proper look and a tidy up day.
nice to see it outside with pegs etc on it
one thing i did notice is the light brackets, too slabby and plain ,deff need sortin out
should be better once not bare loominum too
will trim the bottom to match the muddie, then pocket , started scribbling,but ended up calling it a day
Old Streetfighter Motorcycle Forum Post 04-21-2020, 04:13 PM   #184
yantosh
Flip Offs: 14
got a good bit of the bulk removed from the light mounts, welded other bits on too... only set it on fire a little
made a start on the proper brackets,they mimic the yoke, with added sticky out bits
Old Streetfighter Motorcycle Forum Post 04-22-2020, 04:59 PM   #185
yantosh
Flip Offs: 14
mounts done .... well the clamps
popped them on
they match the yoke profile
slots line up too
someone on OSS sent me this
it fits and i,ll modify to suit
off to the back end now
rejoin bits of plastic i chopped up
bot sides are slightly diff, but not to worry, i,ll take a cast of it, reshape it, make a mould,then make a carbon one
Old Streetfighter Motorcycle Forum Post 04-25-2020, 04:46 PM   #186
yantosh
Flip Offs: 14
care package arrived from Matt over on OSS
tip over sensor, oil restricter, short filter post and an oil cooler
I removed the heat exchanger, swapped the filter post and put the filter back on (i will get a new one) . The restrictor needs the hole tapped, do it when drilling cases for oil cooler lines
my stumpy levers arrived, no big money names i,m afraid, but they look good and will do the job
now they here i can finish mounting the knuckle dusters
Old Streetfighter Motorcycle Forum Post 04-26-2020, 04:41 PM   #187
yantosh
Flip Offs: 14
time to make some dust, turn this scabby muddie into a buck
several hours later
it looks a lot more like i want it to ... a way to go yet, and then i need to make a mould and then replicate in aramid fibre
Old Streetfighter Motorcycle Forum Post 04-26-2020, 05:49 PM   #188
yantosh
Flip Offs: 14
ordered a temp sensor and small digital display, to keep an on things, single rad and all
then pressed buy now on a motogadget mini, always takes a while to build up to buying them, expensive little things, but the speedo i have is too big for the available space
normal service will be resumed, cheap second hand bits, and only when i cant make it
Old Streetfighter Motorcycle Forum Post 04-27-2020, 05:05 PM   #189
yantosh
Flip Offs: 14
teeny tiny update time
4 brass bushes to go with the headlight brackets, why brass? I had some
not much of an update, to be honest I couldn,t be arsed making them this lunch time, but the little bits keep it moving on
Old Streetfighter Motorcycle Forum Post 04-28-2020, 12:56 PM   #190
yantosh
Flip Offs: 14
today's lunch was the spacer / bush / washer set up for the lower rad brackets
had a machine available while I worked
swingarm spindle nuts
and an artist friend send me this for my tank cover graphics
Thank you for viewing SUKATI....until i get a better name in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - SUKATI....until i get a better name on Custom Fighters Streetfighter Motorcycle Forum
