Swapping steering stems...1mm wall thickness bushings? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Fork Swaps
Fork Swaps Fork and Front End Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > Swapping steering stems...1mm wall thickness bushings?
Old Streetfighter Motorcycle Forum Post 01-12-2017, 11:57 PM   #1
makenzie71
Fighterer
Local Time: 12:32 PM
Flipped Off 1 Time in 1 Post
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default Swapping steering stems...1mm wall thickness bushings?
Alright the donor triples have a 30mm stem and the stem I'm wanting to use is 28mm. A 1mm wall thickness bushing seems...slight...and I can't seem to find any. How would you guys handle this?
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-13-2017, 12:19 AM   #2
mcantar
Fuck it, let's do it live
Local Time: 11:32 AM
Flip Offs: 45
Fighter of the Year Fighter of the Month
Default Re: Swapping steering stems...1mm wall thickness bushings?
What about building up weld and turning it down on a lathe?
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
These people High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 01-13-2017, 12:47 AM   #3
shinyribs
Local Time: 01:32 PM
Flip Offs: 58
What Mac said. Everytime. JMO.
Old Streetfighter Motorcycle Forum Post 01-13-2017, 05:54 AM   #4
yantosh
Local Time: 06:32 PM
Flip Offs: 14
If I was turning a bush I'd rather make it thicker, press it on then skim it once it was fitted to the stem
Old Streetfighter Motorcycle Forum Post 01-13-2017, 12:19 PM   #5
RatFighter
UnicycleMode
Flip Offs: 190
My first time having to do exactly that came up a year or so ago, had to take up a 1.1mm gap on a Harley "springer" front end being fitted to a Honda CB750K. Only ended up with that one spacer to get it all fitted though, even used the stock size Honda bearings on it.
Try as I might, I couldn't get the bearing race over the bushing I had made for it (attempting to press it on after making the bushing) so I tossed the whole thing back in the lathe and skimmed a little bit off, then tossed the stem and bearing race back in the press and it fit snug as stock.
This user High Fived RatFighter!
Old Streetfighter Motorcycle Forum Post 01-13-2017, 12:24 PM   #6
makenzie71
Fighterer
I took it to my machinist this morning and discussed all the suggestions I've received.
He will weld the area up and then turn it down. He says he can make it match the profile of the GSXR stem without any trouble. Our only concern is that the heat from welding it will affect the bearing race, or possibly make the stem brittle.
Old Streetfighter Motorcycle Forum Post 01-13-2017, 03:19 PM   #7
RedLiner
Senior Fighterer
RedLiner's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 44
Flipped Off 7 Times in 7 Posts
RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!RedLiner is an amazingly helpful member with a good attitude!
Fuck that idea of welding the stem. Too risky in my opinion when a press fit bushing or even one held in with bearing retainer will easily do the job you are after. Have it turned after they are on if the dimensions aren't correct like yantosh and RatFighter suggested. This is the easiest and safest way to do it imho.
I just want the bike to be better, stronger, faster.
Like the 6 Million Dollar Man.
RedLiner is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived RedLiner!
Old Streetfighter Motorcycle Forum Post 01-13-2017, 05:20 PM   #8
mcantar
Flip Offs: 45
Preheat and postheat, use the right kind of filler, should be fine. If you're really worried you can have it properly heat treated afterward, not terribly expensive.
I'd much prefer a solid chunk of metal to a multi-piece setup.
Turbo Busa v1.1
This user High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 01-13-2017, 05:35 PM   #9
blensen
blensen's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 12
Flipped Off 4 Times in 4 Posts
blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!blensen is an amazingly helpful member with a good attitude!
Weld build-up and turn to size is a super common way to repair worn industrial shafts. I wouldn't be concerned at all about doing it to a steering stem where the loads are mostly axial. and well supported by bearings.
Originally Posted by ultimate fighter
my throttle response was as fast as an old man with parkinsons trying to put his keys in the door
blensen is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived blensen!
Old Streetfighter Motorcycle Forum Post 01-13-2017, 05:36 PM   #10
makenzie71
Fighterer
The dude knows his metal and has made axles and driveshafts for me, as well as a number of things from hardened steel. I'm sure it'll be fine for the riding I do.
Thank you for viewing Swapping steering stems...1mm wall thickness bushings? in the Fork Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Fork Swaps - Swapping steering stems...1mm wall thickness bushings? on Custom Fighters Streetfighter Motorcycle Forum
