Since I'm tearing the bike down and last time I did this I didn't have a bike for over a year I figure I'll start a thread where I can get :fu:'s for not getting off my ass to DW
Heres what I brought home 2 weeks ago
Rode the pants off of it ...
Heres it's pants
Googled around for some inspiration...
Started buying parts... Thanks Purpony
Found a "matching" wheel on another forum...
Rode it one last time before putting it in the basement...
And it's home till it's done.
Wonder if this was part of the inspiration for the new headlight design on the new S3's
So far I've got
wheels
easton taper bars off a ktm 85sx
set of fatbar risers
box of speed triple hardware (on the way)
03 digital clocks
03 speed triple main wiring harness to cut up for bits or replace mine with
direct shift shifter (the OE bits are sloppy as hell)
Still need
Axles spacers:
Right side - 25.05 mm ID x 35mm OD x 28mm long
Left Side - 1mm longer than stock left side spacer
1050 Sprint Rotors
Rare earth magnets
speed sensor
Maybe throttle/clutch/brake lines
Headlight (have an idea for this, need to get it on paper)
sync TB's
check valve clearances
clean this dirty fucker
reassemble bike
ride bike with smile on face
Playing with jacking up the tail a few inches... Could extend the bottom subframe rail by about an inch without disrupting electrics or plumbing...
Not sure I wanna deal with modifying the plastics for this but it's a really aggressive look. Would fuck with my ergo's significantly and I'm tip toeing it around parking lots already. I have carpal tunnel as well, and this would add hand/wrist fatigue
I was thinking that too. And if I'm not pleased with riding position I can look at a fatbar with a bit more rise and pull back or risers like what I had on my CBR
I did notice the brakes were pretty shit compared to my CBR would the master swap give me some of that feel back?
Is there a resource that lists masters sizes by make and model so I can hunt for cheap
I'm 5'7"ish with a 29" inseam. I'm pretty well accustomed to one footing it at lights and got over how silly it is to have to push the bike to move it in a parking lot So raising the seat height isn't as much of a concern in that department. If necessary I can sell the corbin and build me a seat. Found this orthopedic gel thats used in wheelchair pads for pretty cheap that could be cut and shaped. Cant find it on Amazon now of course...
Depending the condition of your linkage you might find it cheaper to trade up to a later 1050 arm and linkage than buy the bearings. Nicer look, easy fit and come up cheap on occasion.
Besides the fact that they are black, whats the difference? Just poked at worldoftriumph.com and linkage part numbers are the same between my bike and all but the newest generation of s3.
Arms look a touch different tho. Not really interested in that kind of expense and REALLY hoping my bearings can do with just a repack
Also since I don't have easy access to a welder...
Extending the rear subfram...
My subby attaches like this
Would it be safe to use some round or square stock to extend it so I can test out the position before commiting? I'm also considering a tail swap for next year and am thinking it may be advantageous to not fuck this one up permanently so it can sell
The standard uses an undersized master at 14mm instead of 5/8". It gets squishy and needs rebleeding fairly often, the lever travel is too long, and the bite is somewhat too ferocious compared to what you need. This is all compared to the standard "sportsbike feel" which has emerged over the years. Swapping to 5/8" will fix it in one step. ZXR750, 1000SRAD or anything sporty with 6-pots will do it, as will 600 or 750K2 or similar era, also 900RRW-X. If you like a built-in reservoir more than piss-pot type, Hyabusa will be perfect. Best bet is to go to a local wrecker's and rummage through their box of spares, which they will almost certainly have.
The rear brake is oversized, 14mm instead of 1/2". It makes the pedal rock-hard, underpowered and "wooden". So you have to really step on the brake, at which point it works as an on/off switch. Swap to the master from a ZXR750 amongst others, and it will work much much nicer. I used ZXR400L, as this was a direct fir with even the same threads cut, but again going through a box of spares will be probably the best way.
The rear arm just looks nicer to be honest! It is a nicer looking casting, seen here:
The main reason though is that the bearings in the linkages in these arms do dry out, do rust, do seize, and the parts alone are very expensive. Replace with a low miles replacement part from a newer bike and you're on a winner, and can still eBay off your arm and old wheel or put it on here for someone who wants a conversion rear end.
I have yet to find a salvage yard that handles motorcycles within an hours drive of me... I should ask shotgun, he lives around here and would probably know.
The new wheels are cool but they're 5.5" not 6" like the ugly 3 spoke so you'll be needing a 180 not 190.
TuneECU is awesome and amazingly powerful for free software.
The valves are a special Triumph tool job unless you want to remove the cams, or there's a replica usually available on eBay. They tighten up so ideally set at the loose end of tolerane.
Don't neglect the rear linkage while you're doing a service.
The PO (2nd owner) told me he had the local dealer do a valve check, fingers crossed.
And also mentioned that the original owner "put new cams in it" which I interpret as "installed the newer exhaust cam", fingers crossed on that as well. My bike is about 1000 units too early in the production line to have the new cam I've got 60323 and the new cam started at about 61xxx or so.
And you are the 3rd person to mention that rear linkage The other guys have said it's usually cheaper to buy the linkage off a newer low mileage bike than to buy replacement bearings :/ lame
Hi liking your bike I have just sold mine,in some ways wish I had not ,but got two gsxr,s on the go at the moment I was getting 142 bhp out of mine great fun and handling a little over engineered for there time sound great real head turners enjoy and be safe have a look at mine.
I love this bike. The power above 3k seems very linear. Don't care so much about that magic dyno number. It's got far more HP up top than I'll use for a while. I'd probably be happier with a street triple with an sssa... but $$$
To help you achieve the stance/tail position that you want: Couldn't you just use a set of lowering links and drop the front end equally in order to give you enough stand over height to play with the tail/subframe angle?
For a bike with a narrow 3cyl engine and high seat these bikes have disappointingly poor ground clearance from stock even before you start lowering anything. I wouldn't. This situation can be helped by fitting a later exhaust manifold from a 98-00 model. That is to say without the springs on the outside at the mid section like yours has but before the crossover balance pipe was added as then your silencers won't fit. These were tucked in/under more.
The rear linkage design also makes it hard to mess with ride height but you can gain a few mm using a 190/55.
Never considered lowering it. Not sure how I feel about the idea. I'm coming from an f4i that had very nice handling characteristics. If I make it feel any heavier I'd be pretty disappointed. But I'm almost a total newbie when it comes to synergy between suspension and steering in motorcycles.
ToDo List
drill triple for risers
direct shift shifter (moose racing?)
5/8" front master (98 cbr900 for example)
1/2" rear master (zxr750 for example)
Axles spacers:
Rare earth magnets
Paint...
reassemble bike
Interested how you're gonna drill that top yoke with the gullwing angle of it.
Related Threads
1.6M posts
40.4K members
Since 2006
