GOLDEN TRASH 78 KZ650 - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > GOLDEN TRASH 78 KZ650
Old Streetfighter Motorcycle Forum Post 05-11-2019, 12:03 AM   #31
scottiemann
fuckin genius
Fighterer
scottiemann's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:14 PM
scottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud ofscottiemann has much to be proud of
Default Re: GOLDEN TRASH 78 KZ650
Its coming along nicely, cant wait to see it done.
And I am into guns and antique machine restoration and have seen the aluminum black stuff, never used it but other people love it.
I have an anodizing setup at my parents house I haven't used in years but I can do 8 different colors. its pretty cheap and easy to set up but has a learning curve.
However it would be somewhat difficult to get a decent finish on those levers with anything but black because they look like the standard cast levers. cast aluminum is unpredictable to anodizing because of all the impurities and the fact that impurities can collect more densely in certain areas of the piece...
sorry to thread jack, and very nice work sir
current build is on YouTube, check out my channel The Armed DIYer
****Current Build****
91 GSXR 750
mods yet to be determined
******On Hold******
98 superhawk
Debaffled cans
De-PAIRed
TPS mod
Bmc air filter
Factory pro jet kit
Factory pro ignition advanced
15/42
05 CBR1000RR front end
Bunch of other shit...
scottiemann is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived scottiemann!
Old Streetfighter Motorcycle Forum Post 05-13-2019, 10:14 AM   #32
rabies
time is running out......
CF Lover
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:14 PM
Flip Offs: 1,393
Flipped Off 39 Times in 35 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
its good info. mind sharing a link to some of the learning? I like doing my own stuff.
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-13-2019, 10:42 AM   #33
rabies
CF Lover
Flip Offs: 1,393
oil change.
smelled like fuel.....but it had oil and plenty.
more goodies
new valve cover gasket and cleaned up bolts
I don't like rap but it looks good
top triple is thin. and I drilled for some handle bar stems.
so I JB welded some washers on the bottom
waiting on carbs.
gas tank filler lid.
make wiring harness
finish seat
These people High Fived rabies!
Old Streetfighter Motorcycle Forum Post 05-13-2019, 11:48 AM   #34
scottiemann
fuckin genius
Fighterer
Caswell Plating
I wanna say it was this place I got my information and stuff from but they have grown a lot since I bought my stuff years ago. I only bought their etching/cleaning chemicals and dye from them. I put the rest of the kit together myself using car battery acid/distilled water, lye for stripping anodizing, aluminum plates hung with a makeshift aluminum rack, a cheap hot plate for heating the dye and sealer and a car battery charger for doing the actual anodizing...
91 GSXR 750
******On Hold******
98 superhawk
Debaffled cans
De-PAIRed
TPS mod
Bmc air filter
Factory pro jet kit
15/42
Old Streetfighter Motorcycle Forum Post 05-14-2019, 11:32 AM   #35
rabies
CF Lover
Flip Offs: 1,393
looky looky.
(he said they were cleaned) but jetted for pods and exhaust. rebuilt.
need to get new manifold boots. mine are all cracked. I could RTV them but they hold up the carbs. il make a carb stay too that supports they weight. (airbox normally supported them)
Wednesday night Il have more done.
Old Streetfighter Motorcycle Forum Post 05-17-2019, 11:15 AM   #36
rabies
CF Lover
Flip Offs: 1,393
Default seat. still dont knwo what im doing
my cat insisted that i cut this seat and redo it. throwing away precious kevlar
cleaned up frame some more.
and seller jipped me.
this mig is junk. welds like a hot glue gun. just melts wire
and this. after 1hr of milling the inside with a bur bit
Old Streetfighter Motorcycle Forum Post 05-17-2019, 11:22 AM   #37
rabies
CF Lover
Flip Offs: 1,393
Default wiring
i don't do wiring.
i hate wiring
i don't understand wiring.
my wiring friend is too busy chasing tail.
so here i am...figuring it out
simple enough right?????????????????????
then the flood came and ruined the party. i got into the ark and went to bed
how the show ended
need to remove starter cable.
finish making wiring harness
finish seat.
bleed front brake
waiting on new carb boots.
finish tank.............so basicly the whole bike is still far from done
..i just want to ride a motorcycle
Old Streetfighter Motorcycle Forum Post 05-17-2019, 11:39 AM   #38
Junkie
re-tarded
Local Time: 05:14 PM
Flip Offs: 3
what bike is that R/R from? I'm used to them having 3 phase input (3 wires) and then DC output (2 wires, hot and ground). It looks like you have 3 phase input but then maybe it grounds through the case? Not what I'm used to seeing.
Old Streetfighter Motorcycle Forum Post 05-17-2019, 12:18 PM   #39
rabies
CF Lover
Flip Offs: 1,393
what is R/R? rectifier/regulator?
its brand new oem for the 78 kz650. 3 wire plug and 1 red odd ball wire.
Old Streetfighter Motorcycle Forum Post 05-17-2019, 01:15 PM   #40
Junkie
re-tarded
Flip Offs: 3
yes, regulator/rectifier
the red wire is your +12V
how does it ground? if it was through contact with the frame I'd expect to see an area with anodizing removed (so that it makes a good contact).
This user High Fived Junkie!
Thank you for viewing GOLDEN TRASH 78 KZ650 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - GOLDEN TRASH 78 KZ650 on Custom Fighters Streetfighter Motorcycle Forum
