Ahks' "Not a Speed Triple" - Page 31 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Ahks' "Not a Speed Triple"
Old Streetfighter Motorcycle Forum Post 05-15-2015, 02:48 PM   #301
Ahks
Feckin Eejit!
Ahks's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:54 AM
Location: Hiding in my own shadow near post apocalyptia.
Flip Offs: 28
Flipped Off 24 Times in 22 Posts
Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!Ahks is an amazingly helpful member with a good attitude!
Default Re: Ahks' "Not a Speed Triple"
It is a 1 1/8th bar. If I think I get some flex I'll make a cross bar. Still have the clamps from the renthal I put on the CBR.
Thanks off to DW
Ahks is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-16-2015, 09:25 AM   #302
Ahks
Feckin Eejit!
Flip Offs: 28
Cool thing about the TL top yoke.
I managed to break my zip saw, sawzall, reciprocating saw, whatever you wanna call it it... so out came the hack saw, which I discovered had a dull blade hence the miter saw
With a bit of a trim
And elongating a few holes...
The OEM triumph ignition fits
The trim is so the top sits flush with the top of the yoke. I think the lock even lines up, at least partially.
And you see the JB weld too. Theres 2 layers of 1/8" aluminum in there, every bit of facing material I could reach got roughed up for adhesion.
a full package of JB :p well mixed and dolloped in and spread around. Point a heat gun at it so it turns a touch more liquidy and it flows into all the nooks and crannys with a bit of a prod.
Then this morning I measured 450000000 times and drilled the other hole after boring out the one that came. Uneventful for once. No miscalculations or mismeasurments. No filled in "oops" 3rd holes :p
Hurried up and bolted everything together and!?!
Woohoo! it's got legs again...
But whats this?
Flattening the bevel I had on them for the OEM top yoke took too much off for them to be usable Time to source new risers... or maybe I could make some spacers out of some scrap cuts I have laying around...
So
Risers, new or make some spacers
Axle spacers, waiting (patiently I have plenty to keep me busy)
Wiring, fix the corners I cut on the electrics and sort the component layout with this new tail
Tail and battery box... keep plugging away
Front fender... I've... got an idea
Getting there!
And the front end swap only set me back a couple days worth of work and was well worth it I think.
These people High Fived Ahks!
Old Streetfighter Motorcycle Forum Post 05-16-2015, 12:43 PM   #303
Ahks
Feckin Eejit!
Flip Offs: 28
Just realized some of the photo's that I linked from g+ photos are broken for some folks (probably anyone not logged into a google). If you see missing photos let me know which post has em so I can put em on imgur instead.
Old Streetfighter Motorcycle Forum Post 05-16-2015, 12:47 PM   #304
Cookie2000ad
Persuasion Engineered
Cookie2000ad's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:54 PM
Flip Offs: 166
Flipped Off 59 Times in 27 Posts
Cookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CK
Default Medal Burnout Contest Winner Fighter of the Month
I can see them, (but do have aGmail account) doesn't look like you need much, maybe even some Form A stainless washers might be enough?
Cookie2000ad is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Cookie2000ad!
Old Streetfighter Motorcycle Forum Post 05-16-2015, 02:34 PM   #305
Ahks
Feckin Eejit!
Flip Offs: 28
Had to google that. I've never seen the "Form *" classification for washers :p
I didn't immediately think of washers as I assumed the broad face of the riser on top of the yoke helps distribute torque across the face of it. But after thinking on it a moment I realize theres plenty of risers that taper down to a simple round post...
For example
So I may just do that... I need some stainless M10 flat washers to space out the calipers a touch anywho
This user High Fived Ahks!
Old Streetfighter Motorcycle Forum Post 05-16-2015, 02:39 PM   #306
Cookie2000ad
Flip Offs: 166
I think form C is wide and thick. That might be what you need actually.
Old Streetfighter Motorcycle Forum Post 05-16-2015, 05:07 PM   #307
Ahks
Feckin Eejit!
Flip Offs: 28
Oh hey look what came in the mail today!
Thanks SHINY!
Old Streetfighter Motorcycle Forum Post 05-16-2015, 09:12 PM   #308
Ahks
Feckin Eejit!
Flip Offs: 28
The spacers fit perfectly. Axle tool should be here Monday and then just 3 or 4 more details for the front end and then I can call the conversion "done".
One of the details is this caliper spacing. DEcosse's fork swap mega thread on triumphrat says these busa forks with the sprint front wheel should fit stock sprint calipers with just an M10 washer as a spacer.
That is too much brake drag right? Considering the lines aren't even hooked up, so no hydraulic pressure at all
Old Streetfighter Motorcycle Forum Post 05-16-2015, 09:15 PM   #309
shinyribs
Flip Offs: 58
How difficult was is to install the caliper? If you could put it on without needing to pry, or really put much pressure on it, I'd think that it's not dragging too much.
But that video seems too tight to me. Seems you can actually hear the pads dragging the rotor, or is that something else?
How about leave everything installed , but pull the mounting bolts out of the caliper. Squeeze the brake, release, let the pistons retract, then see where the caliper wants to sit at rest. That's what I've been doing on my bikes when mounting oddball brakes.
Old Streetfighter Motorcycle Forum Post 05-16-2015, 10:03 PM   #310
Ahks
Feckin Eejit!
Flip Offs: 28
That sound is pads dragging. If I loosen the bolts the drag goes away.
Tomorrow I'm going to hook up the lines, bleed it down then squeeze and release the brakes then check the spacing. I suspect these washers I have are a touch on the thin side for this particular use.
Tags
triumph daytona 955i t595
Thank you for viewing Ahks' "Not a Speed Triple" in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Ahks' "Not a Speed Triple" on Custom Fighters Streetfighter Motorcycle Forum
