oil cooler hose hardware question - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Making Power
Making Power Anything to do with fabricating and modifying engines, carbs, ignition, etc. goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > oil cooler hose hardware question
Old Streetfighter Motorcycle Forum Post 02-21-2017, 01:36 PM   #1
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:13 AM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Default oil cooler hose hardware question
Is there any easy / clean way to put a U turn (or similar hardware) on a flange fitting on an oil cooler? I think the entrance / exit flanged tubes on my cooler are welded in place (bummer, because the ones on the engine are NOT, so if I had a better cooler I could do AN6 or some such) and I'd like to route the one that faces forward towards the back of the bike, without resorting to a doofy looking loop of hose.
I suppose worst case, I can put some hose on the flange, butt a barb fitting U turn right up against it, and camp em both. I'd prefer something cleaner though, am looking for some sort of hardware-to-hardware fitting.
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-21-2017, 03:40 PM   #2
makenzie71
Fighterer
Local Time: 03:13 AM
Flipped Off 1 Time in 1 Post
makenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to allmakenzie71 is a name known to all
Default Re: oil cooler hose hardware question
Have the flanges you want welded to it. You could have the setup the way you really want for under $100.
makenzie71 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-21-2017, 09:25 PM   #3
shinyribs
Local Time: 04:13 AM
Flip Offs: 58
For the particular look your bike has already, how about forming some soft copper tubing for the oil lines and just using a short bit of rubber hose to connect the ends?
Old Streetfighter Motorcycle Forum Post 02-21-2017, 09:27 PM   #4
makenzie71
Fighterer
Hell yeah as industrial and wild as that thing is I'd steampunk the shit out of it. A big gauge on the oil line reading pressure wouldn't go amiss.
This user High Fived makenzie71!
Old Streetfighter Motorcycle Forum Post 02-21-2017, 10:05 PM   #5
SEBSPEED
V4's FTW
Flip Offs: 53
Cxracing.com, new cooler under 70 bux
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 02-21-2017, 10:53 PM   #6
shinyribs
Flip Offs: 58
But this bike needs a Lockhart.
Old Streetfighter Motorcycle Forum Post 02-22-2017, 04:03 AM   #7
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
Flip Offs: 21
That is certainly tempting. I just wish there was a better way to connect hard lines to the cooler. In theory I could run the hard lines right down to the filter adapter, if I got the right hardware, because that bit is threaded, so CAN take new hardware.
Given that I'm ditching the stock instrument cluster, having something to replace the idiot light might actually be a good idea. The one on my FJ comes on fairly often - I think the sump pickup is at the front of the engine.
I'd never even heard of them. I thought I was buying a stock cooler (some XJ models came with em). The extremely 80's logo is a nice touch, was part of why I mounted it so visibly.
Old Streetfighter Motorcycle Forum Post 01-25-2018, 10:02 PM   #8
beezwiz
Flip Offs: 7
Flipped Off 15 Times in 9 Posts
beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!
I have had some painful experiences w/ the Lockhart brand. Outer frame of cooler is not the most resilient of materials... junk aluminum!
Old Streetfighter Motorcycle Forum Post 01-26-2018, 09:51 AM   #9
venturesomerite
Oiler Boilereerer...er(s)
venturesomerite's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 6
Flipped Off 4 Times in 3 Posts
venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!venturesomerite is an amazingly helpful member with a good attitude!
Those lines are oddly placed, never seen anything like that. I'd personally start with a different one and sell that on ebay and make your money back. I would think anything welded on to extend/adapt those lines would be fragile if you didn't take them back down to the cooler and start from square one, and at that point, other than cause you can, why bother? Might make better use of time and money to start with something else.
I think if you could find a cooler that had both come out the side, it would make a ton more sense in your application. This one's 200 bucks, but it was the first one I saw that looked like my thinky pictures.
EDIT**** a quick google reveals some thing like this here attachment is what I'm talking about
Name:	Screen Shot 2018-01-26 at 8.49.50 AM.png
~~~Brian
*** Sorry, had all my pics hosted on photobucket and they turned out to be a greedy cunt. Working on getting them all hosted elsewhere, and slowly fixing 5 billion pictures.
Uglier Better - 1996 Suzuki Katana 600 that wants to be a Gixxer
Coffee Pot - 1983 Yamaha Virago 920 - A cafe build on the super duper cheap.
venturesomerite is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-26-2018, 02:29 PM   #10
SEBSPEED
V4's FTW
Flip Offs: 53
Put a Lockhart sticker on it. That's all Lockhart did when they imported theirs...
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Thank you for viewing oil cooler hose hardware question in the Making Power section of our streetfighter motorcycle forum. I hope you found it useful!
Making Power - oil cooler hose hardware question on Custom Fighters Streetfighter Motorcycle Forum
