Is Smoking Permitted? - Page 249 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Is Smoking Permitted?
Old Streetfighter Motorcycle Forum Post 12-22-2018, 08:30 PM   #2481
Smoker
BLACK BELT
Local Time: 08:12 PM
Flip Offs: 35
Default Re: Is Smoking Permitted?
Today, someone with a +7mm OEM cylinder [running] engine let me know he's about an hour away.
Nice bike, and he sent me the dyno results.
Sounds like someone is looking for a SHOWDOWN!
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 12-22-2018, 11:41 PM   #2482
shinyribs
Local Time: 11:12 PM
Flip Offs: 58
That's a dang nice torque curves, too. For a high revving 2T it's not very peaky looking. Nice! The benefit of the twin, I suppose.
Old Streetfighter Motorcycle Forum Post 12-23-2018, 07:17 AM   #2483
Smoker
BLACK BELT
Flip Offs: 35
Mostly due to the YPVS. Banshee engine is very similar, but no power valve.
Other good thing about this build is the engine is considerably more "square". OEM is 54mm stroke x 64mm bore. The +7mm will have 61mm stroke x (probably) 66mm bore.
Old Streetfighter Motorcycle Forum Post 12-23-2018, 07:50 AM   #2484
rex_saugerty
V four honda whore
Local Time: 06:12 AM
Flip Offs: 3
So you would say i would benefit from boost bottle on 80cc single too?
Old Streetfighter Motorcycle Forum Post 12-23-2018, 12:51 PM   #2485
Smoker
BLACK BELT
Flip Offs: 35
I would say you won't lose power with a proper boost bottle for your engine.
It could smooth out the power delivery, and add a little HP, mostly on the bottom end. I've read claims of +10 (bottom), +4 (mid), and +2 (top), on a much larger engine than yours.
The Helmholtz Resonant Frequency Formula is hard to apply because of the many engine variables. Finding the perfect BB for a specific engine always comes down to trial & error. Harry Barlow did a great research project and paper on boost bottles years ago, if you can find it.
Helmholtz Resonant Frequency Formula:
f=(a/2pi) x [{pi(Dp/2)^2}/Vb{Lp+1.57(Dp/2)}]^0,5
f= resonant frequency of bottle (ie. effective RPM)
a=speed of sound at your altitude (340m/s at sea level)
Dp=Diameter of connecting pipe in cm
Lp=Length of connecting pipe in cm
Vb=bottle volume in cc
The bottle should be at least as big as the displacement of the cylinder and the hose cross section should be at least as big as the throttle opening at the intended RPM. Yamaha's SAE paper was #810923, most technical university libraries have these on file. Keep in mind that this is to design a bottle for a single cylinder engine.
Old Streetfighter Motorcycle Forum Post 12-23-2018, 01:22 PM   #2486
rex_saugerty
V four honda whore
Flip Offs: 3
Thanks for this a lot
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:03 PM   #2487
Smoker
BLACK BELT
Flip Offs: 35
Guess I should have said an aftermarket generic boost bottle is a total gamble, and not a good one.
If you like the way it looks, try it out. Make a custom one, if you can. Use your butt dyno.
For my engine, the best builders are using intakes with internal crossovers. No boost bottles.
I'm using the boost bottle because I like the look, not for more HP.
Most bikers look at it like some kind of alien appendage.
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:04 PM   #2488
RS_Raz
Dickhead
Senior Fighterer
Local Time: 04:12 AM
Flip Offs: 10
This is a real deal dyno print out of a Banshee engine with & without a boost bottle:
IMO I don't think Yamaha would have bothered with the R&D, manufacture & installation of boost bottles if it didn't have benefits. I read that it improves low speed running by allowing mixture to enter a chamber until it's needed rather than passing back through the carb and picking up even more fuel on it's way back into the engine, causing a rich condition.
These people High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:04 PM   #2489
rex_saugerty
V four honda whore
Flip Offs: 3
Well mine is 80cc same engine base as JDM nsr80, would like to have some power for city fun
Old Streetfighter Motorcycle Forum Post 12-23-2018, 02:52 PM   #2490
Smoker
BLACK BELT
Flip Offs: 35
Let me know when you have a real dyno.
Tags
ewoks stole my boxers
Thank you for viewing Is Smoking Permitted? in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Is Smoking Permitted? on Custom Fighters Streetfighter Motorcycle Forum
