wont turn over - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Beginner Streetfighter Questions
Beginner Streetfighter Questions This is the place to ask all beginner questions with no fear of being flamed. This section will be HEAVILY MODERATED! Any fighter related question is allowed, no matter how simple!
CustomFighters.com Streetfighter Motorcycle Forum > wont turn over
Old Streetfighter Motorcycle Forum Post 07-02-2018, 11:34 AM   #1
betocho343
gixxer750No0biie
Noobie
Local Time: 06:50 PM
betocho343 is a NOOB
Default wont turn over
97 gixxer 750. had my bike running with some problems. from the start had issues with electrical system & carbs leaking badly. when i took the carbs of for rebuild, the 1st piston was filled with gasoline. removed stator cover, stator, rectifier, starter, battery, starter sylenoid, throttle cables, choke cable, & clutch. replaced all of the above parts & put it back together. Now when i turn the key on, the dash & lights come on, but when i hit the start button nothing happens. It wont turn over or anything. thought maybe the ecm may need to be replaced, cuz the fuel pump wont prime eiter. the pump & relay are good. There is power in the r/blu & g/blk wires to fuel pump when key is open. any HELP appreciated. Thanks
betocho343 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-03-2018, 10:53 AM   #2
Casper
The friendly Ghost.
Local Time: 03:50 PM
Flip Offs: 188
Default Re: wont turn over
If you apply 12 V directly to the fuel pump (fuel line not attached to the carbs) does it flow?
If you apply 12 V directly to the starter motor (not attached to the engine) does it spin?
After that yes,
If you apply 12 V to the starter relay trigger circuit, does it apply 12 V power to the starter motor and does it spin (attached to the engine)?
After that yes,
Have you checked your safety switches?
* Clutch Lever safety switch
* Neutral safety switch
* Kick stand safety switch
* Tip over safety switch
Have you checked that your switches are in working order?
* Ignition switch
* Kill switch
* Starter switch
Some times trying to start a hydro locked engine will burn out the starter motor.
Some times the starter solenoid goes bad.
Some times the safety switches are not working correctly or have damage in the harness that prevents the bike from seeing the system as safe.
Some times the switches get corrosion on the contacts and prevent it from moving enough electricity.
Casper is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 07-03-2018, 09:27 PM   #3
Mongoose
Drain the cylinder.. Changee the oil... Then recheck all your work.. Probably missed somethin easy like a ground or the switcj gear block isnt in 100%
This user High Fived Mongoose!
Old Streetfighter Motorcycle Forum Post 08-12-2018, 08:43 PM   #4
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 643
Updates ? Problem solved or still there ?
ROBBO' 2009
Thank you for viewing wont turn over in the Beginner Streetfighter Questions section of our streetfighter motorcycle forum. I hope you found it useful!
Beginner Streetfighter Questions - wont turn over on Custom Fighters Streetfighter Motorcycle Forum
