Host bike has smaller pivot bolt than donor bike...how to get around this? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Swingarm Swaps
Swingarm Swaps Swingarm and Rear End Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > Host bike has smaller pivot bolt than donor bike...how to get around this?
Old Streetfighter Motorcycle Forum Post 01-01-2017, 01:46 PM   #1
makenzie71
Fighterer
Local Time: 12:29 AM
Flipped Off 1 Time in 1 Post
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default Host bike has smaller pivot bolt than donor bike...how to get around this?
Title says it. Donor is a 2005 GSXR600 and host is a 2003 ZR7S. The GSXR pivot bolt is 25mm. I haven't been able to confirm it yet but I am pretty sure the ZR7 bolt is 20mm.
Ideas?
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-01-2017, 01:53 PM   #2
medimicated420
Local Time: 01:29 AM
Flip Offs: 27
Flipped Off 5 Times in 5 Posts
medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!medimicated420 is an amazingly helpful member with a good attitude!
Default Re: Host bike has smaller pivot bolt than donor bike...how to get around this?
http://www.customfighters.com/forums...ad.php?t=76297
this is how jackstand Johnny got around it
medimicated420 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-01-2017, 02:04 PM   #3
makenzie71
Fighterer
If the ID of the pivot bolt is 20mm I'll eat my underwear....
Old Streetfighter Motorcycle Forum Post 01-01-2017, 02:51 PM   #4
makenzie71
Fighterer
Okay well I finally got the pivot bolt out of the ZR7 and it measures .782in. I cut the threaded end off the GSXR pivot bolt and it measured inside .775in. There's some rust inside the GSXR bolt, though...not much, but some. I might be able to sand .007in off both and make the GSXR bolt work as a bushing.
Old Streetfighter Motorcycle Forum Post 01-01-2017, 03:28 PM   #5
Mongoose
Local Time: 10:29 PM
not a fan of machining via a grinder... but do what ya gotta do.
Old Streetfighter Motorcycle Forum Post 01-01-2017, 03:53 PM   #6
makenzie71
Fighterer
I don't think I'll have to actually cut any of the metal. Hadn't crossed my mind, but I actually dealt with this a couple years ago when I mounted a VFR750 swingarm on my GSXR1000. I cut the ends off the pivot bolt and used them to bush a 20mm R6 pivot bolt in the frame.
I think once I get all the rust out of the GSXR pivot bolt it'll work alright. My fear will be getting it all apart is I ever need to haha...maybe cut holes in the GSXR bolt so that grease will get in them.
Old Streetfighter Motorcycle Forum Post 01-01-2017, 04:21 PM   #7
Mongoose
that seems way more complicated then how i did mine.. i guess it's just the words vs doing.
Old Streetfighter Motorcycle Forum Post 01-01-2017, 05:08 PM   #8
a_morti
Local Time: 07:29 AM
Flip Offs: 24
I've done this before by remaking the spacers as top hat spacers. Don't need to meet in the middle, just support the gsxr central spacer at each end.
Does mean some machine time but I'd say neater and more reliable than hacking up the original tube, which will then have bare metal exposed to rust. Also lighter plus way easier to assemble.
Ps - stop measuring Japanese bikes in inches. You make shit way harder than it needs to be with your 712/838th BS.
Old Streetfighter Motorcycle Forum Post 01-01-2017, 05:13 PM   #9
Mongoose
whats wrong with using inches... it's all the same. neither is harder really..
Old Streetfighter Motorcycle Forum Post 01-01-2017, 05:16 PM   #10
a_morti
Flip Offs: 24
You can find yourself trying to look for a .775" bearing when really you need a 20mm bearing.
It's just messy to mix units. You'd never order 2 litres of milk then express it as 2.113 quarts so why measure metric bearings and shafts in inches?
Thank you for viewing Host bike has smaller pivot bolt than donor bike...how to get around this? in the Swingarm Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Swingarm Swaps - Host bike has smaller pivot bolt than donor bike...how to get around this? on Custom Fighters Streetfighter Motorcycle Forum
