GOLDEN TRASH 78 KZ650 - Page 13 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > GOLDEN TRASH 78 KZ650
Old Streetfighter Motorcycle Forum Post 09-11-2019, 04:14 PM   #121
Larry02ACR
Senior Member
Fighterer
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:19 PM
Flipped Off 1 Time in 1 Post
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
Default Re: GOLDEN TRASH 78 KZ650
Originally Posted by rabies View Post
so I need a longer chain. I believe 6 links.
oem KZ650 chain is 102. I need about 108.
ninja chain is 520
kz is 530
I bought a 520(should still fit) with 110 links.
cut off link use master? simple enough. I think I did this same procedure long time ago with the 79 kz750 R1 newb build
A sprocket for a 530 chain is about 1/8" wider (or should be) than one for a 520 chain.
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-11-2019, 05:47 PM   #122
Junkie
re-tarded
Local Time: 03:19 PM
Flip Offs: 3
you'll need a 520 front sprocket to get the chain on
Old Streetfighter Motorcycle Forum Post 09-12-2019, 09:41 AM   #123
rabies
time is running out......
CF Lover
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 1,393
Flipped Off 39 Times in 35 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
dang. so the ninja sprocket is 520 on the wheel.
the front needs changed out on the kz motor for 520 drive sprocket? got it.
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-12-2019, 10:58 AM   #124
Junkie
re-tarded
Flip Offs: 3
correct
you might be able to get away with running a 530 chain on 520 or 525 sprocket (it wouldn't be right, and would be able to move back and forth because the sprocket would be narrower) but the 530 sprocket is too wide to fit in between the side plates on the 520 sprocket
if you're trying to be as cheap as possible you might be able to grind the sprocket down to size
Old Streetfighter Motorcycle Forum Post 09-12-2019, 11:14 AM   #125
rabies
CF Lover
Flip Offs: 1,393
i found a 520 sprocket for $10 on ebay.
just need to get those fancy JDM rearsets from *streetfigheterkz*
mount chain.
finish welding tabs(correctly)
and make a bracket dealy for the caliper since it has to be moved.
Old Streetfighter Motorcycle Forum Post 10-03-2019, 10:45 AM   #126
rabies
CF Lover
Flip Offs: 1,393
wrong sprocket. I ordered a 520. aparantly its not...does not fit the chain.
swingarm and wheel is from a 2013 ninja 300/sprocket is def 520.
old vs new.
neither fit chain.
also figured out rear brake since I got a much better welder 140 Hobart mig.
...itl work...
Old Streetfighter Motorcycle Forum Post 10-03-2019, 12:50 PM   #127
Junkie
re-tarded
Flip Offs: 3
it appears the sprocket says JTF513 on it, http://www.jtsprockets.com/catalogue/sprocket/JTF513/ says it's a 530
a 520 sprocket should be 1/4" wide (in reality I think a touch narrower - https://www.mcmaster.com/2299k45 is .343" wide when it'd be for a 530 chain, so 1/32" under the supposed width, 520 would be .219")
These people High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 10-03-2019, 04:03 PM   #128
rabies
CF Lover
Flip Offs: 1,393
just ordered a sprocket from a 300 ninja. $8
Old Streetfighter Motorcycle Forum Post 10-03-2019, 04:21 PM   #129
Junkie
re-tarded
Flip Offs: 3
I think that represents 42mm between holes, 21.7mm spline minor diameter, 25mm spline major diameter, Z-13 (13 splines?)
that has all the same numbers, although I can't say for sure that it'll fit.
I'd give JT a call and see what they say.
edit: I guess the pics don't show here. http://www.jtsprockets.com/catalogue/sprocket/JTF513/ is for the 513 and http://www.jtsprockets.com/catalogue/sprocket/JTF1581/ for the 1581
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 10-07-2019, 05:10 PM   #130
rabies
CF Lover
Flip Offs: 1,393
got the chain on. correct sprocket (on the correct side...)
just need to bolt on rearrests and get a proper brake line
Thank you for viewing GOLDEN TRASH 78 KZ650 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - GOLDEN TRASH 78 KZ650 on Custom Fighters Streetfighter Motorcycle Forum
