1994 Fireblade Hack - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > 1994 Fireblade Hack
Old Streetfighter Motorcycle Forum Post 07-29-2019, 04:49 PM   #21
a_morti
Local Time: 07:37 AM
Flip Offs: 24
Default Re: 1994 Fireblade Hack
A short piece of vacuum or fuel hose split along its length may do as a stop gap for the tank rubbers.
This user High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 07-29-2019, 04:51 PM   #22
a_morti
Flip Offs: 24
Dave, you're going to advise someone to run their tyres at 'low to mid 20' psi range?
That's way, way down from what the manufacturer says (36/42), and verging on running a flat. I'd say it's a great way to increase fuel consumption, get weird wallowy handling, lose speed, and maybe even get a tyre delaminate in the long term.
It's a good thing you know everything about bikes, eh.
Old Streetfighter Motorcycle Forum Post 07-30-2019, 10:22 AM   #23
Junkie
re-tarded
Local Time: 10:37 PM
Flip Offs: 3
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
36/42 is WAY too high unless the bike is seriously loaded down. It might be reasonable for touring 2 up, but solo without a bunch of shit on the bike you'll never get any heat into the tires.
I wouldn't quite run low to mid 20s on a leadrebike, more likely high 20s when riding for fun, but nowhere near 36/42.
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
Old Streetfighter Motorcycle Forum Post 07-30-2019, 01:00 PM   #24
AgentOrange
Aspiring Hooligan
Fighterer
AgentOrange's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 1 Time in 1 Post
AgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to all
Seems like most people run about 30 pounds, I'm 160 pounds without gear.
I have taken off about 30 pounds of fairing, brackets, etc. I'm not sure if that is enough weight to affect tire pressures.
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.
AgentOrange is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-30-2019, 03:09 PM   #25
AgentOrange
Aspiring Hooligan
Fighterer
Greased and dialed the head bearings, just a little drag. The last guy who touched it must have thought the top nut had something to do with the bearing preload. I just about broke my back getting that thing off. The preload nut was finger tight and the grease was dry. Would have made an interesting first ride.
Another issue I came across is the rear brake caliper. There seems to be a hug amount of play. As far as I can find there are no missing parts and nothing is too worn. The caliper plate, caliper, and pads are seem to be wandering and embedding themselves into everything around it. The top pin seems to fit very poorly, tons of slop. Like missing a bronze sleeve type of slop....
This user High Fived AgentOrange!
Old Streetfighter Motorcycle Forum Post 07-30-2019, 05:05 PM   #26
a_morti
Flip Offs: 24
The caliper floats on the mounting bracket, in and out in the sliding pin (front) with rubber boot and the rubber bushing on the (rear) fixed bolt (sorry not sure on tech terms here). If the rubber boot on the sliding pin gets torn and the grease gets out, the sliding pin will run metal on metal where the soft cast alloy hole will expand. It could also just get worn with very high miles.
If the front hole in the mounting plate is wollered out, the mounting plate may be junk. Unless you're really good at drilling off centre holes and fitting brass bushes in them.
If the hole still looks round, could be that replacing the rubber boots will do it.
The boots usually tear due to people using ordinary grease on the sliding pins. You need to use rubber safe grease, ordinary grease will absorb in the rubber making it swell, then tear.
Old Streetfighter Motorcycle Forum Post 07-30-2019, 05:10 PM   #27
a_morti
Flip Offs: 24
I used to run 32/36 for regular road riding on the last blade I had, rode just fine. If it dipped 5psi lower I could tell in a bad way, any less than that I couldn't tell (as I found out with a slow puncture in the rear). Still 10psi more than Dave recommends.
Old Streetfighter Motorcycle Forum Post 07-30-2019, 06:31 PM   #28
AgentOrange
Aspiring Hooligan
Fighterer
The hole is definitely wollered out. Looks pretty round. The pin measures 9mm, the hole is just over 10mm. I could probably drill it out and press a bronze bush in there. Mcmaster has them for just under $2.00.
Old Streetfighter Motorcycle Forum Post 07-30-2019, 06:44 PM   #29
a_morti
Flip Offs: 24
It isn't meant to be a tight fit as the rubber takes up play. But it is meant to be round. Get yourself a set of rubbers, and see if that solves it. If not, go crazy with bushings.
Old Streetfighter Motorcycle Forum Post 07-31-2019, 07:59 PM   #30
AgentOrange
Aspiring Hooligan
Fighterer
Figured out the brakes. The boots weren't seated. Bled the rear brakes. The fronts probably need a rebuild, the fluid was milky, I ran out of fluid before it cleared up.
Adjusted and cleaned the chain, need a new one of those too. Just past the "replace chain" line.
Grips, jets, and spark plugs showed up today. Should have some time Friday.
Thank you for viewing 1994 Fireblade Hack in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - 1994 Fireblade Hack on Custom Fighters Streetfighter Motorcycle Forum
