How To Attach a Subframe. - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > How To Attach a Subframe.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 04:06 PM   #1
remfanuk
Senior Member
Fighter
Local Time: 05:16 AM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
Default How To Attach a Subframe.
The mk2 bandit frame is not endowed with prettiness primarily i think due to the lines of the subframe. So, i am removing it and want to put something eyecatching but functional. Correct me if i am wrong, but aluminium and steel cannot be successfully welded, so I thought how best to bolt a subframe onto the main frame.
You can see from the photos where I plan to chop the subframe off. Assuming I would have to have a couple of chunks of steel welded to the frame which could be tapped or just have a bolt through them to attach to the subframe, I am unsure what that might look like. Clearly i dont want to weaken the aluminium tubing at the point that it mounts to the frame by making some kind of cutout for the mount...anyone got any photos of a bolt on arrangement please? hope i make sense...oh, i am not a welder! Thanks
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-20-2019, 04:48 PM   #2
Junkie
re-tarded
Local Time: 02:16 AM
Flip Offs: 3
Default Re: How To Attach a Subframe.
I'd start off by making inserts that go into the main frame tube and have one end shaved down approximately halfway, with a transverse threaded hole for the bolts to go into (I'd rather trust threads in steel than aluminum). Either find a size of round stock with a nice tight fit or, if you have to, turn some down to size.
For the subframe side, the concept is about the same. If you're using round tube, find or make round stock that fits nicely into the tube.
See my quick sketch. Obviously only one of them (frame or subframe) will have a threaded hole, the other will have a plain hole and probably a flat spot for the bolt to tighten against.
These people High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 05-20-2019, 05:02 PM   #3
remfanuk
Senior Member
Fighter
I see...think i have seen something similar before...would you weld the inserts into the frame and the subframe for extra strength? And a nut at the end of the bolt or do we trust the thread of the steel insert? thanks for your time...i appreciate your reply.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 05:09 PM   #4
Junkie
re-tarded
Flip Offs: 3
Yes, I'd absolutely weld the inserts into both. The symbol at the top right corner of the frame tube is a weld symbol, guess I forgot to mention that.
You could use a nut instead if you prefer. In that case you'll want to give it a flat spot to rest on, as with the bolt.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 06:57 PM   #5
mcantar
Fuck it, let's do it live
Local Time: 04:16 AM
Flip Offs: 44
Alum on the alum side, steel on the steel side.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
These people High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 05-21-2019, 12:46 PM   #6
Junkie
re-tarded
Flip Offs: 3
Huh, don't think I've seen those used for subframes. I'm thinking it'd be a PITA to get a bolt in from behind but who knows.
What I was suggesting is essentially that but minus the flange and second bolt.
Old Streetfighter Motorcycle Forum Post 05-22-2019, 03:09 PM   #7
remfanuk
Senior Member
Fighter
Thanks for the help there guys.
From what you drew and described Junkie it would seem to be similar if not the same as the removable lower frame rail on the bandit where two halves of tubing meet. Is that right? If so, I was thinking of using shouldered bolts so the thread is only on the end of the bolt that would screw into the steel part of the frame with the shouldered part passing through the alluminium subframe.
ID:	105120   Click image for larger version
Old Streetfighter Motorcycle Forum Post 05-22-2019, 04:06 PM   #8
Junkie
re-tarded
Flip Offs: 3
Yes, that's about what I'm describing, although most subframe mounts I see only use one bolt rather than two.
I suppose shouldered bolts would be an option to remove a little bit of slop, but if you drill a tight hole (rather than an oversize hole) for the unthreaded section I wouldn't worry about it. That's how mine's mounted.
My subframe is square tube rather than round, but the concept is the same.
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 05-23-2019, 04:04 AM   #9
remfanuk
Senior Member
Fighter
You have been a great help thanks...be good to see a photo of how you went about the same process.
Sent from my SM-G960F using Tapatalk
Old Streetfighter Motorcycle Forum Post 05-23-2019, 02:11 PM   #10
remfanuk
Senior Member
Fighter
Here is my drawing...hopefully looks right?
Thank you for viewing How To Attach a Subframe. in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - How To Attach a Subframe. on Custom Fighters Streetfighter Motorcycle Forum
