SUKATI....until i get a better name - Page 20 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2017 Winter Buildoff > Bike Build Threads
Bike Build Threads Post yer bike threads in here.
CustomFighters.com Streetfighter Motorcycle Forum > SUKATI....until i get a better name
Old Streetfighter Motorcycle Forum Post 04-29-2020, 04:49 PM   #191
yantosh
Local Time: 02:49 PM
Flip Offs: 14
in to work early this morning to chop some nuts
can,t fit them till new spindle
got the brass sleeves screwed on
and cut a couple of temporary brackets
2 of the brass sleeves are a couple of mm too long, push the clamp round
don,t know how well it shows in picture, but these are a bit rough, no complaints, you gets whats you pays for
so I tarted them up a bit , and made new posts with angles on the front
bit better looking
but the post could do with being longer, give the brake lever some clearance
i,ll make new ones
bought a temp gauge for the water, single rad n all
might french it into tank panel
thats all for today
Old Streetfighter Motorcycle Forum Post 04-30-2020, 05:10 PM   #192
yantosh
Flip Offs: 14
glass shop open, just have to call orders in
can of resin and can of gelcoat
longer mounting posts fitted
and then, cos i,m worth it, a little extravagance
it,ll fit in here, board is sitting too far out just now, temp brackets need trimmed
next i need to buy some teeny 12v led,s , because will I fuck pay 70 for a 30p bit of aluminium with 1 of coloured leds
Old Streetfighter Motorcycle Forum Post 05-01-2020, 12:30 PM   #193
yantosh
Flip Offs: 14
todays mad half hour was a fitting for the fan switch sensor , the rad has an extra outlet, for the lower rad i,m not using. i will join these with a short section of silicone water hose
rattle it up in lathe
then add some flats
Old Streetfighter Motorcycle Forum Post 05-02-2020, 02:56 PM   #194
yantosh
Flip Offs: 14
lets not rush to start, take a minute to enjoy some rare but genyoowine Scottish sunshine
gelcoat on the cobbled together rear muddie
layers of glass
then pop it out
I did the front muddie too, but it was a fuckin disaster
i,m going to skin the glass one i already have , which leads me to the issue of the embossed logo... do I try to trim the aramid fibre about it?
or do i mould the badge separately and shtick it on ,
little trial
inbetween all that pissing about with resin I drilled all the holes to tie the number board , thats it secure, still a bit of tarting up to do. this won,t get skinned until the lights are tested, making sure the aim is correct
found a res pot in the shed, something else I do,t need to buy
going to see if I can get a fitting to snap on here before i butcher it
now where,s me feckin dinner Chinese delivery guy
Old Streetfighter Motorcycle Forum Post 05-03-2020, 11:16 AM   #195
yantosh
Flip Offs: 14
started skinning the front muddie , and trying to mould the tank cover.... I very quickly realised life is too short for trying to mould something with all those subtle details, so i,m skinning that too
used my failure to experiment with resin over stickers
Old Streetfighter Motorcycle Forum Post 05-03-2020, 05:11 PM   #196
yantosh
Flip Offs: 14
little bit of rubbing
layer 2
sure I,ve been here before in a build off ......
Old Streetfighter Motorcycle Forum Post 05-04-2020, 04:53 PM   #197
yantosh
Flip Offs: 14
fucked about with resin etc again a bit, but no cunt needs to more pics of that
did some payday ebay shopping
CBR125 rear master
a TLS water pump cover, it doesn,t have the extra outlet of the R
inside looks nice clean
and an SV1000 thermostat , it has a higher opening temp, apparently if TL,s run too cold they switch to the cold map and foul the plugs in jig time, which sounds familiar from the last one I had
cheers to Mattman on OSS for TL gems of knowledge
Old Streetfighter Motorcycle Forum Post 05-05-2020, 04:34 PM   #198
yantosh
Flip Offs: 14
lost the badge on the muddie since im skinning it, so i made one
i,ll put it on here before clearcoat
Old Streetfighter Motorcycle Forum Post 05-06-2020, 04:23 PM   #199
yantosh
Flip Offs: 14
popped the initial rear guard out of the mould, no more 3 pieces and duct tape
will need made nice and re-moulded
fan switch thingy fits fine
lets try again with a clutch cover
the plastic cover wouldn,t last with a future plan
I like the inside , the circle and the slot are incase it needs any more machining, let me clock it up
it only went and fitted ... hopefully fits with a clutch inside
TLS water pump cover on too
Old Streetfighter Motorcycle Forum Post 05-07-2020, 06:24 PM   #200
yantosh
Flip Offs: 14
bank oliday guv,nor
hung back late with the guys doing overtime , got the clutch cover looking quite trick .... well I like it , and to be fair thats the main thing
got my one off hand crafted from finest unobtanium by the high priests of metallurgy exhaust system
just kidding.... its a length of stainless pipe that will be coerced into some semblance of an exhaust by a cack handed cunt in a garden shed
here,s a quick mock up
and then its back to the rubbing.... we all love a good rubbing
almost starting to look okay...ish
Thank you for viewing SUKATI....until i get a better name in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - SUKATI....until i get a better name on Custom Fighters Streetfighter Motorcycle Forum
