SUKATI....until i get a better name - Page 21 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > Past Streetfighter Buildoffs > 2017 Winter Buildoff > Bike Build Threads
Bike Build Threads Post yer bike threads in here.
CustomFighters.com Streetfighter Motorcycle Forum > SUKATI....until i get a better name
Old Streetfighter Motorcycle Forum Post 05-08-2020, 05:30 PM   #201
yantosh
Local Time: 03:16 PM
Flip Offs: 14
made up a couple of posts and got the rear brake master cylinder mounted
started smoothing off the rear guard buck
trimmed and sat inn place
there is a gap under the back of the seat, ideal place for indicators i,m thinking
ten at night , late enough...... more tomorrow
Old Streetfighter Motorcycle Forum Post 05-09-2020, 02:58 PM   #202
yantosh
Flip Offs: 14
make a fancy exhaust he said......
it,ll be kool he said .......
why do i do this to myself
be cool as fuck if I manage it mind...
Old Streetfighter Motorcycle Forum Post 05-10-2020, 04:06 PM   #203
yantosh
Flip Offs: 14
split my SV thermostat to check it had a higher rating than the TL
it does
I dont need this pipe
so cut, drill, tap
stainless cap screw and copper washer...... sorted
drilled and tapped for the locking screw on the damper mount, i adjusted the damper to full ... won,t do that again until i finish welding and bracing the frame post
finished building up and smoothing rear guard buck, drilled mounting holes in it too. Holes... no hidden fastening? no... I don,t build trailer queens, this is a working bike, i can use the mounting holes to attach a rack for longer trips ,it will be going to IoM
buck sitting covered in gel coat just now,
butchered the shit out of the left hand inner panel
makes the area much neater
just need to find a right hand one now
Old Streetfighter Motorcycle Forum Post 05-12-2020, 04:21 PM   #204
yantosh
Flip Offs: 14
made a spacer for the clutch actuator .... i say made... i parted off a bit of ally tube
check the fit
I will be making an overly engineered cover for it soon
popped the buck from the rear guard mould, its waxed up , but waiting for numberboard bits before moulding
tidied up the front guard mount at lunch time
swapped out the thermostat housings, SV one has its inlet pointing in a better direction, but my engine mounts foul the stock hose
Old Streetfighter Motorcycle Forum Post 05-13-2020, 03:49 PM   #205
yantosh
Flip Offs: 14
kinda inconsequential update, but it keeps it moving
got the 3 holes pitched in the bellmouth rings , stainless grub screws fitted
Old Streetfighter Motorcycle Forum Post 05-14-2020, 01:36 PM   #206
yantosh
Flip Offs: 14
started a couple of oil filler caps, one for me, one for the sv cover
had plans for a fancy jig for chopping the pie cut pieces... then thought why.... just weld some stuff....i started a cut , but the 110v transformer tripped out trying to cut through the steel so i slotting it
Old Streetfighter Motorcycle Forum Post 05-14-2020, 05:36 PM   #207
yantosh
Flip Offs: 14
plan, draw, make, fit, repeat
occasionally shower and sleep too
Old Streetfighter Motorcycle Forum Post 05-15-2020, 04:21 PM   #208
yantosh
Flip Offs: 14
started a pair of exhaust clamps , will be a fancy held on with springs system
and chopped a bunch of pipe sections
look.... it makes a circley bit
not welding it tonight... tired
and I think a fellow cf hypertard owner has an inner panel for me ... cheers guv
Old Streetfighter Motorcycle Forum Post 05-16-2020, 01:41 PM   #209
yantosh
Flip Offs: 14
glued together the segments, still got one left
going to attach a tab and bolt it to the clutch cover
then when the bends i ordered arrive i can route it to the head
skinned the number board
moulded a rear guard ,its easier with gelcoat, if i can,t make it nice i,ll skin a gel coat one
Old Streetfighter Motorcycle Forum Post 05-16-2020, 03:45 PM   #210
yantosh
Flip Offs: 14
clamps drilled, more resin applied...... movie time
Thank you for viewing SUKATI....until i get a better name in the Bike Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
Bike Build Threads - SUKATI....until i get a better name on Custom Fighters Streetfighter Motorcycle Forum
