Looking at a small-ish Sharp mill, thoughts? - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Looking at a small-ish Sharp mill, thoughts?
Old Streetfighter Motorcycle Forum Post 03-02-2018, 06:43 PM   #1
Junkie
re-tarded
Local Time: 09:20 AM
Flip Offs: 3
Default Looking at a small-ish Sharp mill, thoughts?
Came across this.
Sharp Vertical Mill, single phase, good condition.
What's a reasonable price for it? Any guesses on tool holding? The guy isn't sure (a friend of his died, he's selling it for the widow). Any guess on weight? Looks smaller than a bridgeport so I'm guessing I should be able to throw it in my '73 Chevy C20 Camper Special (3/4 ton but almost 1 ton) with utility bed no problem.
Anything specific I should check out on it? I don't really have room for a full size but I can manage to fit this.
Loading would be by forklift, unloading will be by cherry picker... that's gonna be interesting.
Old Streetfighter Motorcycle Forum Post 03-02-2018, 07:00 PM   #2
Junkie
re-tarded
Flip Offs: 3
Default Re: Looking at a small-ish Sharp mill, thoughts?
To compare: currently I have a little HF 44991 (aka Sieg X2) POS. It's way better than nothing, but not very good. I don't really want to dump money into a DRO on something as small as it is (by the time I install the vise I don't have much room to the spindle, if I run a drill chuck I almost have to run stubby bits)
Old Streetfighter Motorcycle Forum Post 03-02-2018, 07:54 PM   #3
SEBSPEED
V4's FTW
Local Time: 12:20 PM
Flip Offs: 53
No idea on spindle taper, but that unit would be a huge step up from what you have. Simply for the adjustable knee. Make sure to check the ways to make sure it's not clapped out, check motor for noises and quill for play. Probably weighs about 750lbs. Should be fine in your truck.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 03-02-2018, 08:01 PM   #4
SEBSPEED
V4's FTW
Flip Offs: 53
Also, make sure you negotiate for the package, I see a fair bit of extra tooling there that will cost you a lot to buy separately.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 03-02-2018, 09:27 PM   #5
Junkie
re-tarded
Flip Offs: 3
I take it to check the ways I hook up a dial indicator, wiggle, move, wiggle, repeat, see how much it changes (as I should be able to tighten them)
how much play in the quill is reasonable?
Old Streetfighter Motorcycle Forum Post 03-02-2018, 10:42 PM   #6
SEBSPEED
V4's FTW
Flip Offs: 53
Any play in the quill is bad as it will get worse as it extends. It's an indication of bad bearings (which could be replaced, depending on how adventurous you are).
Take a quick look on google for how to inspect machine ways. Ideally they will be very smooth and even and show signs of scraping, worst case they will show hard wear from lack of cleaning and lubrication. Gibs can be tightened to compensate for a worn area, but will then be tight in a less worn area.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 03-03-2018, 12:20 AM   #7
Streetfighterkz
Capt Oblivious
Streetfighterkz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 11 Times in 7 Posts
Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!
That looks quite a bit like my Select 6x26 mill. I bought mine in pretty good condition with a bunch off endmills, collets, and a vice for $1000. Had to rent a engine hoist to take apart and move it to my garage.
Later, Doug
74 Kawasaki H1-500 Project
76 Kawasaki Kz900 'Strip-fighter Project
77 Kawasaki Kz1000
78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-03-2018, 02:28 AM   #8
Junkie
re-tarded
Flip Offs: 3
That might be an option. Removing the head would make me feel way better about it not falling over etc in the back of the truck etc.
Old Streetfighter Motorcycle Forum Post 03-03-2018, 12:08 PM   #9
Junkie
re-tarded
Flip Offs: 3
Regarding tying it down: what should I attach to on it? Is there such thing as too tight (other than the limits of the mount points on my truck)?
Old Streetfighter Motorcycle Forum Post 03-03-2018, 12:43 PM   #10
SEBSPEED
V4's FTW
Flip Offs: 53
See if you can get your straps between the pulley box and the horizontal head shaft. Minimum of 2, one to each side. Then do a minimum of 2 on the bottom also. Bring sling straps in case the hooks won't pass through, or use the strap end of spare ratchet tie downs to loop through and tie off to give a hook hold. Tight as you like without folding your box sides in, better it you drill through the bed to the frame rail, better yet if you borrow a trailer as your picker may not extend high enough to lift the machine from the bed.
When I hauled my Bridgeport, I lagged 2x4's to the trailer floor all around the machine base to keep it from shifting, and i used 4 large cargo ratchet straps off the top of the column pulling to each corner to keep it from tipping. It never moved an inch even though I had to pull it from Long Island through NYC roads which are like driving through a mine field.
As I do with any type of load, I stopped 10-20min into the drive to recheck the straps to make sure nothing moved, settled, or came loose. It was all tight all the way home.
I did break my machine down, I brought a pallet to lay the head on and I simply strapped it down after laying it in there with the forklift. Table was laid on a moving blanket in the bed.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
This user High Fived SEBSPEED!
Thank you for viewing Looking at a small-ish Sharp mill, thoughts? in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Looking at a small-ish Sharp mill, thoughts? on Custom Fighters Streetfighter Motorcycle Forum
